Simlocki K510i, K750i - błąd FILE NOT FOUND przy użyciu Cruisera
newchief 05 Sty 2007 11:21 4202 21
  • #1 3407718
    newchief
    Ocena: 20
    Witam!
    Mam problem :
    Gdy robie simlocka cruiserem:
    Odblokowanie RSA
    Odblokowanie Simlocka
    Firmrestore
    to jak konczy robisz Firm Restreo to wywala mi telefon i mowi ze FILE NOT FOUND .. jakiegos FW brauje i musze flashowac telefonik. ;/
    System diagnostics passed.
    Version 10.10 beta ready!
    [ --- Attach to Phone --- ]
    Connecting via Fighter USB Cable...
    Powering on the phone...
    Baseband chip ID: 0x8040
    Protocol version: 3.1
    Baudrate = 460800Bd
    Trying Red CID29 flash applet...
    Trying Brown CID29 flash applet...
    Trying Blue CID29 flash applet...
    Trying Red CID16 flash applet...
    Trying Brown CID16 flash applet...
    Trying Blue CID16 flash applet...
    Trying Red CID36 flash applet...
    Trying Brown CID36 flash applet...
    Trying Blue CID36 flash applet...
    Trying Brown CID49 flash applet...
    Sending applet prologue...
    Sending applet body...
    Time spent entering bootstrap: 4s
    Initializing phone hardware...
    Applet ID: 060206 1814 NPACXC125872_COMPACTPRO...
    Flash manufacturer: Intel
    Flash ID: 0x897E
    OTP Security Level: 1 (Retail)
    OTP CID: 49
    Phone type (from GDFS): K510i
    CXC article: R4EA031 prgCXC1250231_GENERIC_CO
    CXC version: R4EA031
    Language package: CENT_EUROPE
    Operator: T-Mobile
    CDA article: CDA102460/19
    CDA version: R9A
    Default article: cxc1250246
    Default version: R4EA031
    Crash counter: 0
    Phonecode: 0000
    Sending applet...
    Applet ID: 060305 1000 104_DB2010_FLASHLOADER_...
    RSA protection state cannot be determined for this CID.
    Phone hardware initialized OK
    [ --- Unlock RSA --- ]
    Preparing to program flash...
    Baudrate = 921600Bd
    The applet ignored baudrate change request!
    Programming flash...
    Time: 00:00:01
    Flash process done.
    Phone automatically detached.
    Baudrate = 460800Bd
    Flash ID: 0x897E
    OTP CID: 49
    Operator: T-Mobile
    CDA version: R9A
    Crash counter: 0
    Phonecode: 0000
    Sending applet...
    [ --- Change Certificate Color --- ]
    [ --- Direct Unlock --- ]
    Defeating RSA protection...
    Waiting for the phone to turn off...
    Should the communication hang, reinsert battery.
    Baudrate = 460800Bd
    Waiting for acknowledge...
    Applet ID: 060514 1351 CRUCXCxxxxxx_S_LOADER_S...
    Initializing applet...
    Baudrate = 460800Bd
    Defeated!
    Sending applet...
    Applet ID: 060525 0308 CRUCXCxxxxxx_PRE_LOADER...
    Sending applet...
    Applet ID: 060430 0501 CRUCXC1326743_COMPACTPR...
    Reading security zone...
    Unlocking phone...
    Recalculating CRCs...
    Phonecode: 0000 (default)
    Turning off phone...
    Baudrate = 460800Bd
    Flash ID: 0x897E
    OTP CID: 49
    Operator: T-Mobile
    CDA version: R9A
    Crash counter: 0
    Sending applet...
    [ --- Restore Firmware --- ]
    Baudrate = 460800Bd
    Baudrate = 460800Bd
    Identifying firmware...
    Firmware ID: prgCXC1250231_GENERIC_CO
    Firmware version: R4EA031
    Defeated!
    Sending applet...
    Sending applet...
    Searching for FW restoral file...
    File name: R4EA031_CXC1250231_GENERIC_CO.ck51sw
    FW restoral file NOT FOUND.
    Download and install the latest FW-Restore installer from our support area.
    i pozniej musze robisz flasha
    [ --- Flash Main Firmware --- ]
    Flash file: "K510i_CXC1250231_Generic_R4EA031_Red49.ck51sw"
    Waiting for flash file to load...
    Baudrate = 921600Bd
    RSA protection was set back to normal.
    Time: 00:08:22
    Flash process done.
    Moze cos robie zle? prosze o pomoc jestem nowym swiezym uzytkownikiem cruisera.
