K510i 6x dioda. Po naprawie GDFS, wgraniu softu nic.
gavron04 17 Maj 2011 18:55 1805 14
  • #1 9516631
    gavron04
    Ocena: 138
    Witam. Dostałem do naprawy K510i. Przy wł. 6x dioda. Pod ładowarką biały ekran, po chwili szary. Najpierw pod boxem zrobiłem GDFS, EROM. Poszło sprawnie
    SIGNED MODE (USING SERVER)
    CFG:100000000000
    RESET MODE STARTED
    NEW SECURITY (RESPIN) PHONE
    ChipID:8040,EMP protocol:0301
    PHONE STATE: "RETAIL"
    FLASH CID: 0050
    Speed:921600
    RESET:070703 1100 NPACXC125870_DB2010_CERTRESETLOADER_P5F
    FLASH ID: 897E
    GOT SEED:32287B152280FD77152052BD
    P96 AUTH PASSED
    OTP: LOCKED:1 CID:50 PAF:1 IMEI:--------------- CERT:RED
    PHONE SUCCESSFULLY RESET TO DEVELOPER STATE
    Elapsed: 20 secs.
    CFG:000000000000
    PHONE STATE: "DEVELOPER"
    FLASH CID: 0051
    Speed:921600
    OTP: LOCKED:1 CID:50 PAF:1 IMEI:---------------------- CERT:BROWN
    LDR:DB2010_RESPIN_PRODLOADER_SETOOL2
    FLASH ID: 897E
    writing "C:\Documents and Settings\dom\Pulpit\v1.01\gdfs_in_ssw_format\db2010\k510_gdfs_in_ssw_format.ssw"
    CURRENT FLASH FILE CID:254
    SSW uses dynamic hash, dynamic hash len is: 32
    Will flash 32 blocks...
    writing "C:\Documents and Settings\dom\Pulpit\v1.01\eroms\db2010\db2012_erom_cid50.ssw"
    CURRENT FLASH FILE CID:36
    Converting firmware...
    SSW uses dynamic hash, dynamic hash len is: 2
    Will flash 2 blocks...
    Setting up GDFS...
    OTP WRITE NOT EXECUTED
    WRITING CLEAR SIMLOCK UNITS...
    ALL UNLOCK/LOCK CODES SET TO "37888773"
    SIGNING...
    Elapsed: 58 secs.
    Po tym nic nie pomogło. Wgrałem soft:
    MODEL:CZAJO
    CDA: CDA102459/2
    CDA REV: R8A
    VARIANT:CENT_EUROPE
    LANGUAGE: EN PL CS SK HU
    CFG:100100000000
    FLASH CID: 0050
    Speed:921600
    OTP: LOCKED:1 CID:50 PAF:1 IMEI:----- CERT:RED
    LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695
    FLASH ID: 897E
    writing "C:\Documents and Settings\dom\Moje dokumenty\Pobieranie\K510_R4EA031_MAIN_GENERIC_CO_RED50.mbn"
    CURRENT FLASH FILE CID:50
    SSW uses full hash, hash len is: 6540
    Will flash 327 blocks...
    writing "C:\Documents and Settings\dom\Moje dokumenty\Pobieranie\K510_R4EA031_FS_S_E_EUROPE_RED50.fbn"
    SSW uses full hash, hash len is: 2180
    Will flash 109 blocks...
    LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009
    loader GDFS startup executed
    loader FILESYSTEM startup executed
    using GENERIC phone customization
    tpa/preset/custom/C3_PCA_G3v2.cer
    tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    tpa/preset/custom/customize.xml
    tpa/preset/custom/DESKTOP_HOOK_2.itm
    tpa/preset/custom/Entrust.net Root Certificate.cer
    tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    tpa/preset/custom/FM_THEMES_HOOK_3.itm
    tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    tpa/preset/custom/GAMES_HOOK_3.itm
    tpa/preset/custom/GTE_CyberTrust_Root.cer
    tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    tpa/preset/custom/Root.cer
    tpa/preset/custom/SEMC_E2E_Root_CA.crt
    tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    tpa/preset/custom/ThawtePremium.der
    tpa/preset/custom/ThawteServerCA.cer
    tpa/preset/custom/Utiroot.cer
    tpa/preset/custom/VeriSignClass3Root.cer
    tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Writing package "C:\Documents and Settings\dom\Moje dokumenty\Pobieranie\CZAJO_CDA102459_2_R8A_Generic_CENT_EUROPE\tpa.zip"...
