Brak obrazu na Compaq Presario V3015CA, jak zainstalować BIOS F.39?
Amro eid 24 Wrz 2008 00:29 1999 3
  • #1 5565707
    Amro eid
    Ocena: 42
    hi colleagues:cry::cry:
    my laptop compaq presario v3000 Compaq Presario V3015CA product of hp
    i have no display on internal lcd or exterinal monitor power unit is ok
    when i press on the power led works normal but fan turn off through 1 secand
    also hdd and cd rom by the way It does not have a 3 1/2 floppy drive
    some body have any idea will help?????????
    i guess it.s bios lost i get the BIOS Version from the web site of hp for the set
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
    and it is the right version F.39 but there is no explaination about set up this file
    especially all drivers not working in my set
    how to install it in my set (WinFlash for HP BIOS F.39)the program which i have
    set up have extaintion .exe could convert it to binary may i can reprogrammer
    the flash memory
    or some hint will help in this problem
    thanks in advance
  • #2 5566141
    gsm_virus
    Ocena: 191
    When you download the file "sp38062.exe" , you must run it , and this do auto-extract on your hdd to folder C:\SwSetup\SP38062 , this is your flasher (only works on Windows) in folder winphlash and, right BIOS file is 30B5F39.WPH.
  • #3 5572453
    Amro eid
    Ocena: 42
    hi gsm_virus
    thanks for reply
    1- BIOS file is 30B5F39.WPH ok but have u any article or document
    how to install it i think many ppl search about that and no support from hp
    2 - anothe explaination if u can help
    in many cases like that i can reprogrammer the flash (29LV800) with bios.bin no problem i search any thing can convert to binary
    i search through the net and i found
    http://66.102.9.104/search?q=cache:-4j4CleJ4W...ompaq+Presario+v3000&hl=en&ct=clnk&cd=2&gl=eg
    can some one help me to download this file
    any info or articl or link will help
    thanks again gsm_virus
    regards
  • #4 5612525
    Amro eid
    Ocena: 42
    hi again
    hi again
    i get 30B5F39.WPH ,BIOS.BAK, flash1.ini, FLASH1.sys and all component
    of sp38062.exe after extract in onother pc and i programmered
    the bios chip 29LV800 new one with 30B5F39.WPH and put it again in the laptop
    now the set open power on and the hdd run for afew secand and the same about cd rom and no display on the internal lcd or from the external
    vga and the fan of processor works with out stop although no heat on
    the processor
    could the chep of vga is defect it is on the same heat think or softwar
    or some thing else or no way i have to replace the mother board
    any help i.ll be thankfull
    regards