    Dodam iz np z k300i nie mialem tego problemu..
  • #2 3407781
    nc22
    okim ale cid 49 robi tylko setool 3 rozumiem ze po flashu tel wstaje bez sima co do k510 to nawet usb-smart niema problema ale co prawda musisz zanizyc cida co do k750 to niepoleci ci go na cid 49 musz obnizyc cid do 36 . Ja robie na setoolu 3 i zdasa sie ze po simie musze przefleszowac
  • #3 3407784
    sim
    Ocena: 7
    Nie wspominałeś o tym więc powtórzę za cruiserem:
  • #4 3407794
    nc22
    a jeszcze co da k300 to majom maksymalnie cid 36 a to cruiser robi bez problema bez potrzeby flashowania
  • #5 3407819
    newchief
    Ocena: 20
    USB-Smart nawet nie ma w opcjach k510i.
    Prosze o jakas sensowna rade i pomoc.
  • #6 3407827
    MoDerato
    Jeżeli telefon nie wstaje po simie a wyskakuje napis Reflesh Main FW to oznacza że albo nie masz zainstalowanej najnowszego Restore albo nie ma Cruiser obsługi twojej wersji wiec albo ściagnij z supportu plik Restore w wersji 1.10 albo wgraj soft i po sprawie telefon wstanie na nogi bez problemu.
  • #7 3407832
    newchief
    Ocena: 20
    Owszem widocznie nie skopiowalem tego..i nie wiem dlaczego tak sie dzieje..Moze powinienem cos jeszcze zaznaczyc lub odznaczyc jakas opcje. Prosze o rady bo zaczyna meczyc mnie to ze po simlocku obowiazkowo flash. :(:cry:
    No nie mialem zainstalowanego najnowszego Restore..wlasnie zaisntalowalem. mam nadzieje ze to pomoze.Dziekuje.. ehhhhh
  • #8 3407967
    tino2003
    Admin grupy GSM
    Ocena: 2088
    Nie bardzo wiesz o czym piszesz, więc nie wprowadzaj ludzi w błąd.
    @newchief ściąg najnowsze restore i musi śmigać, jeszcze nie miałem k750 abym musiał go flashować, jedynie w810 trafił mi sie jeden pod którego nie było RF.
    pozdr
  • #9 3408013
    tekkno
    Ocena: 16
    mam taki sam problem mam najnowszego frimaware
  • #10 3408245
    tomek4321
    Ocena: 9
    witam, wczoraj miałem K750 i simlok poszedł od reki (setool3) dziś miałem takiego samego z tą samą wersją oprogramowania i wywalało - NEW SECIURITY MODEL DETECTED - jak to odblokować?
  • #11 3408265
    newchief
    Ocena: 20
    Zrob dokladnie tak jak pisał tino2003 - sciag z supportu cruisera Restore odpowiadajacy wersji glownego programu.
  • #12 3408278
    tekkno
    Ocena: 16
    mam criusera 10.10 i frimawera 10.10 telefon wlacza sie normalnie puzniej blyska i pozostaje na bialym wyswietlaczu i na zapalonekj klawiaturze, nie mozna go wylaczyc trzeba wyciagnac baterie
  • #13 3408284
    newchief
    Ocena: 20
    Ale telefon po ponownym wlozeniu baterii zyje czy zimny trup?
  • #14 3408298
    tekkno
    Ocena: 16
    a drugi dostalem ubity z CID 36, wgralem mu sterfe bezpieczenistwa, oprograqmowanie , telefon wstal wlacza sie, ale jak przechodzi w ekran startowy,i wyskakuje, please wait, kolory blakna i nic sie niedzieje, telefon moge wyłaczyc normalnie i wlaczyc ktos ma jakis pomysł ??
    zyje normalnie ale, ciaglke to samo
    a dostalem u bitego na amen zero reakcji
  • #15 3408306
    newchief
    Ocena: 20
    To ja Ci juz nie pomoge chyba..jedynie co to sprobuj moze jeszcze raz flasha..
