HP LJ 2420 - co oznaczają błędy 52.00 i 59.9?
norb86 15 Lis 2007 11:00 2679 2
  • #1 4483178
    norb86
    Ocena: 8
    Mam 2 oddzielne błędy:
    1. 52.00 - jest to jakiś błąd kasety ale czy ktoś wie coś więcej?
    2. 59.9 - ?
  • #2 4483515
    hefid
    Spoczywaj w Pokoju
    Ocena: 6170
    Przeniosłem z: Schematu/instrukcji…
    Kazik
    Spec od drukarek
    Ocena: 53
    Error 52.xx:
    1. Press the SELECT ( ) button
    to continue.
    2. Turn the printer off, and then
    turn the printer on again.
    3. Reseat the connectors
    between the laser/scanner
    and ECU (J83 and J84).
    4. Replace the laser/scanner
    assembly (see Laser/scanner.
    5. Replace the ECU (see ECU).
    Error 59.xx:
    59.00, 59.10, 59.20 Motor failure
    1. Turn the printer off, and then
    2. Reconnect the main-motor
    wire-harness on the ECU
    3. Replace the gear assembly
    (see Gear assembly.
    4. Replace the ECU (see ECU).
    59.A or 59.4 EP Motor failure
    2. Reconnect the EP-motor wireharness
    on the ECU.
    (see Gear assembly.