    /tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm
    /tpa/preset/custom/customize.xml
    /tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    /tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    /tpa/preset/custom/FM_THEMES_HOOK_3.itm
    /tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    /tpa/preset/custom/GAMES_HOOK_3.itm
    /tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    /tpa/preset/system/language/allowed_language.txt
    /tpa/preset/system/language/lng.lst
    /tpa/preset/system/language/pl.lng
    /tpa/preset/system/language/pl.t9
    Phone detached
    Elapsed: 385 secs.
    Jakieś pomysły?
  • #3 9516656
    gavron04
    Ocena: 138
    Jednak nic.. To samo ciągle..
    Czekam na kolejne pomysły.
  • #4 9520193
    gavron04
    Ocena: 138
    Wie ktoś jak to naprawić?
    Aktualnie jest tak, że wgrałem EROM DB2012 CID 50, GDFS .ssw, soft R4EA031 i przy uruchomieniu mignie biały ekran, czasami wibracja i cały czas szary ekran.
  • #6 9520685
    gavron04
    Ocena: 138
    Jest tak, że czasem się załączy, i można go używać.
    No i bardzo często jak się ekran załącza na biało to taka 'fala' przechodzi.. Nie wiem jak to nazwać
  • #7 9521254
    rafcio363
    Poziom 30  
    Ocena: 266
    Nie urażając autora tematu - box z Ciebie serwisanta nie zrobi :)
    Poza tym taki stary małowartościowy model to prościej płytę załatwić niż go męczyć pół dnia.Ale jak masz chęć to w czym problem schemat do ręki i jazda.
  • #8 9521290
    gavron04
    Ocena: 138
    Nie rozumiem, dlaczego od razu z takim tekstem wylatujesz ;). Odezwę się jak coś z nim zrobię.
    rafcio363
    Poziom 30  
    Ocena: 266
    Bylebyś go już nie softował do bólu :)
    Jak raz włączy a raz nie to go wygrzej i zobacz czy nie zalany.
  • #10 9521359
    gavron04
    Ocena: 138
    Właśnie miałem iść to robić ;). Zalany nie był (na 100%)
    Jedno pytanko, ile stopni ?
  • #11 9521378
    rafcio363
    Poziom 30  
    Ocena: 266
    Każda stacja ma inna tolerancję/dokładność temp do której trzeba dojść metodą prób i błędów ,spróbuj 100-300 stopniowo zwiększając.
  • #12 9521384
    gavron04
    Ocena: 138
    Ok. (Mam PT 803, więc nie zobaczę ile dokładnie :) Ale będę próbował :)
  • #13 9521431
    rafcio363
    Poziom 30  
    Ocena: 266
    Chyba do 6tki jak dobrze pamiętam.
    Ale 4-5 juz grzeje mocno.
  • #14 9530099
    gavron04
    Ocena: 138
    Po wygrzaniu na razie 5 razy pod rzad poprawnie odpalił.
    Najpierw grzałem 3, później 4 i na końcu 5.
    Jeśli będzie działał cały czas to napiszę.
    Pozdr
  • #15 9531995
    gavron04
    Ocena: 138
    Od wczoraj telefon za każdym razem wł. się poprawnie. Żadnych problemów.
✨ Użytkownik zgłosił problem z telefonem K510i, który po naprawie GDFS i wgraniu oprogramowania wyświetlał 6x diodę oraz biały ekran, a następnie szary. Po kilku próbach z różnymi wersjami EROM i softu, problem nie ustępował. Użytkownicy zasugerowali, że może to być problem sprzętowy, a także poradzili wygrzanie płyty głównej, co ostatecznie przyniosło pozytywne rezultaty. Po wygrzaniu telefon zaczął poprawnie się uruchamiać.
