Schemat podłączenia alarmu w Jeep Grand Cherokee 2006 - poszukiwany
sfinx 10 Mar 2009 09:31 2274 2
  • #1 6261328
    sfinx
    Ocena: 57
    Czy dysponuje ktos schematem podlaczenia alarmu w samochodzie
    Jeep Grand Cheroke 2006 ?
    Z gory dziekuje
    Grzegorz
    antena
    Ocena: 39
    Pilotowy czy bezpilotowy
    carrier
    Specjalista - Alarmy Samochodowe
    Ocena: 1047
    Jeep Grand Cherokee 2005 -2007
    PART COLOR LOCATION
    12 VOLT CONSTANT Connect to BATTERY ONLY
    STARTER PINK/ORANGE (+) IGNITION SWITCH HARNESS
    STARTER 2 PURPLE/BROWN (-) See NOTE *1 IGNITION SWITCH HARNESS, See DIAGRAM
    IGNITION 1 PINK/LIGHT GREEN (+) IGNITION SWITCH HARNESS
    IGNITION 2 N/A
    IGNITION 3 N/A
    ACCESSORY/HEATER BLOWER 1 PURPLE/BROWN (-) Same wire as STARTER #2, See NOTE *2 IGNITION SWITCH HARNESS, See STARTER #2 DIAGRAM
    ACCESSORY/HEATER BLOWER 2 N/A
    KEYSENSE N/A
    PARKING LIGHTS ( - ) N/A
    PARKING LIGHTS ( + ) DO NOT USE!
    POWER LOCK PURPLE/DARK GREEN (1-Wire System) See NOTE *3 IN DRIVERS KICK PANEL or Cluster Connector 3, pin 17 See DIAGRAM
    POWER UNLOCK Same wire, See DIAGRAM See NOTE *3, See DAIGRAM
    DOOR TRIGGER See NOTE *4 IN EACH KICK PANEL
    DOMELIGHT SUPERVISION YELLOW/ORANGE (-), Requires Part #R30-H Relay @ ANY UNDERDASH LIGHT
    TRUNK RELEASE ORANGE/PURPLE (-) See NOTE *5, Requires Part #R30-H Relay IN DRIVERS KICK PANEL
    SLIDING POWER DOOR N/A
    HORN DARK GREEN/ORANGE (+) @ HORN or IPM, Connector, C2 pin 35, See NOTE *6
    TACH ANY wire NOT RED/TAN or DARK GREEN/LIGHT GREEN @ any FUEL-INJECTOR or IGNITION COIL
    WAIT TO START LIGHT N/A
    BRAKE WHITE/TAN (+) or WHITE/LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
    FACTORY ALARM DISARM N/A
    ANTI-THEFT CHRYSLER'S SENTRY KEY, A TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER
    EXTRA INFORMATION
    NOTE *1 & *2 this vehicle requires a Special Circuit that requires (2) Relays and (2) Resistors, Starter #2 requires a (-)Negative thru a 180 Ohm Resistor and an extra relay part #R30-H and Accessory requires a (-)Negative thru a 610 Ohm Resistor and an extra relay part #R30-H, to connect this circuit up, See DIAGRAM NOTE *3 vehicles with MEMORY SEATS, have to go to the DRIVERS MEMORY MIRRO MODULE in the door to get this wire. The LOCK wire requires a (-)Negative thru 330 Ohm resistor and UNLOCK requires a (-)Negative thru a 100 Ohm resistor, some units require 2 extra relays part #R30-H, to connect. See DIAGRAM NOTE *4 the DRIVERS DOOR is a PURPLE (-) PIN 6, the PASSENGER DOOR is a PURPLE/WHITE (-) PIN 7, the DRIVERS REAR DOOR is a PURPLE/GRAY (-) PIN 4, and the PASSENGER REAR DOOR is a PURPLE/YELLOW (-) PIN 5, when connecting an ALARM SYSTEM, use all 4 DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM. NOTE *5 when testing the TRUNK/HATCH RELEASE wire, you must use the Key to open the REAR GLASS, this wire should then show a (-) Negative during testing. NOTE *6 the IPM (Integrated Power Module) is located on the DRIVERS FENDER, BEHIND THE BATTERY.
