Sony Ericsson K800i CID 52 - mryga ekran po aktualizacji softu, co robić?
gw007 06 Cze 2007 22:39 2588 12
  • #1 3960675
    gw007
    Ocena: 14
    witam mam k800i ktora po wlaczeniu mrygnie i pokaze sie logo SE, a potem mryga na bialo, zrobilem aktualizacjie softu do najwyzszego.
    Telefon pod ladowarka normalnir sie laduje jest logo i nic nie mryga
    v0.91380084/UNI
    Card serial:000*****
    Loaded 51 flash descriptors
    SERVER SUPPORT ENABLED.
    Open COM port OK
    ChipID:9900,EMP protocol:0301
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:35170801100028 CERT:RED
    FLASH CID:52 COLOR:RED
    MAPP CXC article: R1JC002 prgCXC1250210_GENERIC_WI
    MAPP CXC version: R1JC002
    Language Package:CENT_EUROPE
    CDA article: CDA102511/91
    CDA version: R5A
    Default article: cxc1250490
    Default version: R1CB001
    Network LOCKED
    Operator: 260-02
    RESTORATION FILE NOT PRESENT
    YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK
    Elapsed:8 secs.
    Open COM port OK
    Speed:921600
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    Flash ID check:897E
    Flash props sent ok
    phone CID not supported in that mode
    Elapsed:5 secs.
    SERVER CREDITS LEFT/USED: 24/6
    CARD COUNTERS: FLASH 104, UNLOCK 187
    Elapsed:2 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    Elapsed:13 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CDA version: R5A
    Network LOCKED
    Operator: 260-02
    Elapsed:15 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    writing G:\Documents and Settings\GW\Pulpit\k800 52\R1KG001_1250210_GENERIC_WI.ssw
    CURRENT FLASH FILE CID:52
    SSW uses complete hash, hash len is:9200
    Will flash 460 blocks...
    SSW loading returns:0
    writing G:\Documents and Settings\GW\Pulpit\k800 52\R1KG001_FS_CENT_EUROPE_WI_RED_CID52.ssw
    SSW uses complete hash, hash len is:4580
    Will flash 229 blocks...
    CSloader version:
    070125 1328 GENCXC1250562_DB2020_CSLOADER_R3A006
    loader startup: executed
    loader filesystem startup: executed
    loader GDFS startup: executed
    loader unlock: executed
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed:698 secs.
    SERVER CREDITS LEFT/USED: 23/7
    CARD COUNTERS: FLASH 105, UNLOCK 187
    Elapsed:2 secs.
    Elapsed:2 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    MAPP CXC article: R1KG001 prgCXC1250210_GENERIC_WI
    MAPP CXC version: R1KG001
    CDA version: R5A
    Network LOCKED
    Operator: 260-02
    Elapsed:2 secs.
    RECOVERY MODE STARTED
    DB2020 EROM UPGRADE STARTED
    Open COM port OK
    Flash ID check:897E
    Flash props sent ok
    EROM UPGRADE CAN'T FIND QUALIFIED PART
    Elapsed:3 secs.
    Elapsed:3 secs.
    Open COM port OK
    Abort all operations.
    Can't load id loader !
    Elapsed:10 secs.
  • #2 3961201
    yokoon
    Poziom 29  
    Ocena: 144
    Skoro pod ładowarką działa więc sprawdź akumulator, być może uszkodzony. Z tego co wiem to akumulatorki do komórek posiadają
    wewnętrzną elektronikę.
  • #3 3961206
    gw007
    Ocena: 14
    Przed chwila sprawdzilem, nadal to samo.
  • #4 3964734
    gw007
    Ocena: 14
    Dostalem drugi model tez uszkodzony softowo tylko ze zapalil sie nei pokazal loga SE i juz nie mrygal, ale setool go postawil:
    v0.91380084/UNI
    Elapsed:3 secs.
    Elapsed:3 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CDA version: R5A
    Network LOCKED
    Operator: 260-02
    Elapsed:5 secs.