  • #16 3408320
    tekkno
    Ocena: 16
    spoko tylko wiesz moze ktos mnie nakieruje chociaz ;/
    dobra dalem rade
    ten z CID 49 , z CID 36 nadal sie mecze
  • #17 3408761
    fantomas
    Ocena: 6
    panowie jeżeli macie cruisera i ubite 510 i 750 to nie ma byka żeby nim tych telefonów nie postawić wasz problem polega na tym że nie umiecie się nim posługiwać albo jesteście zbyt nerwowi i wydaje sie wam że sprzęt za was wszystko zrobi bez ruszania własną makówką ot co jeżeli ktoś wyrazi życzenie to niech odezwie sie do mnie na priv to postaram się pomóc a teraz tak dla ogółu po pierwsze i najważniejsze przed zabraniem się do roboty należy sprawdzić czy sprzęt którym dysponujemy odsługuje w danym momencie telefon z konkretną wersją oprogramowania i to jest żelazna zasada bez względu czy to eryk czy też inny producent a o tym, idę o zakład, autor pierwszego postu na pewno zapomniał bo gdyby nie , to nie miałby tych problemów a teraz do rzeczy jak postawić cruiserem ubitego 510 bez wzgędu na to jaką wersję softu miał przed awarią
    solucja dotyczy telefonów z CID49 gdzie zabezpieczenie nie jest zdeterminowane jego wartością ani kolorem
    1.proszę postępować dokładnie punkt po punkcie żeby naprawić telefon
    2.bateria full ( doładować ew. z zasilacza laboratoryjnego)
    3.uruchamiamy cruisera
    4.wskazujemy model telefonu ręcznie nie auto (k510i)
    5. klikamy "podłącz telefon" po czym jak w oknie programu wyświetli się
    komunikat "włączanie telefonu" najpierw wkładamy baterię po czym
    wpinamy kabel ( radzę robić to w takiej kolejności jak podałem)
    gdyby komunikacja z telefonem nie powiodła się za pierwszym razem
    trzeba ją powtarzać aż do skutku ( musi zatrybić) acha pamiętać o
    3V na kabel
    6.jeżeli program wykryje telefon najpierw robimy "unlock RSA"
    7.wjmujemy baterię i odłączamy kabel
    8.ponownie podłączamy telefon ( kolejność podłączenia jak wyżej)
    9.flashujemy najpierw Main_FW po czym klikamy na "wyłącz telefon"
    i odpinamy kabel i wyciągamy baterię
    10.podłączamy telefon ( o kolejności nie będę już wspominał myślę że
    każdy już zapamietał)
    11.robimy ponownie "unlockRSA"
    12.odłączamy telefon(bateria i kabel out)
    13.podłączamy telefon
    14. flashujemy Raw_FS przy czym nie zaznaczamy automatycznej
    customizacji(nie zaznaczać "ptaka" przy finalize FS)
    15.klikamy na "odłącz telefon" po czym kabel i bateria out
    16.podłączamy telefon
    17.robimy "unlock RSA" po czym bateria i kabel out z telefonu
    18.podłączamy telefon i robimy ręcznie customizację po jej zakończniu
    ponownie "wyłacz telefon" i bateria oraz kabel out z telefonu
    19.podłączamy telefon i jeszcze raz "unlock RSA" po zakończeniu bateria
    20.podłączamy telefon i robimy "direct unlock"( nie poprzez kody)
    tym razem program po obliczeniu CRC odłączy go sam nam pozostanie
    wyciągnąć baterie i odłaczyć kabel
    21. podłączamy telefon i robimy "restore firmware"
    22.wkładamy kartę sim do telefoniku włączamy go czekamy aż sakrame-
    ntalne"Please Wait" dobiegnie końca i dzwonimy wot wsio
    tak to mniej więcej wyglada potwierdzić to mogą ci którzy wcześniej kontaktowali sie ze mną na priv i po moich wskazówkach nagle ich eryki ożywały a ich zdanie o cruiserze zmieniało się diametralnie
    regards fantomas
  • #18 3408773
    zeezoo
    Ocena: 19
    Sposób na CID49 - sprawdzony, szybki i bezproblemowy:
    1. Instalujesz najnowszą wersję Cruisera
    http://www.mycruiser.org/cruiser/support/inde...ftware_GSM/&file=Cruiser_v10.10_installer.rar
    2. Potem najnowszą FW Restore
    http://www.mycruiser.org/cruiser/support/inde...SM/&file=CruiserFWRestore_v1.10_installer.rar
    3. Następnie ustawiasz odpowiedni model telefonu (dość ważne).
    4. Łączysz się z fonem
    5. Remove RSA
    6. Łączysz ponownie
    7. Direct Unlock
    8. FW Restore
    Telefon musi śmigać...
