tvc sharp LC-32LE144E main 32LE244_main BD Rev: 1.02 tylko czerwona dioda LED st
misterbinn 26 Kwi 2020 02:38 9195 16
Treść została przetłumaczona angielski » polski Zobacz oryginalną wersję tematu
  • #1 18647557
    misterbinn
    Poziom 7  
    Ocena: 7
    cześć wszystkim, w tym telewizorze czerwona dioda LED zawsze świeci światłem ciągłym i tv nie włącza się ani z przycisku włączania, ani z pilota, 5V są obecne, czy może to być problem z pamięcią flash lub inne problemy?
    dzięki
  • #3 18651478
    VINZA
    Ocena: 164
    Hello, check the output voltages from U2 and U3, they must be exact, otherwise replace the corresponding integrated. Many defects of these frames are to be attributed to these 2 ic.
    Here the wiring diagram with the exact voltages.
    • toshiba.pdf (267.55 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #4 18652321
    misterbinn
    Poziom 7  
    Ocena: 7
    hello, in fact I was thinking I give U2 and U3 the first one delivers 2.2v and the second 0v, I see if I can recover them from some card, I replace them and I update you
    thanks
  • #5 18652332
    bazi1962
    Ocena: 142
    Oczywiście, że może.
  • #6 18652720
    misterbinn
    Poziom 7  
    Ocena: 7
    in fact I also tried to reprogram the flash several times even replacing the chip but without results, then measuring the voltages I realized that U2 delivers 2.2v instead of 1.3v and U3 delivers 0v instead of 1.8v so first you need to restore the two voltages replacing both U2 and U3
  • #8 18655246
    misterbinn
    Poziom 7  
    Ocena: 7
    after removing U2 and U3 I checked the presence of any output short circuits but fortunately everything is normal, as soon as available I will replace them and update you
  • #9 18677990
    misterbinn
    Poziom 7  
    Ocena: 7
    hi, I replaced U2 and U3, now the voltages 1.3v and 1.8v are present, the TV only turns on that sometimes it freezes with a loud audio noise and noise on the image, it no longer responds to commands, in this phase it does not the 1.8v are present because the enable voltage is missing by disconnecting the mains plug and reattaching it it turns on and works normally, it has been on for several hours now it is ok, I think of a problem on the processor, possibly the main is to be replaced, let's see how it goes
  • #11 18678219
    misterbinn
    Poziom 7  
    Ocena: 7
    Can't find a file to flash via USB?
  • #13 18678653
    misterbinn
    Poziom 7  
    Ocena: 7
    update performed, is this enough or is it better to flash the eprom with the 8 mb bin file?
  • #15 18683081
    misterbinn
    Poziom 7  
    Ocena: 7
    I updated from the sharp site now okay, thanks for the advice
  • #16 20052434
    SimoneFerri
    zdarzyło mi się ic u4 na płycie głównej zwarł się przegrzał od spalenia
  • #17 20741466
    flashh
    Ocena: 30
    Podłącze się pod temat. Efekt że świeci tylko LED i żadnej reakcji na ON. Kupiłem W25Q64FVSIG i wrzucam już różne wsady ale bez efektu. Napięcia OK. Czy są jakieś innego tego typu usterki w tym modelu. O dziwo nic nie wskazywało że oryginalna pamięć się uszkodziła bo bez problemu ją zczytałem i zapisałem wsad.
    Może macie jakieś pomysły
Użytkownik zgłosił problem z telewizorem Sharp LC-32LE144E, który nie włącza się, a czerwona dioda LED świeci ciągłym światłem. Po sprawdzeniu napięć, okazało się, że U2 dostarcza 2.2V zamiast 1.3V, a U3 0V zamiast 1.8V. Po wymianie tych układów, napięcia wróciły do normy, jednak telewizor czasami się zawieszał. Użytkownik zaktualizował oprogramowanie, co poprawiło działanie, ale nadal występują sporadyczne problemy. Inni użytkownicy sugerowali sprawdzenie zwarć oraz wymianę pamięci flash, a także podzielili się linkami do zasobów dotyczących aktualizacji oprogramowania.
