witam trafiła do mnie nokia 7373 z uwalonymi certyfikatami:
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Zleciłem przeliczenie ASK-a na RPL, wgrywałem go 2ma metodami poniżej manuale:
SOLUTION FOR THIS Problem :
CONFIG Key : FFFFFFFFFFFFF
1. make ask file using BB5 Reader v1.1
a. open BB5 Reader v1.1
b. connect phone using dku-2
c. select phone generic
d. click connect
e. read phone
f. make ask
g. remember where you save the ask file
2. open your ask>rpl account and login
3. click files and wait page to open
4. click browse and select the ask file you make then click send
5. you will see your ask file at the ask file list and credit will minus
6. wait for 15 minutes or more, depending on nokia server if busy
7. if you see rpl file at rpl list,click to download
8. now use JAF to write rpl file using f-bus cable
9. you need to write full PM using sx4 then click write PM
3. if all is normal then unlock phone
write rpl instructions:
1. open JAF select BB5 tab
2. click inf
3. then click CRT tools
4 select write rpl(remove the checks JAF and Plain rpl using JAF 1.98.27)
5. select the rpl for the phone
6 then click write rpl
7. once DONE! close crt tools
8. then write PM using sx4 :
a. check sx4 and click service button
b. when DONE check write PM(must show ok always)
C. remember = Phone must be in local or test mode
d. if phone cannot local or test mode, do full format using file sys format
e. click inf if done.
ORAZ:
1- connect phone and open JAF latest exe
2- select File Sys Format and make service
3- when phone goes to test mode you will see a file system Format new window, cancel this window
4- Open CRT Tool and uncheck JAF Format and write BB5 RPL your received from us
w obu przypadkach po zczytaniu telefonu (na końcu odbudowy certyfikatów) wszystko wygląda jak należy, jednak gdy włoże karte telefon wraca do stanu pierwotnego z uwalonymi certyfikatami.
pytanie 1) co może być przyczyną niepowodzenia?
pytanie 2) jako PM wgrywam PM308? bo tak robie
pytanie 3) czy ma znaczenie przy jakiej ver softu był zczytywany ASK
i przy jakiej jest wgrywany, czy musi być to ta sama ver czy
nie ma to znaczenia
LOCK STATUS:
Block 1:
d. click connect
e. read phone
f. make ask
2. click inf
ORAZ:
nie ma to znaczenia
