Gdzie znaleźć PCB do Universal Ezoflash Programmer ver6.3?
tps_star 21 Lis 2005 12:33 4906 9
  • #1 2011319
    tps_star
    hi
    i need pcb for universal ezoflash programmer ver6.3
    please helpme
    best regard
  • #2 2013850
    EZoSat
    Latest ezoflash+ version v4.4, www.ezoflash.com
  • #3 2014285
    tps_star
    thancks
    i have ezoflash ver4.4
    but i need universal ezoflash ver6.3 (smd version epsilon)
    and adapter tsop48 16bit
    please helpme
  • #4 2021928
    tps_star
    please helpme
  • #5 2784320
    curdeballans
    Poziom 30  
    Ocena: 453
    For my information -is it the same or similar ezoflash and universal flash programmer by epsilon?
    Adapters are the same? It can be used in both device?
  • #6 2784544
    EZoSat
    schematic equal generally.
    epsilon - smd chips, adapters interface 2 sockets 2x10
    ezoflash - single side, adapters interface (EZoBus)- socket 2x16 + socket 1x5
    Not compatible. Each programmer has own adapters.
  • #7 2784554
    curdeballans
    Poziom 30  
    Ocena: 453
    thank you , it's clear enough.
  • #8 2787271
    curdeballans
    Poziom 30  
    Ocena: 453
    Is it possible to make connector adapter -universal flash programmer to ezoflash adapters?
    I know it's simple thinking about cost reduction.
  • #9 2788140
    EZoSat
    EZoFlash is original design, docs are available for all adapters.
    Unfortunately adapted universal flash programmer is commercial, not my design, no doc's available. At first you have to be sure on universal fp 2 connectors correct pinout. I can't help to you.
  • #10 2788196
    curdeballans
    Poziom 30  
    Ocena: 453
    Thanks for answer.
    Now I'm starting building ezoflash programmer from the begining because I've found complete documentation all of adapters. It is usefull. Epsilon is only commercials and it is not good for electronić improvement of our electronic minds.
    Thanks again.
✨ Poszukiwany jest PCB do Universal Ezoflash Programmer w wersji 6.3 (SMD wersja Epsilon) oraz adapter TSOP48 16-bit. Dyskusja wyjaśnia, że Universal Ezoflash Programmer i standardowy Ezoflash to różne urządzenia z odmiennymi interfejsami adapterów. Universal Ezoflash (Epsilon) wykorzystuje dwa gniazda 2x10 dla adapterów, natomiast Ezoflash posiada interfejs EZoBus z gniazdami 2x16 i 1x5. Schematy są podobne, ale adaptery nie są kompatybilne między tymi programatorami. Dokumentacja adapterów Ezoflash jest dostępna i umożliwia samodzielne budowanie programatora, natomiast Universal Ezoflash jest produktem komercyjnym bez publicznej dokumentacji, co utrudnia modyfikacje i adaptacje. Próby stworzenia adaptera łączącego oba systemy są utrudnione ze względu na różnice w pinoutach i braku dokumentacji Universal Ezoflash.
