zrobiłem downograde i nadal to samo gdzie przyczyna prosze o porady
Connecting to BB5 Box ...
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-133
Version: V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia.
IMEI:
SP LOCK status:
Config Key: 2343000000000000
Block 1: CLOSED Type 5 Data: 23430F
Block 2: CLOSED Type 5 Data: 23430F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-133__Locked_Keycnt_0_Fbuscnt_0__V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-133_359568015968418_Locked_Keycnt_0_Fbuscnt_0__V_05wk47v28.1_22-06-06_RM-133_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
Unlock fail. Please try again.
Type: RM-133
IMEI:
SP LOCK status:
Reset phone ...
Autobackup file:
already exist
Reset phone ...
SP LOCK status:
Unlocking phone ...
Try number: 1
Response byte: 08
Try number: 2
Response byte: 08
Try number: 3
Response byte: 08
Try number: 4
Response byte: 08
Try number: 5
Response byte: 08
Try number: 6
Response byte: 08
Try number: 7
Response byte: 08
Try number: 8
Response byte: 08
Try number: 9
Response byte: 08
Try number: 10
Response byte: 08
