[Rozwiązano] Toshiba 49SMRT19: Nieustające Miganie LED przy Panelu VES490UNDL-2D-N11
yokoono51 30 Gru 2023 13:07 651 9
  • #1 20883014
    yokoono51
    Ocena: 286
    Mark: Toshiba
    Model: 49SMRT19
    Chassis (main board, components): 17MB211S
    LCD Screen/Panel (if exist): VES490UNDL-2D-N11
    More informations:
    Hello dear friends.
    I also have a TOSHIBA 49SMRT19. On the net it says that it is BARSBET. I have never met anything like this before. It has a 17MB211S motherboard and a VES490UNDL-2D-N11 panel. The stby LED flashes permanently. I don't have anything useful in my archive. Can I find something with you? Thanks in advance.
  • #3 20883196
    yokoono51
    Ocena: 286
    1. Has anyone tried to repair the motherboard in the TV. There are traces of flux near the flash memory.
    2. The indicated software is not supported by the motherboard. The stby LED flashes quickly but permanently.
    3. It has t-con 6870c-0532b. The voltages on the t-con are correct. It was replaced with another trial one.
    4. I replaced the motherboard with another 17MB211S. Missing osd and image.
    5. I rewrote the new motherboard with the above software. Missing osd and image.
    6. I tried to rewrite the panel profile (I have the correct profile) without seeing the image. I didn't succeed but I'll keep trying.
    7. The panel does not appear to be broken and has no chipped corners.
  • #4 20883272
    jeloi
    Ocena: 587
    Replacement ribbon cable MB--matrix?
    DC converter problem
  • #5 20883297
    yokoono51
    Ocena: 286
    1. I have not yet replaced the ribbon between the main and the t-con.
    2. When connecting and disconnecting the 2 ribbons between the t-con and the panel, the image is black, without osd, on the connected side.
    L.E. It is possible, since troubleshooting has been attempted, that there was another motherboard model in it. Nothing useful can be found on Google.
  • #6 20883678
    badael
    Ocena: 206
    Did you put the panel file in the PQ folder?
    There is this USB
    Vestel_55FD7000T_17MB211S_VES550UNDL-2D-N11_V0.38.2.0
    and (I don't know for which panel)
    17MB211_core
  • #7 20883734
    yokoono51
    Ocena: 286
    Yes. I put the files in the PQ folder. I know how to proceed. I rewrote the flash memory with more bins but still no image or osd. I want to try everything possible before saying that it is a panel defect.
    I have a software in the archive (17MB211S panel VES550UNDL-2D-N11) for the stick but it does not solve the problem.
  • #8 20884353
    jeloi
    Ocena: 587
    Post ptf.ptf file so I can check which panel it is with
    • Toshiba 49SMRT19: Nieustające Miganie LED przy Panelu VES490UNDL-2D-N11 IMG_20231231_072112.jpg (4.87 MB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #9 20884730
    yokoono51
    Ocena: 286
    The problem is that the TV does not turn on. Has anyone tried to repair it. I'm not even convinced that the motherboard is identical to what the manufacturer put. I ordered another motherboard, another model, and which I know precisely fits this panel. Until then, I wish you all a HAPPY NEW YEAR.
  • #10 20890635
    yokoono51
    Ocena: 286
    Conclusion: defective panel. It came to dismemberment. Thank you all for your help. Happy New Year.
✨ Użytkownik posiada telewizor Toshiba 49SMRT19 z płytą główną 17MB211S i panelem VES490UNDL-2D-N11, który ma problem z migającą diodą LED w trybie czuwania. W trakcie dyskusji poruszono kwestie związane z próbami naprawy płyty głównej, wymiany kabli taśmowych oraz problemami z oprogramowaniem. Użytkownik próbował różnych metod, w tym wymiany płyty głównej i przepisania profilu panelu, jednak nie uzyskał obrazu ani menu OSD. Ostatecznie stwierdzono, że problem może leżeć w uszkodzeniu panelu, co potwierdzono po rozmontowaniu urządzenia.
