Skoda Rapid 1.4TSI CZCA - błąd P2177, zubożona mieszanka na biegu jałowym
nikor11 07 Lut 2025 07:48 1488 2
  • #1 21428378
    nikor11
    Ocena: 43
    Skoda Rapid 1.4TSI na pasku kod silnika. Sporadycznie raz na ok 1tyś km pojawia się błąd P2177 (system Too Lean Off Idle Bank 1 - zubożona dawka paliwa na biegu jałowym)
    Auto jeździ poprawnie.
    W czym może być problem?
  • #2 21428386
  • #3 21537984
    nikor11
    Ocena: 43
    powracam z tematem, usterka pojawia się tylko na paliwie 95.
    Log z VCDS
    4 Faults Found:
    17132 - Oxygen (Lambda) Sensor B1 S1
    P0133 00 [01100000] - Response too Slow
    Intermittent - Not Confirmed - Tested Since Memory Clear
    2821 - Bank 1; System Too Lean off Idle
    P2177 00 [11101101] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 335197 km
    Date: 2025.04.24
    Time: 06:42:40
    Engine RPM: 1941.00 /min
    Normed load value: 33.3 %
    Vehicle speed: 57 km/h
    Coolant temperature: 95 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.512 V
    Unlearning counter according OBD: 40
    Long-term fuel trim bank 1 at idle: 0.61 %
    Oxygen control: adaptation value at partial load: bank 1: 1.25000
    Short term adaptation of mixture formation bank 1: -2.3 %
    Outside temperature: 12 °C
    Oxygen sensor test: bank 1: delta lambda: -0.00232
    Fuel level: 9.00 l
    17138 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
    P0141 00 [01100101] - Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 334960 km
    Date: 2025.04.19
    Time: 12:44:29
    Engine RPM: 2183.50 /min
    Normed load value: 46.7 %
    Vehicle speed: 81 km/h
    Coolant temperature: 96 °C
    Intake air temperature: 29 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 13.853 V
    Exh mss flw bef main cat conv bank 1 filtered: 83.8 kg/h
    Exhaust gas temperature before catalytic converter: 589.00 °C
    Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120: 1024.000 Ohm
    Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister: 1
    Oxygen sensor test: bank 1: delta lambda: -0.00183
    Short term adaptation of mixture formation bank 1: 0.0 %
    O2 sensor 2: B1: internal resistance limit: 796 Ohm
    17136 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
    P2096 00 [11101101] - Too Lean
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 335327 km
    Date: 2025.05.02
    Time: 11:43:36
    Engine RPM: 2319.50 /min
    Normed load value: 32.9 %
    Vehicle speed: 104 km/h
    Intake air temperature: 34 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 14.536 V
    Long-term fuel trim bank 1 at idle: 1.17 %
    Oxygen_sensor_bank_1_sensor_1_cell_resistance_adapted_value: -16.8
    Oxygen sensor test: bank 1: delta lambda: -0.00247
    Ox_sensor_bank_1_sensor_1_char_line_adapted_value_lean_range: 1.27
    Ox_sensor_bank_1_sensor_1_char_line_adapted_value_rich_range: 0.84
    Readiness: 0000 0001
