Witam!
Prosiłbym o pomoc w diagnozie dysku SAMSUNG HD642JJ!
Czy mam się martwić? czy zacząć zbierać na nowy dysk?
S.M.A.T.R. i test w Victorii
Smart test=BAD!
Test!
Wszelkie sugestie mile widziane!
Pozdrawiam!
Smart test=BAD!
SATA SAMSUNG HD642JJ S1AFJDWQ710398
ID Name Value Worst Tresh Raw Health
1 Raw read error rate 99 56 51 2473 ••••
3 Spin-up time 86 86 11 5070 ••••
4 Number of spin-up times 99 99 0 958 ••••
5 Reallocated sector count 100 100 10 0 •••••
7 Seek error rate 100 100 51 0 •••••
8 Seek time perfomance 100 100 15 9859 •••••
9 Power-on time 99 99 0 2770 ••••
10 Spin-up retries 100 100 51 0 •••••
11 Recalibration retries 100 100 0 0 •••••
12 Start/stop count 99 99 0 958 ••••
13 Soft read error rate 99 76 0 643 ••••
183 unknown attribut 100 100 0 79 •••••
184 End-to-End error 100 100 99 0 •••••
187 Reported UNC error 100 100 0 998 •••••
188 Command timeout 100 100 0 0 •••••
190 Airflow temperature 71 59 0 29°C/84°F ••••
194 HDA Temperature 66 58 0 34°C/93°F ••••
195 Hardware ECC recovered 100 100 0 670362 •••••
196 Reallocated event count 100 100 0 0 •••••
197 Current pending sectors 100 100 0 5 •••••
198 Offline scan UNC sectors 100 100 0 1 •••••
199 Ultra DMA CRC errors 99 99 0 39 ••••
200 Write error rate 100 100 0 0 •••••
201 Off-track errors count 253 253 0 60 ••••• Test!
Victoria 4.46b Freeware (12.08.2008) log file. 2009-11-19
14:40:24 : Starting Victoria 4.46b Freeware (12.08.2008), 2xCPU, 2666,90 MHz, Windows XP found.
14:40:24 : API access enabled, device #1
14:40:32 : Get passport... OK
14:40:32 : 48bit access enabled
14:40:32 : Model: SATA SAMSUNG HD642JJ; Capacity: 1250261615 LBAs; SN: S1AFJDWQ710398; FW: 1AA01112
14:41:04 : SMART ON command
14:41:04 : Get passport... OK
14:41:04 : Starting Off-line routine SMART Test (0)
14:44:30 : Get passport... OK
14:44:30 : Recallibration... OK
14:44:30 : Starting Reading, LBA=0..1250261614, sequential access, timeout 10000ms
14:47:04 : Block 20563456 Error: ABRT
14:56:06 : Get S.M.A.R.T. command... OK
14:56:06 : SMART status = BAD
15:26:29 : Warning! Block start at 429027328 = 282 ms
16:39:13 : Warning! Block start at 1108484864 = 988 ms
17:00:48 : ***** Scan results: Warnings - 2, errors - 1 *****Wszelkie sugestie mile widziane!
Pozdrawiam!
