Sony Ericsson K310 - problem z flashowaniem i simlockiem po użyciu Setool
tomek4321 16 Paź 2007 12:39 1971 6
  • #1 4383765
    tomek4321
    Ocena: 9
    Trafił do mnie k310 na którego nie przychodziły sms-y. Postanowiłem go sfleszować i tu pojawił sie problem. Setool zaczął i już nie skończył...
    Open COM port OK
    ChipID:8040,EMP protocol:0301
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:49
    Speed:460800
    OTP LOCKED:1 CID:49 PAF:1 IMEI:3537---------- CERT:RED
    ldr_on_ldr hdr no ack,err:10
    mempatcher fails to load
    Elapsed:18 secs.
    Open COM port OK
    Speed:460800
    PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
    can't load loader
    Elapsed:14 secs.
    udało mi sie raz go flesznąć gdfs-em z programu i wstał ale teraz ma simloka i za nic nie moge sie go pozbyć - log:
    Loaded 51 flash descriptors
    Open COM port OK
    Speed:230400
    OTP LOCKED:1 CID:49 PAF:1 IMEI:3537------------- CERT:RED
    LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Open COM port OK
    Speed:230400
    Trying to launch embedded bootloader...
    Embedded flashloader:
    COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
    Flash ID check:897E
    Flash props sent ok
    FOUND: R4EA031_CXC1250466_GENERIC_DO
    Restore from:R4EA031_CXC1250466_GENERIC_DO
    writing D:\Gsm\Setool3\Program\96\gdfs_in_ssw_format\k310_gdfs_in_ssw_format.ssw
    CURRENT FLASH FILE CID:254
    SSW uses dynamic hash, dynamic hash len is:32
    Will flash 32 blocks...
    SSW loading returns:0
    CSloader version:
    COMPACT_SEMC_FS_LOADER_SETOOL2_V26
    loader startup: executed
    loader filesystem startup: executed
    loader GDFS startup: executed
    loader unlock: executed
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed:306 secs.
  • #2 4383820
    Artech
    Ocena: 48
    bateria naładowane
    , zaznaczałes opcje do full unlock , co chcesz teraz zrobic unlocka???
  • #3 4383922
    tomek4321
    Ocena: 9
    jak już sie całkowicie postawił to postanowiłem go jednak flesznąć i wysypał się w połowie fleszowania. Teraz nic już nie idzie zrobić (bateria naładowana) i juz tylko to sie dzieje:
    Open COM port OK
    Speed:230400
    OTP LOCKED:1 CID:49 PAF:1 IMEI:35378 CERT:RED
    THEN PRESS "READY"
    Open COM port OK
    Speed:230400
    Flash ID check:897E
    Flash props sent ok
    writing C:\Documents and Settings\Tomek\Pulpit\R4EA031_1250466_GENERIC_DO.ssw.cry
    CURRENT FLASH FILE CID:49
    SSW uses dynamic hash, dynamic hash len is:304
    Will flash 304 blocks...
    Send superblock command NAK
    Elapsed:511 secs.
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    Elapsed:245 secs.
    Open COM port OK
    Speed:921600
    OTP LOCKED:1 CID:49 PAF:1 IMEI:353 CERT:RED
    THEN PRESS "READY"
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    Elapsed:187 secs.
    Open COM port OK
    Speed:230400
    THEN PRESS "READY"
    Open COM port OK
    Speed:230400
    Flash ID check:897E
    Flash props sent ok
    Nothing found,use manual selection
    writing D:\Gsm\Setool3\Program\96\gdfs_in_ssw_format\k310_gdfs_in_ssw_format_v0.ssw
    Elapsed:117 secs.
    Open COM port OK
    Speed:230400
    OTP LOCKED:1 CID:49 PAF:1 IMEI:3537 CERT:RED
    can't load loader
    Elapsed:14 secs.
    Open COM port OK
    Speed:230400
    fout_ssw hdr BAD:AA
    prepare failed,that is FATAL
    Elapsed:55 secs.
  • #4 4383953
    Artech
    Ocena: 48
    to jak raz ci sie zfleszował to musi pójsc drugi raz kombinowałes z predkością??,
  • #5 4383979
    tomek4321
    Ocena: 9
    no tak, ale sfleszował mi gdfs a głównego flesza nie (na głównym się wywalił i tak mu zostało) nic teraz nie idzie tylko wywala
    prędkości przetestowane wszystkie...
    z tego co się zorientowałem to usterka ponoć sprzętowa - wie ktoś co to może być?
    The phone has hardware problems and sooner or later would die
    Originally Posted by the_laser
    if you got once message
    "ldr_on_ldr hdr no ack,err:00
    phone will return to you surely. later or sooner.
  • #7 4389435
    tomek4321
    Ocena: 9
    po ok 20 razach fleszowania wkońcu dobrnął do końca (bo tak to non stop przerywał w różnych momentach) i działa, problem z odbieraniem wiadomości nadak pozostał. Nie zamierzam jednak już więcej nic z nim robić....
✨ Sony Ericsson K310 miał problem z odbieraniem SMS-ów, co skłoniło do próby flashowania urządzenia za pomocą Setool. Proces flashowania przerywał się z błędami takimi jak "ldr_on_ldr hdr no ack, err:10" oraz "mempatcher fails to load". Próby zmiany prędkości transmisji nie przyniosły efektu. Po wielokrotnych próbach flashowania, w tym użyciu pliku GDFS, telefon udało się uruchomić, jednak pojawił się simlock, którego nie można było usunąć. Wskazywano na możliwą usterkę sprzętową telefonu, co potwierdzały komunikaty o błędach bootloadera i flashloadera. Zalecano wykonanie recovery i flashowanie na najwolniejszej prędkości z użyciem innego pliku flasha. Ostatecznie po około 20 próbach flashowania proces zakończył się sukcesem, ale problem z odbieraniem wiadomości pozostał, a dalsze ingerencje zostały zaniechane.
