Nokia 5500 - problem z JAF po nieudanym downgrade przez USB
Mustangoo 17 Kwi 2008 12:44 1793 12
  • #1 5040084
    Mustangoo
    Ocena: 6
    Robilem downgrade 5500 pod jafem po usb (nie poraz pierwszy robie ten telefon). Cala procedura bez problemowo przeszla, prawie cala. Na koniec kiedy jest pooling phone wyskoczyla lipa.
    Backing up CRT...
    Detected P-KEY: 90007604
    P-key nokia module version 01.01
    Init usb communication...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\xxxxxxxxxxxx_CRT_backup_1019174.pm
    Done!
    Backup CRT OK!
    Preparing for downgrade...
    Detected P-KEY: xxxxx
    Phone ready for downgrade!
    Searching for phone...Detected P-KEY: xxxx
    Found
    Reading SW version... 04.40 04.40
    Reading battery value...4003 mV
    Init usb flashing...
    Reading flashid... 128k flash detected.
    CMT: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD
    APE: 00000000 <=> Flash -> not detected
    Verifing ADL communication... Status byte 2
    ADL->Loader: Update Application Loader -> Single Chip
    Loader len: 204672, CHK: 0xF20C
    ADL -> Sending loader...
    Waiting for the phone to boot...
    Searching phone...Found!
    Status byte: 04
    Phone is in flash mode...
    CMT blocks: 3239, APE blocks: 0
    Erasing cmt...
    Send CMT CFG...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-86\rm86_03.55_prod_core.fpsx...
    Erasing cmt zone 002F0000 - 01F3FFFF ...
    Erasing cmt zone 056FF000 - 05EEFFFF ...
    Erasing cmt zone 04800000 - 0480FFFF ...
    Erasing cmt zone 00000000 - 002EFFFF ...
    Erasing cmt zone 01F40000 - 01F7FFFF ...
    Erasing cmt zone 01FA0000 - 01FDFFFF ...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-86\rm86_03.55_prod_variant_74_voda_uk.fpsx...
    Erasing cmt zone 04800000 - 0532FFFF ...
    Writing cmt...
    Sending CMT HASH for MCUSW
    Sending CMT HASH for SOS+CORE1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PMM_CONF
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    Sending CMT HASH for DSP0
    Sending CMT HASH for SOS+ISASW
    Sending CMT HASH for PASUBTOC
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for SOS+EXT0
    Rebooting...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    Phone not found...
    DCT4/BB5 counter: 472
    Done!
    Od tej pory po fbusie nie wykrywa jej, nie wykrywa rowniez jako death usb. Reczny flash nie wchodzi, a telefon jak sie wlacza wisi na bialym ekranie. Smierdzi mi to ask--> rpl, ale moze ktos z was wie jak to swinstwo postawic??
    dzieki z gory
  • #2 5040107
    dickheadGSM
    Ocena: 37
    Kopytkiem powino sie udac. (7 pin)
  • #3 5040137
    Mustangoo
    Ocena: 6
    Tak myslalem ale nie smiga...rezystor w linii BSI jest, miedzy BSI i graoundem R68k tez jest a phone dalej nic...
  • #4 5040149
    dickheadGSM
    Ocena: 37
    Jak nie smiga, nie zrobi CHECKA ??
    Odznacz bk crt i bk pm308 i laduj soft wyzszy na sile. Musi wstac.
  • #5 5040266
    Mustangoo
    Ocena: 6
    Check jest ok. Powiedzcie mi prosze , co oznacza "wrong file id 3C"??
  • #6 5040302
    matezzz
    Ocena: 6
    gdzie dokładnie taki komunikat wystepuje?
    możesz wrzucisz cały log?
  • #7 5040390
    Mustangoo
    Ocena: 6
    Komunikat taki wystepuje przy probie podania recznego pliku - manual flash czy cos takiego...mozliwe ze zle podaje plik ale malo prawdopodobne, dlatego pytam co to za dziwactwo??
  • #8 5040397
    matezzz
    Ocena: 6
    użyj opcji
    'manual flash', później 'use ini', wybierz model z listy, wybierz pc, i powinno być ok, jeśli nie jest to zainstaluj może inną paczke.
  • #9 5046749
    Mustangoo
    Ocena: 6
    Flash wreszcie poszedl (tak jak mowil kolega matezzz), problem jednak w tym ze telefon wisi na logo nokia - wiec mam fajna latarke z logo nokii na ekranie ;)
    Wedlug mnie teraz nie ma innego wyjscia jak tylko ask-rpl. A moze sie myle??
  • #10 5046823
    matezzz
    Ocena: 6
    z tego co widze, to przy pierwszym flaszowwaniu zrobiło ci backup rpl i pm.
    w takim razie wrzuć jej erase flash, później flasz, i zobacz czy sie odpali
  • #11 5050234
    dickheadGSM
    Ocena: 37
    Ale pm zrobil tylko 308 wiec erase, flash, rpl, sx4 i full pm, pm308.
    Chyba ze wgrales nizsza niz byla to wgraj najwyzsza mozliwa.
    Jak nie wstanie dograj rpl i pm308. Ewentualne jak wyzej.
  • #12 5052819
    Mustangoo
    Ocena: 6
    A czy macie moze wersje 4.40?? Z suportu udalo mi sie sciagnac 4.03 i nic wyzej. Bede wdzieczny.
✨ Podczas próby downgrade'u telefonu Nokia 5500 za pomocą programu JAF przez USB, proces przebiegał prawidłowo aż do etapu "pooling phone", gdzie pojawił się problem z komunikacją ADL. Wystąpił błąd "wrong file id 3C" przy ręcznym podawaniu pliku podczas manual flash, co sugerowało nieprawidłowy plik lub konfigurację. Zalecano użycie opcji "manual flash" z wyborem modelu i pliku ini oraz ewentualną zmianę paczki oprogramowania. Po udanym flashowaniu telefon zawieszał się na logo Nokia, co wskazywało na konieczność wykonania operacji ask-rpl lub pełnego flasha z erase flash, rpl, pm308 i sx4. Wskazano także, że jeśli wgrano niższą wersję oprogramowania, należy wgrać najwyższą dostępną wersję. Użytkownik poszukiwał wersji firmware 4.40, którą otrzymał z linku do serwisu blue-nokia.com. W dyskusji pojawiły się także uwagi dotyczące linii BSI i rezystora R68k, które były sprawdzane w kontekście problemów z komunikacją.