    Elapsed:2 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CDA version: R5A
    Network LOCKED
    Operator: 260-02
    Elapsed:2 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CDA version: R5A
    Network LOCKED
    Operator: 260-02
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed:2 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CSloader version:
    Phone detached
    Elapsed:740 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CDA version: R5A
    Network LOCKED
    Operator: 260-02
    Elapsed:7 secs.
    SERVER CREDITS LEFT/USED: 22/8
    CARD COUNTERS: FLASH 106, UNLOCK 187
    Elapsed:3 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:35399601219091 CERT:RED
    CDA article: CDA102568/2
    CDA version: R5A
    Default version: R1KG001
    Network LOCKED
    Operator: 260-01
    Elapsed:11 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    CSloader version:
    Phone detached
    Elapsed:767 secs.
    Log zawiera odrazu ponowne flaszowanie poprzedniego tel.
  • #5 3964829
    contel
    to masz OTP LOCKED:1 CID:49 wiec spokojniego go możesz fleszować do CID 49 lub cid 51
  • #6 3964939
    gw007
    Ocena: 14
    a ma kros może sofcik CD z cid 49 bo na suporcie nie ma tam softu z pl
    Próbowałem teraz wgrać soft z cid 49 bez pl i jest błąd:
    Elapsed:2 secs.
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    writing G:\Documents and Settings\GW\Pulpit\SUPPORT\k800\k800_R1EG001_1250210_GENERIC_WI.ssw.cry
    CURRENT FLASH FILE CID:49
    SSW uses complete hash, hash len is:9100
    HDR block not accepted,error:19
    Elapsed:25 secs.
  • #7 3964987
    contel
    ale napisałem Ci ze najniżej mozesz zejsc do CID 49 a nie 29
  • #8 3965002
    gw007
    Ocena: 14
    Nie ma 29 w db2020:) już poprawiłem literówke:)
  • #9 3965016
    contel
    bardzo chetnie bym ci udzielił flesza ale mam cruisera a nie wiem czy pasują do setoola
  • #10 3965070
    gw007
    Ocena: 14
    Nie pasują:) nigdy nie robiłem db2020 cruiserem możesz mnie krok po kroku przeprowadzić? Pobrałem:
    K800i_CXC1250210_Generic_R1KG001_Red52.ck80sw
    K800i_CXC1250490_CentEurope_R1KG001_Red52.ck80fs
  • #11 3965127
    komismaja
    Ocena: 25
    attach phone
    flash main K800i_CXC1250210_Generic_R1KG001_Red52.ck80sw
    flash raw fs K800i_CXC1250490_CentEurope_R1KG001_Red52.ck80fs
    Customize fs (musisz miec logi) ustaw k800i central europe i wpisze obok wersje softu jaka wgrywasz czyli R1KG001 no i customize
    to wszytsko jakby cos nie tak wklej loga z cruisera
  • #12 3965234
    gw007
    Ocena: 14
    System diagnostics passed.
    Wersja 11.02 gotowa!
    Połączenie przez UC-10 Universal Cable...
    Connecting to server...
    Connection established, checking server status...
    Server version: 2.08
    Retrieving credit info...
    Your ID: user_*****
    Credit: 7
    Czas: 00:00:01
    [ --- Attach to Phone --- ]
    Włączanie telefonu...
    ID podstawowego układu: 0x9900
    Wersja protokołu: 3.1
    Prędkość = 460800Bd
    Booting via ROM...
    Trying CID52 recovery applet...
    Wysyłanie prologu apletu...
    Wysyłanie struktury apletu...
    Czas wejścia bootstrap: 2s
    Inicjalizacja telefonu...
    Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_...
    Flash fabryczny: Intel
    Flash ID: 0x897E
    Poziom zabezpiecznia OTP: 1 (Retail)
    OTP CID: 49
    CID telefonu: 52
    Kolor telefonu: Red
    Wysyłanie apletu...
    Applet ID: 061205 1523 HANCXC9876543210_DB2020...
    Wysyłanie apletu...
    Applet ID: 061201 1314 HANCXC1329129_DB2020_FL...
    RSA protection state cannot be determined for this CID.
    Inicjalizacja telefonu zakończona.
