Muszę przetłumaczyć na polski pierwsze 6 stron datasheet at90s2313. mam problem z paroma słówkami:
utilizes (w zdaniu Utilizes the AVR RISC Architecture)
embedded control aplications
they will source current (cale zdanie to : Port D pins that are externally pulled low will source current if the pull-up resistors are activated)
external clock drive configuration (nie rozumiem tego "drive")
constant table look-up function
as the Data Space locations following those of the Register File, $20-$5F( cale zdanie to: The I/O memory can be accessed directly or as the Data Space locations following those of the Register File, $20-$5F)
Prosze o pomoc
Prosze o pomoc
