Sony KP51S4K - LED miga 19 razy, telewizor nie włącza się, co sprawdzić?
radjas 05 Cze 2004 20:07 1536 7
  • #1 677239
    radjas
    Witam!! Telewizorek nie włącza sie. :( Led mruga 19 razy . Od czego mam zacząć??Pozdrawiam
  • #2 677260
    DiZMar
    Ocena: 6616
    Poczytaj sobie to, moze Ci pomoże ale 19razy :idea:
    Many of the later model Sony TV's have a built in Self- Diagnosis
    function. If the timer/standby indicator is blinking, this
    could be an indication of the problem with the unit. The diagnostic
    blinking will occur automatically with no action
    required by you to engage it.
    The timing of the blinking you see would be as follows: two to eight
    blinks (depending on the fault) about a third of a
    second apart, then pauses for 3 seconds, then the two to eight
    blinks about a third of a second apart again.
    Here is a list of the problems that might have occurred indicated by
    the number of blinks. The words in parentheses are
    those which you will see for each of these faults on a diagnosis
    screen described later in this article.
    Unit is dead and there are no blinks---Problem in the standby power
    section. Might check fuse, R607, Q601, IC601, R612
    and VDR601 (should show open)
    Continuous Blink Once A Second, No Pausing As Discussed Above---
    No reply from the jungle IC301 (data bus is busy, shorted to ground
    or held high), IK video path is defective.
    ONE Blink--- not used for the self-diagnosis
    TWO Blinks---B+ over current protection (OCP) , unit goes to the
    standby mode then displays the 2 blink fault. Could be a
    short in the power supply of any of the circuits.
    THREE Blinks---B+ over voltage protection (OVP), unit goes to the
    standby mode then displays the 3 blink fault. This is
    also a problem in the power supply circuit, check T603 and R672.
    FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
    horizontal line then the video signal muted. Check
    IC1509, Q1505
    FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks
    for about 30 seconds then goes to the self-diagnosis
    function. Something is wrong with the video. Check video out, Q705,
    732, 761 and other components on the C board, also check
    Q218, 219, 220 on the A board. Also unit be in IK blanking, try
    turning up screen slightly.
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking
    self-diagnosis function immediately. Check C515 & 516
    and the jungle IC, IC206.
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded
    33k and the unit goes immediately into safety shutdown.
    Check power supply regulation and horizontal circuits.
    EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby
    and blinks the self-diagnosis code. Check IC406 audio
    amp, PS401 and 402.
    Intermittent problems ?? This is a great feature. You can also bring
    up these fault codes ON-SCREEN to see a list of the
    problem numbers with the abbreviation of the problem and the number
    of times this problem has occurred. This is slightly
    different than entering the service mode. To see the diagnostic
    screen, Press the following buttons:
    Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings
    up a screen with a list of the problems and number
    of times they have occurred. Each of the problem names is abbreviated
    as, "OCP", "OVP", "V STOP", ETC. We have repeated
    them in parentheses in the text for the "Blinks" described above so
    you can correlate between the diagnostic screen and
    the blink codes.
    So, now that you know about these self-diagnostics, how do you use
    them? Say that you have a set with a black screen. You
    see that the LED is blinking 4 times....This would tell you that you
    have no vertical and that is why the video is muted.
    If it was blinking 6 times, you would know that you have a
    horizontal fault.
    It's not a sure cure, but it's a little better than a poke in the eye
    with a sharp stick.
    IMPORTANT: after you repair the unit, PLEASE clear the values on this
    diagnostic screen. These codes do not reset
    themselves after the fault is corrected, so if you don't clear them,
    you'll be seeing "old" fault codes the next time
    you enter this screen.
    Clearing is done by going into the service mode ( display, channel,
    5, volume plus, then power ) then press 8 and Enter,
    which of course returns everything to the factory preset condition.
