Nokia 6280 - nieudany downgrade, telefon nie reaguje po próbie flashowania
quiter1979 07 Sie 2008 21:53 1756 7
  • #1 5418631
    quiter1979
    Boot...
    rap3gv3_2nd.fg
    RAP3Gv3_algo.fg
    Erase RAP3 [00000000 - 000202BF]
    Erase RAP3 [00020300 - 000252FF]
    Erase RAP3 [00020000 - 0007FFFF]
    Erase RAP3 [00080000 - 000DFFFF]
    Erase RAP3 [00200000 - 0037FFFF]
    Erase RAP3 [00380000 - 011DDFFF]
    Erase RAP3 [011DE000 - 011DEFFF]
    Erase RAP3 [011DF000 - 011DFFFF]
    Erase RAP3 [00100000 - 001FFFFF]
    Erase[17.77 MB]...
    Waiting response for 320 Sec...in 0.69s
    Flash[15.93 MB]...in 31.16s
    * * Processed file in 40.83 seconds
    Processing File: rm7830006.43.image_c
    Low level format...fail
    Boot...
    rap3gv3_2nd.fg
    RAP3Gv3_algo.fg
    Erase RAP3 [016E0000 - 01FDFFFF]
    Erase[9.00 MB]...
    Waiting response for 320 Sec...in 0.47s
    Flash[2.75 MB]...in 5.52s
    * * Processed file in 65.24 seconds
    Extract content...fail
    Processing File: rm783006.43.ppm_c
    Boot...
    FAILED TO BOOT PHONE!!!
    Make sure that phone is connected.
    Processing File: rm7830006.430.mcusw
    Boot...
    Boot...
    Boot...
    Boot...
    Boot...
    Boot...
    rap3gv3_2nd.fg
    RAP3Gv3_algo.fg
    Erase[17.77 MB]...
    Waiting response for 320 Sec...in 0.19s
    Flash[15.93 MB]...in 31.14s
    * * Processed file in 40.27 seconds
    Boot...
    rap3gv3_2nd.fg
    RAP3Gv3_algo.fg
    Erase[9.00 MB]...
    Flash[2.75 MB]...in 5.44s
    * * Processed file in 64.89 seconds
    Boot...
    rap3gv3_2nd.fg
    RAP3Gv3_algo.fg
    Erase RAP3 [011E0000 - 016DFFFF]
    Erase[5.00 MB]...
    Waiting response for 320 Sec...in 0.31s
    Flash[4.00 MB]...in 7.92s
    * * Processed file in 17.13 seconds
    * * * Phone flashing done in 3:25 minutes
    Post Flash serial tunning of phone....
    Pooling mode for full factory set...
    Phone not responding, try to set manually!
    jalies sugestie?jak to postawić?
    dodam,że dead usb jaf próbowane,a to wyrzej to log z 7pinowego kabelka i mt-boxa,po 10pinówce jeszcze gorzej tylko nie jestem pewien,czy zaznaczam wszystko w opcjach
    MTBOX: 002d3f0c8e - Nokia Flash/Repair v1_49
    Box: CR V 1.002 256
    Code: NK V 1.001 1048
    SN: 002d3f0c8e
    Nokia Unlimited: 382 times started
    SonyEricsson Trial: 7 left, each max 15min
    Scanning files, please wait...
    Done
    Selected Highest installed version: 06.43
    Using Tx2 Data line.
    Boot...
    rap3gv3_2nd.fg
    %%%%%%%% ERROR BOOTING:
    Boot...
    rap3gv3_2nd.fg
    a to po 10pinówce,zaznaczone Tx2
    fischer8
    Spoczywaj w Pokoju
    Ocena: 116
    Jak robiłeś downgrade?, 6.43 jest przecież najwyższą wersją do rm-84.
  • #3 5418884
    jubi20
    Ocena: 10
    wrzuc mu 6.43 bez downgrade jak postawisz dopier wtedy downgrade na nizsza
    fischer8
    Spoczywaj w Pokoju
    Ocena: 116
    Ale po co ?
  • #5 5419172
    jubi20
    Ocena: 10
    mniemam ze tel jest martwy
    adrianw
    Ocena: 25
    Kolego a jak masz najlepiej spróbuj jak kolega pisał wcześniej 6,43 bez downgrade ale próbuj HWK (niby cienki sprzet ale czesto ratuje tyłek :) )
  • #7 5448989
    quiter1979
    ok telefon juz postawilem ale niestety certy i imei uwalone,co z tym dalej robic buckupy poszły przy stawianiu systemu,zczytałem juz ask tylko kto mi to tanio przeliczy???są jacys chetni?
    aha dodam ze postawilem 10pinowym kabelkiem,bo 7pinowy był nie przerobiony,ale wiem to dopiero teraz niestety
  • #8 5449260
    jubi20
    Ocena: 10
    poszukaj w dziale Bazar tam sa ogloszenie kto i za ile przelicza
Podczas próby downgrade'u oprogramowania w telefonie Nokia 6280 (rm-84) pojawiły się problemy z flashowaniem, w tym błędy niskopoziomowego formatowania oraz brak reakcji telefonu po próbie uruchomienia. Użytkownik próbował wgrać wersję 6.43, która jest najwyższą wersją dla tego modelu, co sugerowano wykonać bez downgrade'u. Telefon początkowo nie reagował, jednak po zastosowaniu kabla 10-pinowego udało się go uruchomić, choć certyfikaty i IMEI zostały uszkodzone. Wskazano, że do naprawy IMEI i certyfikatów potrzebne jest przeliczenie, które można zlecić specjalistom, np. poprzez ogłoszenia w dziale Bazar. Rekomendowano także użycie sprzętu HWK do ratowania telefonu w trudnych sytuacjach flashowania.
