Raspberry PI - Philips 23ITI HDMI - nie można wyświetlić trybu wideo
tmkd 16 Wrz 2016 17:25 2133 1
  • #1 15935405
    tmkd
    Cześć,
    po podłączeniu Raspbery do TV przez hdmi ( ten model :http://www.philips.pl/c-p/231T1SB_00/58-cm-23-cale-panoramiczny-t-line-1920-x-1080-full-hd/dane-techniczne) mam czarny obraz oraz na dole komunikat " Nie można wyswietlić trybu wideo". Czy macie pomysł co może być nie tak. Spędziłem już pół dnia na przeszukiwaniu internetu.
    mój /boot/config.txt wygląda tak:
    # For more options and information see
    # http://www.raspberrypi.org/documentation/configuration/config-txt.md
    # Some settings may impact device functionality. See link above for details
    # uncomment if you get no picture on HDMI for a default "safe" mode
    #hdmi_safe=1
    # uncomment this if your display has a black border of unused pixels visible
    # and your display can output without overscan
    #disable_overscan=1
    # uncomment the following to adjust overscan. Use positive numbers if console
    # goes off screen, and negative if there is too much border
    #overscan_left=16
    #overscan_right=16
    #overscan_top=16
    #overscan_bottom=16
    # uncomment to force a console size. By default it will be display's size minus
    # overscan.
    #framebuffer_width=1280
    #framebuffer_height=720
    # uncomment if hdmi display is not detected and composite is being output
    hdmi_force_hotplug=1
    # uncomment to force a specific HDMI mode (this will force VGA)
    hdmi_group=1
    hdmi_mode=16
    # uncomment to force a HDMI mode rather than DVI. This can make audio work in
    # DMT (computer monitor) modes
    hdmi_drive=2
    # uncomment to increase signal to HDMI, if you have interference, blanking, or
    # no display
    #config_hdmi_boost=9
    # uncomment for composite PAL
    #sdtv_mode=2
    #uncomment to overclock the arm. 700 MHz is the default.
    #arm_freq=800
    # Uncomment some or all of these to enable the optional hardware interfaces
    #dtparam=i2c_arm=on
    #dtparam=i2s=on
    #dtparam=spi=on
    # Uncomment this to enable the lirc-rpi module
    #dtoverlay=lirc-rpi
    # Additional overlays and parameters are documented /boot/overlays/README
    # Enable audio (loads snd_bcm2835)
    dtparam=audio=on
    edidparser pokazuje
    Enabling fuzzy format match...
    Parsing edid...
    HDMI:EDID version 1.3, 1 extensions, screen size 51x29 cm
    HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
    HDMI:EDID found monitor S/N descriptor tag 0xff
    HDMI:EDID found monitor name descriptor tag 0xfc
    HDMI:EDID monitor name is 231TE4L
    HDMI:EDID found monitor range descriptor tag 0xfd
    HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
    HDMI:EDID monitor range: vertical is 56-76 Hz, horizontal is 30-83 kHz, max pixel clock is 170 MHz
    HDMI:EDID monitor range does not support GTF
    HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
    HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
    HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
    HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
    HDMI:EDID standard timings block x 8: 0x8180 0101 0101 0101 0101 0101 0101 0101
    HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 0
    HDMI:EDID parsing v3 CEA extension 0
    HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
    HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
    HDMI:EDID found CEA detail timing format: 1920x1080p @ 24 Hz (32)
    HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
    HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
    HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
    HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
    HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
    HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
    HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
    HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
    HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
    HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
    HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
    HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
    HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
    HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
    HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
    HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
    HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20 bits
    HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
    HDMI:EDID found HDMI VSDB length 7
    HDMI:EDID HDMI VSDB has physical address 1.0.0.0
    HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
    HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
    HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
    HDMI:EDID HDMI VSDB has no latency information
    HDMI:EDID adding mandatory support for CEA (3) 720x480p @ 60Hz
    HDMI:EDID adding mandatory support for CEA (18) 720x576p @ 50Hz
    HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
    HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
    HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
    HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 66472)
    HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
    HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 135592)
    HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
    HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 149416)
    HDMI:EDID DMT mode (5) 640x480p @ 72 Hz with pixel clock 31 MHz has a score of 22118
    HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
    HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
    HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 5398248)
    HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
    HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
    HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
    HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3117160
    HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 3732360
    HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
    HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 4732360
    HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 4124532
    HDMI:EDID CEA mode (33) 1920x1080p @ 25 Hz with pixel clock 74 MHz has a score of 128680
    HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 149416
    HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 103643
    HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
    HDMI:EDID has HDMI support and audio support
    edid_parser exited with code 0
