Jak tu mozna wejsc do BIOSA . Laptop botuje z CD ale nie widzi HD .Podmienilem HD i to samo.Moge botowac rowniez z FD i z tad mysle o wgraniu BIOSA i nie widze go nawet na stronie Toshiby
Czy wolisz polską wersję strony elektroda?
Nie, dziękuję Przekieruj mnie tamThe final method discussed is for the following Toshiba models:
Satellite 5005-S504, 5005-S507, 5005-S508, 5105-S607, 5105-S608, 5105-S501, 5105-S701, 5105-S502, 5105-S702, 5105-S901, 5205-S503, 5205-S703, 5205-S504, and 5205-S704
These are "legacy-free" models, and they do not incorporate a BIOS Setup program in the motherboard ROM. The only way to run BIOS Setup is using a Windows-based BIOS Setup utility called HWSetup. The HWSetup utility comes preinstalled on these Toshiba models, and it is also contained in the Toshiba Utilities package for these models, which can be downloaded from the Toshiba support Web site. To run HWSetup, open the Control Panel and double-click the HWSetup program. HWSetup provides a graphical front end for modifying BIOS settings. Note that if you change any settings, you may be required to restart the system.
ToJurek napisał:Otrzymana od ciebie instrukcje obslugi laptopa w angielskim przegladalem ale o BIOS-sie nic sie nie doczytalem
