Toshiba Satellite A15-S129 - błąd IDE 1 przy wymianie napędu CD, co robić?
RZezniol 27 Lip 2007 18:41 3024 3
  • #1 4120412
    RZezniol
    Ocena: 23
    Witam !!
    Toshiba jak w temacie ...
    Chce podmienic w niej naped CD i robi problemy
    IDE 1 ERROR
    Nic nie daje kombinacja z pinami 45 i 47.
    Naped na 100% sprawny bo chodzi w moim prywatnym lapie bez zastrzezen.
    MA ktos jakies pomysły na ten sprzęt ??
    Pozdro RZezniol
  • #2 4120443
    jarewa
    Ocena: 511
    Może by kolega napisał jakiej firmy i model napędu? To coś bym doradził.
    To jest komentarz producenta-
    Comments :
    Q. My new slimline drive is not detected by my notebook or: I get an IDE #1 (or other numbers) error
    A. Background information: All Toshiba slim line drives work in cable select mode (CSEL) by default. This means, the drive gets a signal from the laptop telling it if it has to act as master or as slave device on the IDE channel.
    Some laptop computers in the market do not work according to this specification, but use the CSEL signal in an inverted manner to save a little bit of electric current. If you install a drive running in standard CSEL mode in such a laptop, the inverted signal will force it to work in the wrong master/slave mode giving the drive the same logical address as the hard disk drive installed on the same IDE channel. As a result, either the HDD or the optical drive, or both may not be detected by the BIOS and will not be usable. Some notebooks might show an error message on start-up, e.g. "IDE #1 error" or similar.
    Solution: The drive needs a special firmware version that can deal with the inverted CSEL signal. To avoid this special firmware being installed by mistake, we do not offer it as download from our website, but send it to customers on a case by case basis. To receive the special firmware version for your drive, please fill in the contact form on this website, or send an email to our hotline team with the following information: Exact model number, current firmware, problem description, your email address (for sending the necessary files).
  • #3 4120485
    RZezniol
    Ocena: 23
    słowem musze znaleźć odpowiedni firmware do mojego napędu ... nie wiem czy chce sie bawic w aktualizowanie firmware bo jak cos nie pyrknie i nie ebde miał mozliwości cofniecia zmian bo mi nie wykryje napędu u mnie w lapie ;) to bedzie zima ...
    Ciekawe jest to ze jak podlacze sam naped bez dysu to komunikat pozostaje mimo ze nie ma mozliwości istnienia konfliktu.
    zaraz zdemontuje moj naped i zobacze co to za model
    Pozdfro RZezniol[/url]
  • #4 4121658
    mrx
    Ocena: 7
    o jakich kombinacjach piszesz ?
    45 lub 47 do masy ?
    Próbowałeś odłączyć 47 od płyty lub z gniazda ?
