HP Pavilion dv6000 - Błąd #10009, jak odzyskać dane z uszkodzonego dysku?
pablo246 13 Lut 2014 23:36 1731 4
  • #1 13299339
    pablo246
    Hej,
    Mam problem z odpaleniem mojego hp dv6000. W biosie znalazłem błąd #10009 - replace hard disk.
    Poczytałem trochę forum i widzę że pierwszym krokiem jest wygenerowanie SMARTa, zainstalowałem parted magica, odnalazłem dysk, pobrałem SMARTa - wklejam poniżej. Prośba do osób znających temat o info co dalej... Z góry dzięki.
    Dodam, że bardzo mi zależy na odzyskaniu danych z tego dysku.. uda się?
    smartctl 5.43 2012-06-30 r3573 [i686-linux-3.12.6-pmagic] (local build)
    Copyright (C) 2002-12 by Bruce Allen, ...
    === START OF INFORMATION SECTION ===
    Model Family:     Western Digital Scorpio Blue Serial ATA
    Device Model:     WDC WD2500BEVS-60UST0
    Serial Number:    WD-WXC208125192
    LU WWN Device Id: 5 0014ee 2abd806cb
    Firmware Version: 01.01A01
    User Capacity:    250,059,350,016 bytes [250 GB]
    Sector Size:      512 bytes logical/physical
    Device is:        In smartctl database [for details use: -P show]
    ATA Version is:   8
    ATA Standard is:  Exact ATA specification draft version not indicated
    Local Time is:    Thu Feb 13 23:16:46 2014 CET
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    See vendor-specific Attribute list for marginal Attributes.
    General SMART Values:
    Offline data collection status:  (0x00)	Offline data collection activity
    					was never started.
    					Auto Offline Data Collection: Disabled.
    Self-test execution status:      (   0)	The previous self-test routine completed
    					without error or no self-test has ever
    					been run.
    Total time to complete Offline
    data collection: 		( 9180) seconds.
    capabilities: 			 (0x5b) SMART execute Offline immediate.
    					Auto Offline data collection on/off support.
    					Suspend Offline collection upon new
    					command.
    					Offline surface scan supported.
    					Self-test supported.
    					No Conveyance Self-test supported.
    					Selective Self-test supported.
    SMART capabilities:            (0x0003)	Saves SMART data before entering
    					power-saving mode.
    					Supports SMART auto save timer.
    Error logging capability:        (0x01)	Error logging supported.
    					General Purpose Logging supported.
    Short self-test routine
    recommended polling time: 	 (   2) minutes.
    Extended self-test routine
    recommended polling time: 	 ( 110) minutes.
    SCT capabilities: 	       (0x303f)	SCT Status supported.
    					SCT Error Recovery Control supported.
    					SCT Feature Control supported.
    					SCT Data Table supported.
    SMART Attributes Data Structure revision number: 16
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
      1 Raw_Read_Error_Rate     0x000f   188   186   051    Pre-fail  Always       -       158214
      3 Spin_Up_Time            0x0003   189   188   021    Pre-fail  Always       -       1525
      4 Start_Stop_Count        0x0032   091   091   000    Old_age   Always       -       9257
      5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
      7 Seek_Error_Rate         0x000f   100   253   051    Pre-fail  Always       -       0
      9 Power_On_Hours          0x0032   085   085   000    Old_age   Always       -       11160
     10 Spin_Retry_Count        0x0013   100   098   051    Pre-fail  Always       -       0
     11 Calibration_Retry_Count 0x0012   100   100   051    Old_age   Always       -       0
     12 Power_Cycle_Count       0x0032   094   094   000    Old_age   Always       -       6608
    187 Reported_Uncorrect      0x0032   011   001   000    Old_age   Always       -       78658
    188 Command_Timeout         0x0032   100   092   000    Old_age   Always       -       25771376766
    190 Airflow_Temperature_Cel 0x0022   072   040   040    Old_age   Always   In_the_past 28
    192 Power-Off_Retract_Count 0x0032   199   199   000    Old_age   Always       -       999
    193 Load_Cycle_Count        0x0032   170   170   000    Old_age   Always       -       92082
    194 Temperature_Celsius     0x0022   119   087   000    Old_age   Always       -       28
    196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
    197 Current_Pending_Sector  0x0012   200   200   000    Old_age   Always       -       8
    198 Offline_Uncorrectable   0x0010   100   253   000    Old_age   Offline      -       0
    199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
    200 Multi_Zone_Error_Rate   0x0009   100   253   051    Pre-fail  Offline      -       0
    SMART Error Log Version: 1
    Warning: ATA error count 39861 inconsistent with error log pointer 3
    ATA Error Count: 39861 (device log contains only the most recent five errors)
    	CR = Command Register [HEX]
    	FR = Features Register [HEX]
    	SC = Sector Count Register [HEX]
    	SN = Sector Number Register [HEX]
    	CL = Cylinder Low Register [HEX]
    	CH = Cylinder High Register [HEX]
    	DH = Device/Head Register [HEX]
    	DC = Device Command Register [HEX]
    	ER = Error register [HEX]
    	ST = Status register [HEX]
    Powered_Up_Time is measured from power on, and printed as
    DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
    SS=sec, and sss=millisec. It "wraps" after 49.710 days.
