Witam mam K550i z takim problemem
v0.914014/UNI
Card serial:
Loaded 51 flash descriptors
SERVER SUPPORT ENABLED.
ALTERNATIVE SECURITY BYPASS ENABLED.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:51
Speed:115200
OTP LOCKED:1 CID:51 PAF:1 IMEI:35601xxxxxxxx CERT:RED
FLASH CID:51 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:2019
Flash props sent ok
bypassing DB2020 security...
done,restarting...
Speed:115200
Trying to launch embedded bootloader...
Embedded flashloader:
DB2020_PRELOADER_FOR_SETOOL2
Flash ID check:2019
Flash props sent ok
Restore from:F:\se tool\rest\R1JD001_CXC1250669_GENERIC_LI
full sig complete.
USERCODE RESET TO "0000"
Searching...
Firmware lock check determined.
loader startup: executed
CSloader refused to start GDFS services,error is:29
loader GDFS startup failed, that is fatal
Elapsed:49 secs.
Przy zczytaniu
v0.914014/UNI
Card serial:000xxxxxx
Speed:115200
Flash ID check:2019
Flash props sent ok
OTP LOCKED:1 CID:51 PAF:1 IMEI:3560xxxxxxxxx CERT:RED
set_gdfs_props failed, exiting
Elapsed:5 secs.
pliki:
K550i_CXC1250671_CentEurope_R1JD001_Red51.ck55fs
CDA1025682_K550_Gen_CENT_EUROPE.cus
K550i_CXC1250669_Generic_R1JD001_Red51.ck55sw
Jakies sugestie ?
v0.914014/UNI
Card serial:
Speed:115200
Flash ID check:2019
Flash props sent ok
done,restarting...
Speed:115200
Flash ID check:2019
Flash props sent ok
full sig complete.
Searching...
Elapsed:49 secs.
Przy zczytaniu
v0.914014/UNI
Speed:115200
Flash ID check:2019
Flash props sent ok
Elapsed:5 secs.
pliki:
Jakies sugestie ?