  • #3 677337
    czeladnik
    Spec od TV
    Ocena: 8
    radjas napisał:
    Witam!! Telewizorek nie włącza się. :( Led mruga 19 razy . Od czego mam zacząć??Pozdrawiam
    1.Rozkrecic
    2.obejrzec od srodka
    3. ocenic swoje sily i zamiary
    ..... troche wiecej wlasnej inicjatywy Szanowny Kolego....
    Cos pomierzyc,chassis obejrzec,pare info od klienta itp.
    DiZMar....19 razy :D :spoko:
  • #4 677537
    radjas
    Witam :) Być może a raczej jak czytam brzmi to niewiarygodnie te 19 razy ale tak jest (liczyć jeszcze umiem:) ). W poniedziałek się za niego wezmę ale raczej na "czuja" bo i schematu niemoge znalezć :(.
    @DiZMar dziękuje .....to co napisałeś sporo juz mi wyjasnia.
    @czeladnik według Twych sugesti zmobilizuję bardziej swe incjatywe
  • #5 678369
    DiZMar
    Ocena: 6616
    Ten TV to chyba powinno być Sony KP-41S4K i wtedy to będzie chassis RE2, którego schemat znajduje się tu:
    https://www.elektroda.pl/rtvforum/topic17562.html#309113
  • #6 683687
    radjas
    Witam ponownie:) . Udało mi się już coś niecoś wyjaśnić. Więc tak : padł trafopowielacz (NX_4007) ,a i przy okazji tranzystor ( 2SD2539). Z tranzystorkiem to nie problem ale gdzie mogę nabyć to trafo bo szukam w sieci i mam tylko adresy z poza kraju:(. Jezeli zna ktoś taki nasz adresik to proszę o pomoc. Pozdrawiam
  • #7 683726
    DiZMar
    Ocena: 6616
    W SONY KP51S4K Chassis RE2 a nie jak w temacie Sony KP_4154K siedzi NX4007=HR8569=859899400, gdzie go dostacć to poszukam i dopiszę jak znajdę.
    W SONY KP51S4K Chassis RE2 a nie jak w temacie Sony KP_4154K siedzi NX4007=HR8569=859899400, gdzie go dostac to poszukam i dopiszę jak znajdę.
    A więc w:
    http://www.north.com.pl/sklep/
    za 129zł+przesyłka 13zł za 2-3 tygodnie
    lub w:
    http://www.poltronic.com.pl/sklep
    za 106+przesyłka 10,50-ale brak
    lub w firmie Selenex lub Foton z Kutna dorobią Ci każde trafo WN TV aby było w standardowym rozstawie pin na podstawie dostarczonego uszkodzonego trafa w cenie z przesyłką myślę, że znacznie niższą niż wyżej podane. Oto kontakt: (024)254-46-40
  • #8 691573
    radjas
    @DiZMar :):) Wielkie dzięki za pomoc .Dzisiaj zamowiłem.Jak otrzymam przesyłke i odpale to z pewnoscią napiszę. Pozdrawiam
✨ Telewizor Sony KP51S4K nie włącza się, a dioda LED miga 19 razy, co wskazuje na błąd sygnalizowany przez system autodiagnostyki. Miganie LED w modelach Sony informuje o konkretnych usterkach, a w tym przypadku problemem okazał się uszkodzony transformator wysokiego napięcia (trafopowielacz) oznaczony jako NX4007 (również HR8569, 859899400) oraz tranzystor 2SD2539. Schemat chassis RE2, stosowany w tym modelu, jest dostępny na forum elektroda.pl. Wymiana uszkodzonych elementów jest konieczna do przywrócenia działania telewizora. Transformator można zamówić w polskich sklepach internetowych lub zlecić wykonanie na podstawie uszkodzonego egzemplarza w firmach specjalizujących się w produkcji transformatorów wysokiego napięcia do telewizorów. Wskazane jest samodzielne rozkręcenie i ocena stanu podzespołów oraz wykorzystanie dostępnych schematów do diagnozy.
