Witam Panowie, mam PCMSCAN z licencją, ale mam problemy :
[23:53:42.093] Sat Apr 22 23:53:42 1995
[23:53:42.093] PCMSCAN™ v2.4.12 (Build 1194)
[23:53:42.109] ERROR: Failed to load OBD-II database!
[23:53:42.109] ERROR: OBD-II and PID functionality will probably not work right!
[23:53:42.109] ERROR: This is probably an installation problem. Please re-install the program!
[23:53:42.109] Applying license for: PCMSCAN (ORGANIZACJA)
[23:53:42.109] Creating New Configuration File...
[23:53:42.125] License applied successfully!
[23:53:42.125] Loading OBD-II Parameter Set...
[23:53:42.125] Loading PID scripts...
[23:53:42.125] Loaded 3 PID scripts.
[23:53:49.609] Opening OBD-II Connection...
[23:53:49.609] ERROR: Unknown diagnostic system: OBDII_GENERIC
[23:53:49.609] ERROR: Using this diagnostic system instead: OBDII_GENERIC
[23:53:49.609] Failed to open OBD-II connection! Error 80: Invalid diagnostic system.
[23:55:15.953] Opening OBD-II Connection...
[23:55:15.953] ERROR: Unknown diagnostic system: OBDII_GENERIC
[23:55:15.953] ERROR: Using this diagnostic system instead: OBDII_GENERIC
[23:55:15.953] Failed to open OBD-II connection! Error 80: Invalid diagnostic system.
Co jest nie tak ?
Co jest nie tak ?