    [ --- Flash Main Firmware --- ]
    Plik flash'a: "K800i_CXC1250210_Generic_R1KG001_Red52.ck80sw"
    Oczekiwanie na wczytanie pliku flash'a...
    Przygotowanie do programowania flash'a...
    Prędkość = 921600Bd
    The applet ignored baudrate change request!
    Programowanie flash'a...
    Czas: 00:11:46
    Zapis flash'a zakończony
    [ --- Flash Raw File System --- ]
    Plik flash'a: "K800i_CXC1250490_CentEurope_R1KG001_Red52.ck80fs"
    Prędkość = 921600Bd
    Czas: 00:05:54
    [ --- Customize File System --- ]
    Wysyłanie apletu CS...
    Błąd!
    Prędkość = 921600Bd
    Błąd!
    [ --- Turn off Phone --- ]
    Wyłączanie telefonu...
    [ --- Detach Phone --- ]
    Terminating threads...
    Wszystkie zadania zatrzymane.
    Telefon automatycznie odłączony.
    Your ID: user_*********
    Credit: 7
    Czas: 00:00:01
    Prędkość = 460800Bd
    Booting via ROM...
    Flash ID: 0x897E
    OTP CID: 49
    CID telefonu: 52
    Kolor telefonu: Red
    Wysyłanie apletu...
    Wysyłanie apletu...
    Prędkość = 921600Bd
    Czas: 00:05:52
    Applet ID: 070125 1328 GENCXC1250562_DB2020_CS...
    Inicjalizacja apletu CS...
    Prędkość = 921600Bd
    Uruchamianie usług GDFS...
    Uruchamianie systemu plików, proszę czekać...
    Generating witness...
    Number of preceding users: 0
    Credit: 7
    Received successfully.
    Calculating unlock data...
    Czas: 00:00:04
    Tworzenie kustomizacji...
    Modyfikacja telefonu...
    Gotowe.
    Zapis ciągu CDA MS Article...
    New value: CDA102568/2
    Gotowe.
    Zapis ciągu CDA MS Wersja...
    New value: R7A
    Gotowe.
    Zapisywanie domyślnego ciągu Article MS
    New value: cxc1250490
    Gotowe.
    Zapisywanie domyślnego ciągu Wersja MS
    New value: R1KG001
    Gotowe.
    Zapisywanie ciągu pakietu językowego...
    New value: CENT_EUROPE
    Gotowe.
    Writing country...
    New value: Generic Trade
    Gotowe.
    Your ID: user_****
    Credit: 6
    Czas: 00:00:01
    TELEFON NADAL NIE DZIALA
  • #13 3969991
    gw007
    Ocena: 14
    Widzę, że nikt nie ma pomysłu na postawienie tego SE.
    Oddam go na gwarancje, ale czy po aktualizacji softu na stronie SE uznadza ją?
✨ Sony Ericsson K800i po aktualizacji oprogramowania do najnowszej wersji (CID 52) uruchamia się, pokazując logo SE, a następnie ekran miga na biało. Telefon ładuje się normalnie pod ładowarką, jednak nie przechodzi do pełnego startu. W logach serwera i narzędzi serwisowych widoczny jest konflikt CID telefonu (52) z OTP LOCKED na poziomie 1 i CID 49, co uniemożliwia bezpośrednie wgranie softu z CID 49 z powodu błędu HDR block not accepted (error 19). Użytkownik próbował pełnego flashowania za pomocą narzędzia DB2020 i Setool, jednak bez powodzenia. Wskazano, że najniższy możliwy CID do flashowania to 49, a nie 29. Próby użycia softu z CID 49 bez polskiej wersji językowej kończyły się błędami. W dyskusji pojawiła się sugestia sprawdzenia akumulatora, jednak problem pozostał. Użytkownik posiada pliki firmware K800i_CXC1250210_Generic_R1KG001_Red52.ck80sw oraz K800i_CXC1250490_CentEurope_R1KG001_Red52.ck80fs i prosi o instrukcję krok po kroku do flashowania. Ostatecznie brak jest rozwiązania, a użytkownik rozważa oddanie telefonu na gwarancję, zastanawiając się, czy aktualizacja softu na stronie SE nie wpłynie na jej uznanie.
