uses crt;
{ $ASMMODE INTEL}
{$i386_intel}
function cpuid_support : boolean;assembler;
Check if the ID-flag can be changed, if changed then CpuID is supported.
Tested under go32v1 and Linux on c6x86 with CpuID enabled and disabled (PFV)
asm
pushf
pushf
pop eax
mov ebx,eax
xor eax,200000h
push eax
popf
pushf
pop eax
popf
and eax,200000h
and ebx,200000h
cmp eax,ebx
setnz al
end;
function cr0 : longint;assembler;
asm
DB 0Fh,20h,0C0h
{ mov eax,cr0
special registers are not allowed in the assembler
parsers }
end;
function cpuidax(par:longword):longword; assembler; asm
mov eax,par
DB 00fh, 0a2h
mov eax,eax
end;
function cpuidbx(par:longword):longword; assembler; asm
mov eax,par
DB 00fh, 0a2h
mov eax,ebx
end;
function cpuidcx(par:longword):longword; assembler; asm
mov eax,par
DB 00fh, 0a2h
mov eax,ecx
end;
function cpuiddx(par:longword):longword; assembler; asm
mov eax,par
DB 00fh, 0a2h
mov eax,edx
end;
function eflags: longword; assembler; asm
pushf
pop eax
end;
CONST
desc:array[0..31] of string=(
// vol2a, table 3-16, page 217/750. EDX(1)
{ 0} 'Floating Point Unit On-Chip.',
{ 1} 'Virtual 8086 Mode Enhancements.',
{ 2} 'Debugging Extensions.',
{ 3} 'Page Size Extension.',
{ 4} 'Time Stamp Counter.',
{ 5} 'Model Specific Registers RDMSR and WRMSR Instructions.',
{ 6} 'Physical Address Extension.',
{ 7} 'Machine Check Exception.',
{ 8} 'CMPXCHG8B Instruction.',
{ 9} 'APIC On-Chip.',
{10} 'Reserved',
{11} 'SYSENTER and SYSEXIT Instructions.',
{12} 'Memory Type Range Registers.',
{13} 'PTE Global Bit.',
{14} 'Machine Check Architecture.',
{15} 'Conditional Move Instructions.',
{16} 'Page Attribute Table.',
{17} '36-Bit Page Size Extension.',
{18} 'Processor Serial Number.',
{19} 'CLFLUSH Instruction.',
{20} 'Reserved',
{21} 'Debug Store.',
{22} 'Thermal Monitor and Software Controlled Clock Facilities.',
{23} 'Intel MMX Technology.',
{24} 'FXSAVE and FXRSTOR Instructions.',
{25} 'SSE.',
{26} 'SSE2.',
{27} 'Self Snoop.',
{28} 'Multi-Threading.',
{29} 'Thermal Monitor.',
{30} 'Reserved',
{31} 'Pending Break Enable.');
procedure cpuid4(par:longword);
begin
writeln(
par:8, #32,
hexstr(cpuidax(par),8), #32,
hexstr(cpuidbx(par),8), #32,
hexstr(cpuidcx(par),8), #32,
hexstr(cpuiddx(par),8), #32);
end;
procedure opis;
var x,i:longword;
begin
writeln('EFLAG ', hexstr(eflags, 8));
writeln('--------.---AX--- ---BX--- ---CX--- ---DX---');
for x:=0 to cpuidax(0) do
cpuid4(x);
x:=cpuidbx(0);
while x>0 do begin
write(char(x mod 256));
x:=x div 256
end;
x:=cpuiddx(0);
while x>0 do begin
x:=x div 256
end;
x:=cpuidcx(0);
while x>0 do begin
x:=x div 256
end;
writeln; writeln;
writeln('------- Supported -------');
x:=cpuiddx(1);
for i:=0 to 31 do begin
if odd(x) then writeln(desc[i]);
x:=x shr 1
end;
writeln;
writeln('----- NOT suported ------');
x:=cpuiddx(1);
if not odd(x) then writeln(desc[i]);
x:=x shr 1
end;
writeln;
end;
function rdtsc:qword; assembler; asm
rdtsc
end;
function GetTickCount : longint; external 'kernel32' name 'GetTickCount';
type pqword=^qword;
function qpc(q: pqword):boolean; external
'kernel32' name 'QueryPerformanceCounter';
function qpf(q: pqword):boolean; external
'kernel32' name 'QueryPerformanceFrequency';
var x,a,cp,ck:longword; p,k,s: qword;
begin writeln;
p:=rdtsc; writeln(p);
opis;
k:=rdtsc; writeln(k);
writeln(k-p);
p:=69;
if qpf(addr(p)) then
writeln('Frequency = ',p/1e6:0:3,' MHz, ',1/p*1e6:20:15, ' uS');
writeln;
s:=0;
for x:=1 to 32 do begin
p:=rdtsc(); cp:=gettickcount();
delay(1000);
k:=rdtsc(); ck:=gettickcount();
s+=k-p;
writeln(k-p:16, ' ticks, ', s div x:12, ' aver, ', ck-cp:8, ' mS (circa)');
end;
writeln;
writeln((s div x) div (ck-cp):10);
cp:=gettickcount(); while gettickcount=cp do;
cp:=gettickcount();
ck:=cp+1000;
p:=rdtsc;
while gettickcount()<ck do
k:=rdtsc;
ck:=gettickcount;
writeln( (k-p)/1e6:0:3, ' milions ticks');
writeln(((k-p) / (ck-cp)*1e3)/1e6 :20:6, ' MHz');
//if cpuiD_support then writeln(hexstr(cr0,8))
end.
