Telefunken TE32269B40Y2D Pannello VES315WNDB-2D-N21 - mainboard 17mb211s
smartino 04 Lut 2024 16:41 537 6
  • #1 20944614
    smartino
    I have changed mainboard. It is work with new spi 25Q16 flashed with file for this panel. Tv ok but image solarizated. In service mode is memorize other panel because the mainboard is different. Help me.
    yokoono51
    Poziom 29  
    Ocena: 321
    You have the panel profile below. I think you know the installation procedure.
  • #3 20944662
    smartino
    I have not profile panel. I have flashed SPI with file for this panel. But i think in nand flash there is different panel. I think to change with old nand flash? O change panel profile with usb but I don't know the procedure.
    Added after 10 [minutes]:
    >>20944637
    I have got your 2 files. May you please tell me how to install these files? Thank you.
    yokoono51
    Poziom 29  
    Ocena: 321
    1, Create a folder on the stick called pq. Put the 2 files in the folder
    2. Turn on the TV and insert the USB stick
    3. Type menu 4725
    4. Go to USB Operations and type OK.
    5. Exit the menu and turn off the TV from the remote control
    6. Wait until the LED on the TV stops flashing and unplug the TV.
    7. When the stby light has gone out, remove the stick and turn on the TV.
    If necessary, repeat the operation. Try a stick with the smallest capacity.
  • #5 20944750
    smartino
    Thank you. I'm gonna try and let you know shortly. Give me a few minutes.
    Added after 23 [minutes]:
    >>20944732
    Hi, I executed your procedure step by step and now the TV shows just a black screen, the black light. The only key that works on the remote control is on/off. I cannot access the menu anymore. What should I do now?
    yokoono51
    Poziom 29  
    Ocena: 321
    Thousands of apologies. MY FAULT. I gave the profile for another panel. If you have memorized the installation procedure, you can rewrite the profile without seeing the panel. If you have a stick with an LED, you can also see when the stick is active. If you fail, rewrite the bin again on 25Q16 and repeat the operation.
    Rewrite profile without screen image:
    MENU/4725/up arrow once/ok (wait 5 sec.)/exit/power (to turn off the TV).
    L.E I think you changed the panel code after posting.
    The correct profile:
    • 17MB211S panel VES315WNDB-2D-N21.rar (43.72 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #7 20945024
    smartino
    It worked! Thanks a lot! You are a genius.
Użytkownik wymienił płytę główną w telewizorze Telefunken TE32269B40Y2D, jednak obraz jest zniekształcony (solarizacja). Po zainstalowaniu nowego układu SPI 25Q16 z plikiem dla tego panelu, telewizor działa, ale w trybie serwisowym zapamiętuje inny panel. Użytkownik nie miał profilu panelu i rozważał wymianę pamięci NAND lub aktualizację profilu przez USB. Po uzyskaniu instrukcji dotyczących instalacji plików na USB, użytkownik napotkał problem z czarnym ekranem. Ostatecznie, po poprawnym wgraniu profilu, telewizor zaczął działać prawidłowo.
