AXTON C 609 - 5 KANAŁÓWKA - CO MYŚLICIE, KLASYK?? UJDZIE??
Toxias 04 Lut 2007 18:00 3950 3
  • #1 3527925
    Toxias
    http://www.acr.ch/shop/index.php?sid=11706073...223145&itemno=C609&aid=135&cf=itc
    Co myślicie o tym wzmacniaczu ponoć ta firma to klasyk ale czy to prawda??
    Nie znam się ale koniecznie chcę kupić wzmacniacz 5\6 kanałowy, żeby ładnie grał. Czy ten się nadaje cena nie za duża mi pasuje 1000zł??
    C609 5-Channel Amplifier
    5-Channel Amp · 4 x 70 & 170 W @ 4 ohms
    AXTON's C609 5-channel system amplifier supports virtually any configuration - up to and including a full system with front and rear satellites and a subwoofer. 220 watts at 2 ohms for the sub channel is all the power you'll ever need!
    Features
    # premium-quality PWM switched dual power supply with ultra fast MOSFETs for high efficiency and stability
    # A/B power amp circuit with matched BJT transistors (Bipolar Junction Transistors)
    # discrete solid-state power amps
    # operating mode switchable from full-range to high-pass or low-pass mode
    # integrated active crossovers high/low-pass (12 dB/oct.), cutoff frequencies for satellites and subwoofer separately and continuously adjustable from 40 - 240 Hz
    # Subsonicfilter for channel 5 with 20 Hz/12 dB/oct.
    # 3 pairs of RCA inputs (Front, Rear, Sub)
    # soft start and turn-off delay circuit
    # automatic on/off via remote switching from head-units
    # all stereo channel pairs are bridgeable and stable at 2 ohms load
    # input gain adjustable over a very wide range of 0.2 to 9 V for optimal adaptation to all head units
    vencapsulated power and speaker terminals for large cable cross sections
    # fast protection circuits against shorts, thermal overload and d.c. voltage at the speaker outputs
    Technical Data
    Max. Power Output stereo @ 4 ohms
    Rated Power Output stereo @ 4 ohms
    Rated Power Output stereo @ 2 ohms
    Rated Power Output bridged @ 4 ohms
    Frequency Response
    THD @ 4 ohms
    Signal-to-Noise-Ratio
    Channel Separation
    Crossover Slope HP/LP
    Crossover Range HP/LP
    Input Sensitivity
    Input Impedance
    Damping Factor @ 4 ohms
    Thermal Cut-off
    Fuses
    Dimensions (W x H x D)
    4 x 70 & 1 x 170 W
    4 x 50 & 1 x 150 W RMS
    4 x 70 & 1 x 220 W RMS
    2 x 155 & 1 x 150 W RMS
    5 Hz - 30 kHz
    < 0.05 %
    > 95 dB
    > 55 dB
    12/12 dB/Oct.
    40 - 240 Hz
    47 kOhms
    0.2 - 9 V
    > 250
    80° C
    3 x 25 A
    410 x 53 x 256 mm
  • #2 3534416
    slavwek.ie
    Ocena: 127
    witam.
    Wysypałeś cały opis, do tego niekompletny a coś kojarzysz z tego??
    Do napędu 2 zestawów 16,5 i niewielkiego(średniej mocy) subwoofera jest znakomity.
    Jak wzmacniacz ma 5 kanałów, filtry HPF i LPF a dotego subsoniczny, przy czym kosztuje 1kpln to sam sobie odpowiedz..
    dodam że był zwycięzcą testów jakość/cena w swojej klasie.
    pzdr
  • #4 3535512
    crazy_88
    Ocena: 165
    Axton jest to firma z tradycją jest godna uwagi , jakośc jest bardzo wysoka i moim zdaniem warto kupic ten wzmacniacz:)tak na marginesie kolega ma dwukanałówke axtona i gra to bardzo ładnie
