teraz cytuje serwisowke (zaznaczam ze nie dumam co moze byc powodem, tylko w jakich przypadkach drukarka sygnalizuje cos takiego): powody sa 4:
I data communication error
1. Turn printer Off, cancel print request and send request again.
2. If the problem continues, send another file.
3. If second document fails, verify host/printer connection. If the second document prints, first document is corrupt. Re-create first document.
II printer detects a carrige stal condition (With the printer turned Off, slide the carriage across the carriage rod. Remove any obstruction from the carriage path. Disconnecting then reconnecting the power module might be required to recover from a carriage stall.)
III. Printer detects a paper jam condition.
Clear the paper jam by feeding paper through the paper path. Do not pull the paper out by force.
With the printer on, open the access door and press and hold the Resume button. This will cause the drive rollers to move. Release the Resume button and press again to move the rollers in the opposite direction. Otherwise take mech apart to free paper.
IV The computer-to-printer connection failed.
Turn off the printer, disconnect the printer cable, turn on the printer. Initiate the self-test printout (see Printer Self-Tests and Diagnostics/Utilities under Troubleshooting). If the self-test printout is OK, the printer is OK. Reconnect the printer cable and resend the file. If the printout is still garbled, try another printer cable. Additionally, verify the proper printer driver and parallel port are selected.
rady mam takie: naoliw prowadnice karetki i przeinstaluj sterowniki jak nie pomoze daj znac
