Audi A6 2004 3Lv6 - Jak podłączyć alarm bez CAN? Szukam rozpiski połączeń
szym10 15 Lip 2007 20:28 3205 6
  • #1 4084575
    szym10
    Ocena: 38
    Moze ktorys z kolegow ma rozpiske podlaczenia
    autoalarmu do tej bryki, alarm bez CAN.
    carrier
    Specjalista - Alarmy Samochodowe
    Ocena: 1054
    poszło na PW
  • #3 4085103
    szym10
    Ocena: 38
    ok Z ogromnym podziekowaniem :)
    Nie oddam nikomu ;)
    Temat zamkniety.
  • #4 5484228
    oloz
    Odświeżę może temat . Czy by też można było prosić kolegów o schemat podłączeń alarmu bez can do A6 2005 3.0 TDI
  • #5 5484497
    carrier
    Ocena: 1054
    2005 -2007 Audi A6 Wiring
    Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2005 -2007 Audi A6 . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections. More information on using a multimeter and testing wires please see our Technical Support Area.
    PART COLOR LOCATION
    12 VOLT CONSTANT RED/WHITE (+) IGNITION SWITCH HARNESS
    STARTER RED/BLACK (+) IGNITION SWITCH HARNESS
    STARTER 2 N/A N/A
    IGNITION 1 BLUE (+) IGNITION SWITCH HARNESS
    IGNITION 2 VIOLET (+) IGNITION SWITCH HARNESS
    IGNITION 3 N/A N/A
    ACCESSORY/HEATER BLOWER 1 YELLOW/BLACK (+) IGNITION SWITCH HARNESS
    ACCESSORY/HEATER BLOWER 2 N/A N/A
    KEYSENSE N/A N/A
    PARKING LIGHTS ( - ) N/A N/A
    PARKING LIGHTS ( + ) GRAY/WHITE (+) BEHIND LIGHT SWITCH
    POWER LOCK GREEN/BLUE (-) TYPE IN DRIVERS KICK PANEL
    POWER UNLOCK BROWN/YELLOW (-) TYPE IN DRIVERS KICK PANEL
    DOOR TRIGGER RED/YELLOW (-) IN DRIVERS KICK PANEL
    DOMELIGHT SUPERVISION USE DOOR TRIGGER
    TRUNK RELEASE N/A N/A
    SLIDING POWER DOOR N/A N/A
    HORN N/A N/A
    TACH GRAY/GREEN AT IGNITION COIL
    WAIT TO START LIGHT N/A N/A
    BRAKE RED/BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
    FACTORY ALARM DISARM N/A N/A
    ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
  • #6 5484711
    oloz
    :) dziękuje za szybką odpowiedź
  • #7 5488043
    oloz
    carrier napisał:
    PART COLOR LOCATION
    STARTER 2 N/A N/A
    IGNITION 3 N/A N/A
    KEYSENSE N/A N/A
    HORN N/A N/A
    Niestety nie pasuje mi ta rozpiska do auta :( tak jak by były to zupełnie inne auta, a kolory bardzo mi przypominają A6 ale to z 1998 roku .
Dyskusja dotyczy podłączenia alarmu bez magistrali CAN w Audi A6 z 2004 roku, silnik 3.0 V6. Autor poszukiwał schematu połączeń elektrycznych do instalacji alarmu w tym modelu. Jeden z uczestników przesłał schemat na prywatną wiadomość, co zostało potwierdzone i temat uznano za zamknięty. Pojawiła się również prośba o podobny schemat dla Audi A6 2005 3.0 TDI, wraz z udostępnioną rozpiska przewodów dla modeli 2005-2007, zawierająca kolory i lokalizacje przewodów w wiązce stacyjki (np. 12V stałe, starter, zapłon, akcesoria, światła postojowe). Jednak schemat ten nie pasował do auta z 2004 roku, a kolory przewodów przypominały starszy model Audi A6 z 1998 roku. Wskazuje to na różnice w instalacji elektrycznej między rocznikami i konieczność poszukiwania dokładnej dokumentacji dla konkretnego modelu i rocznika.
