Symulacja UART w AVR Studio dla Atmega128 - jak to zrobić?
czuga 26 Kwi 2005 20:22 1498 3
  • #1 1439887
    czuga
    Ocena: 38
    W AVR306 mozna znalezc taki kod obslugi USARTA dla atmegi128:
    #include <avr/io.h>
    #include <avr/iom128.h>
    #include <avr/ina90.h>
    /* UART Buffer Defines */
    #define USART_RX_BUFFER_SIZE 128     /* 2,4,8,16,32,64,128 or 256 bytes */
    #define USART_TX_BUFFER_SIZE 128     /* 2,4,8,16,32,64,128 or 256 bytes */
    #define USART_RX_BUFFER_MASK ( USART_RX_BUFFER_SIZE - 1 )
    #define USART_TX_BUFFER_MASK ( USART_TX_BUFFER_SIZE - 1 )
    #if ( USART_RX_BUFFER_SIZE & USART_RX_BUFFER_MASK )
    	#error RX buffer size is not a power of 2
    #endif
    #if ( USART_TX_BUFFER_SIZE & USART_TX_BUFFER_MASK )
    	#error TX buffer size is not a power of 2
    #endif
    /* Static Variables */
    static unsigned char USART_RxBuf[USART_RX_BUFFER_SIZE];
    static volatile unsigned char USART_RxHead;
    static volatile unsigned char USART_RxTail;
    static unsigned char USART_TxBuf[USART_TX_BUFFER_SIZE];
    static volatile unsigned char USART_TxHead;
    static volatile unsigned char USART_TxTail;
    /* Prototypes */
    void USART0_Init( unsigned int baudrate );
    unsigned char USART0_Receive( void );
    void USART0_Transmit( unsigned char data );
    /* Main - a simple test program*/
    int main( void ){
    	int i;
    	USART0_Init( 11 );   /* Set the baudrate to 19,200 bps using a 3.6864MHz crystal */
    	_SEI();           /* Enable interrupts => enable UART interrupts */
    	for(;;)        /* Forever */
    		USART0_Transmit( USART0_Receive() ); /* Echo the received character */
    	return 0;
    /* Initialize USART */
    	unsigned char x;
    	/* Set the baud rate */
    	UBRR0H = (unsigned char) (baudrate>>8);
    	UBRR0L = (unsigned char) baudrate;
    	/* Enable UART receiver and transmitter */
    	UCSR0B = ( ( 1 << RXCIE0 ) | ( 1 << RXEN0 ) | ( 1 << TXEN0 ) );
    	/* Set frame format: 8 data 2stop */
    	UCSR0C = (1<<USBS0)|(1<<UCSZ01)|(1<<UCSZ00);              //For devices with Extended IO
    	/* Flush receive buffer */
    	x = 0;
    	USART_RxTail = x;
    	USART_RxHead = x;
    	USART_TxTail = x;
    	USART_TxHead = x;
    /* Interrupt handlers */
    #pragma vector=USART0_RXC_vect
    void USART0_RX_interrupt( void ){
    	unsigned char data;
    	unsigned char tmphead;
    	/* Read the received data */
    	data = UDR0;
    	/* Calculate buffer index */
    	tmphead = ( USART_RxHead + 1 ) & USART_RX_BUFFER_MASK;
    	USART_RxHead = tmphead;      /* Store new index */
    	if ( tmphead == USART_RxTail )
    		/* ERROR! Receive buffer overflow */
    	USART_RxBuf[tmphead] = data; /* Store received data in buffer */
    #pragma vector=USART0_UDRE_vect
    void USART0_TX_interrupt( void )
    	unsigned char tmptail;
    	/* Check if all data is transmitted */
    	if ( USART_TxHead != USART_TxTail )
    		tmptail = ( USART_TxTail + 1 ) & USART_TX_BUFFER_MASK;
    		USART_TxTail = tmptail;      /* Store new index */
    		UDR0 = USART_TxBuf[tmptail];  /* Start transmition */
    	else
    		UCSR0B &= ~(1<<UDRIE0);         /* Disable UDRE interrupt */
    /* Read and write functions */
    	while ( USART_RxHead == USART_RxTail )  /* Wait for incomming data */
    	tmptail = ( USART_RxTail + 1 ) & USART_RX_BUFFER_MASK;/* Calculate buffer index */
    	USART_RxTail = tmptail;                /* Store new index */
    	return USART_RxBuf[tmptail];           /* Return data */
    	tmphead = ( USART_TxHead + 1 ) & USART_TX_BUFFER_MASK; /* Wait for free space in buffer */
    	while ( tmphead == USART_TxTail );
    	USART_TxBuf[tmphead] = data;           /* Store data in buffer */
    	USART_TxHead = tmphead;                /* Store new index */
    	UCSR0B |= (1<<UDRIE0);                    /* Enable UDRE interrupt */
    unsigned char DataInReceiveBuffer( void )
    	return ( USART_RxHead != USART_RxTail ); /* Return 0 (FALSE) if the receive buffer is empty */
    1) ...wrzucilem elfa do AVRStudio...wlaczylem prace krokowa...i cos tam robil az zatrzymal sie w koncu na linii:
    ...czyli stalo sie ta gdyz w main jest echo receive character ...poprawcie mnie jesli zle mysle...a jak prosto to przerobic zeby cos wysylal do RS'a ...i nastepnie czekal na odbior jakiegos znaczka...i najwazniejsze to w jaki sposob moge zasymulowac ze cos przyszlo...
    ...z gory dziekuje za pomocz[/code]
  • #2 1439962
    ko_rex
    Ocena: 2
    W AVR Studio jest co prawda okienko "Terminal", ale działa ono tylko gdy kompilator C podmieni standardowe fukcje obsługi UARTA (printy itp.) na inne, przydatne przy debugowaniu (i tylko wtedy!). Robi sie to w jego opcjach (tzn. tak jest w CV, nie wiem jak w GCC). Natomiast w AVR Studio? Trzeba odpowiednio zadziałać rejestrami procesora i będzie GIT. ALe to żmudna robota...
  • #3 1439986
    Dexter77
    Ocena: 19
    Jesli nic nie zmieniales z lewej strony powinienes miec panel Workspace. Na dole tego panelu sa zakladki Project|I/O|Info. Kliknij zakladke I/O. Ukaze sie drzewko z zasobami procesora. M.in. jest tam galaz I/O. Po rozwinieciu powinien tez byc USART. W Atmedze 128 pewnie beda dwie takie galezie USART0 i USART1. Po rozwinieciu ukaza Ci sie wszystkie rejestry zwiazane z danym USART-em. UDR jest rejestrem w ktorym laduje odebrana dana. Wpisujac do niego jakas dana zasymulujesz jej odebranie. Chyba jeszcze bedziesz musial ustawic flage przerwania bo juz nie pamietam czy AVR Studio robi to automatycznie po wpisaniu jakiejs danej do UDR.
    Pozdro
    Dexter