    Error 39861 occurred at disk power-on lifetime: 11160 hours (465 days + 0 hours)
      When the command that caused the error occurred, the device was active or idle.
      After command completion occurred, registers were:
      ER ST SC SN CL CH DH
      40 51 0f 60 13 01 e0  Error: UNC at LBA = 0x00011360 = 70496
      Commands leading to the command that caused the error were:
      CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
      c4 ff 3f 22 13 01 00 00      00:00:44.475  READ MULTIPLE
      c8 ff 3f 22 13 01 00 00      00:00:40.459  READ DMA
      ef 03 45 ff ff 00 00 00      00:00:40.458  SET FEATURES [Set transfer mode]
      ef 03 0c ff ff 00 00 00      00:00:40.458  SET FEATURES [Set transfer mode]
      c6 ff 10 ff ff 00 00 00      00:00:40.458  SET MULTIPLE MODE
    Error 39860 occurred at disk power-on lifetime: 11160 hours (465 days + 0 hours)
      40 51 00 60 13 01 e0  Error: UNC at LBA = 0x00011360 = 70496
      10 ff 50 2f 25 c2 00 00      00:00:40.413  RECALIBRATE [OBS-4]
    Error 39859 occurred at disk power-on lifetime: 11160 hours (465 days + 0 hours)
      c4 ff 3f 22 13 01 00 00      00:00:36.020  READ MULTIPLE
      c8 ff 3f 22 13 01 00 00      00:00:32.011  READ DMA
      ef 03 45 ff ff 00 00 00      00:00:32.011  SET FEATURES [Set transfer mode]
      ef 03 0c ff ff 00 00 00      00:00:32.011  SET FEATURES [Set transfer mode]
      c6 ff 10 ff ff 00 00 00      00:00:32.011  SET MULTIPLE MODE
    Error 39858 occurred at disk power-on lifetime: 11160 hours (465 days + 0 hours)
      10 ff 50 2f 25 c2 00 00      00:00:31.964  RECALIBRATE [OBS-4]
    Error 39857 occurred at disk power-on lifetime: 11160 hours (465 days + 0 hours)
      c4 ff 3f 22 13 01 00 00      00:00:27.742  READ MULTIPLE
      c8 ff 3f 22 13 01 00 00      00:00:23.861  READ DMA
      29 ff 3f 22 13 01 00 00      00:00:19.987  READ MULTIPLE EXT
      25 ff 3f 22 13 01 00 00      00:00:16.109  READ DMA EXT
      25 ff 3f 1b 09 00 00 00      00:00:16.107  READ DMA EXT
    SMART Self-test log structure revision number 1
    Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
    # 1  Short offline       Completed: read failure       90%     11160         70496
    # 2  Short offline       Completed: read failure       90%     11160         70496
    # 3  Short offline       Completed: read failure       90%     11160         70496
    SMART Selective self-test log data structure revision number 1
     SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
        1        0        0  Not_testing
        2        0        0  Not_testing
        3        0        0  Not_testing
        4        0        0  Not_testing
        5        0        0  Not_testing
    Selective self-test flags (0x0):
      After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
  • #2 13303843
    pablo246
    Bardzo proszę o pomoc!
  • #3 13303873
    domio33
    Ocena: 56
    Podłącz dysk do innego komputera,powinno się udać.Dysk posiada 8 Current_Pending_Sector.
  • #4 13304001
    pablo246
    co oznacza Current_Pending_Sector? zerowanie dysku je usunie?
  • #5 13304007
    sPeRaCz.PL
    Ocena: 613
    Są to sektory niestabilne.
    pablo246 napisał:
    Zerowanie dysku je usunie ?
    Tak. Zerowanie + remap. Procedura opisana jest na forum.
    https://www.elektroda.pl/rtvforum/topic1550200.html
    Zerowanie kasuje definitywnie wszystkie dane, zabezpiecz się kopią zapasową najważniejszych danych.
    Jak wykonasz procedurę zamieść ponownie SMART dysku.