    zeezoo
  • #19 3409003
    arti123
    Ocena: 96
    tu się zgodzę :) pierwszego ubitego w810 męczyłem ok. 3 godzin, zanim stanął na nogi... grunt to dodatkowe zasilanie na kabel , gdzieś ok 3-4 volt
    potem to tylko już kombinacje z softem.. dokładny opis co i jak jest na elektrodzie, wystarczy poszukać
    edit:
    już wyżej kolega opisał :)
  • #20 3759253
    szatz
    Ocena: 50
    A ja się męcze z trzecim z kolei K510i ( dwa wcześniej oddałem ) i z żadnym za pomocą Cruisera nie mogę złapać komunikacji. Są to nowe aparaty ( ok 1 miesiąca ) z sieci Orange. Próbowałem różnych sztuczek jak wyżej i wciąż brak komunikacji . Telefon widzi kabel - na wyświetlaczu w telefonie pojawia się informacja o podpięciu do komputera ale program nie komunikuje się z telefonem.
    Co robie źle ?
    Czy mimo nowej wersji telefonu powinienem uzyskać z nim komunikacje ?
    Czy Cruiser robi simlock w Każdym K510i ?
  • #21 3759644
    grzyb26
    Ocena: 19
    szatz a podpinasz dodatkowe napięcie 3V pod kabel czy nie??
  • #22 3763556
    szatz
    Ocena: 50
    :arrow: grzyb26 dzięki - brakowało tego napięcia mimo że podpinałem baterie (lekko zaśniedziałe styki w gnieździe baterii dodatkowej 3V były powodem braku komunikacji ). Teraz żadnych problemów .
    Dzięki za pomoc . :D
    Pozdrawiam Szatz.
    Obecnie mam problem z K510i ( 4 miesięczny telefon z sieci ERA CID 49 )
    . Komunikacje mam praktycznie za każdym razem - musze najpierw wcisnąć połącz a potem wkładam wtyczke.
    Odblokowanie RSA poszło bez problemu , w następnym podejściu usunąłem simlocka ( za którymś tam razem ) i na koniec mam problem z opcją RESTORE. Wciąż dostaje komunikat :
    Przełamywanie zabezpieczenia RSA
    Oczekiwanie na wyłączenie telefonu...
    Komunikacja przerwana, wyjmij i włóż baterię
    Błąd odczytu ID podstawowego układu.
    Włącz telefon!
    Bateria naładowana na full , dodatkowe napięcie zmieniałem od 2,8 do 4,2 V bez efektów. Oprogramowanie mam najnowsze jakie jest dostępne na chwile obecną czyli 10.41 a FWRestore 1.10 . Wcześniej już 2 ściągnęłem z podobnym CID49 a ten telefon jest jakiś inny ( komunikacje łapie dopiero przy podpinaniu wtyczki ). Jak to dalej pchnąć ?
    Już poszło za ok. 50 próbą i na ustawieniu AUTODETEKCJA, Dlaczego tak jest ?
✨ Problem dotyczy błędu "FILE NOT FOUND" podczas wykonywania operacji simlocka na telefonach Sony Ericsson K510i i K750i za pomocą programu Cruiser, szczególnie przy próbie wykonania funkcji FW Restore. Użytkownicy zgłaszają, że po odblokowaniu RSA i simlocka telefon wymaga flashowania, ponieważ nie uruchamia się poprawnie. Przyczyną jest najczęściej brak najnowszej wersji FW Restore lub niezgodność wersji oprogramowania z obsługą Cruisera. Zalecane jest pobranie i instalacja najnowszej wersji FW Restore (np. 1.10) oraz najnowszej wersji Cruisera (np. 10.10). W przypadku CID 49 konieczne jest obniżenie CID do 36 lub 29, gdyż nie wszystkie wersje CID są obsługiwane bezpośrednio. Dodatkowo, do poprawnej komunikacji z telefonem często wymagane jest podłączenie dodatkowego napięcia 3V do kabla USB, co rozwiązuje problemy z brakiem komunikacji. Wskazane jest dokładne przestrzeganie kolejności operacji: połączenie z telefonem, usunięcie RSA, ponowne połączenie, odblokowanie simlocka, a następnie FW Restore. W przypadku problemów z uruchomieniem telefonu po simlocku, konieczne jest wykonanie pełnego flashowania oprogramowania. W dyskusji pojawiły się także uwagi, że niektóre modele (np. K300) mają maksymalny CID 36 i nie wymagają flashowania po odblokowaniu. Ogólnie, kluczowe jest stosowanie aktualnego oprogramowania i odpowiednich narzędzi oraz znajomość wersji CID telefonu, aby uniknąć błędów i konieczności ponownego flashowania.
