nie wiem czy dobrze to interpertuje bo ten belkot z babelfisha jest ciezki do zrozumienia:)
"4. Videokarta works normally, but conveyors are not included, i.e., RivaTuner it shows that them in you four instead of eight. In this case it is possible to make the following: to remove radiator from videokarty and near the processor to find the group of resistors, shown on the photo below.
This photo made from videokarty GeForce 6600, i.e., resistors on it they are soldered in a correct manner. Specifically, so one must for you arrange them on its videokarte. To solder it is possible by the method given above, but more accurately, since there is a risk to randomly unsolder the resistor established by a number. After this, it is necessary to repeat the process of the piercing of videokarty.
This method can solve not only this problem, but also soak with the problems with the acceleration."
http://babelfish.altavista.com/babelfish/trur...%2f%2fwww.overclockers.ru%2flab%2f19694.shtml
nie mowie zebys probowal odrazu dlubac z lutownica ale skoro rozmontowales radiator to mozesz sie przyjzec tym rezystorom moze zauwazysz tam cos dziwnego co moze byc ta blokada np jakis dodatkowy rezystor lub jego brak
sluszne spostrzezenie ze sa 8 potokowe A4 i to ze ktos twierdzi ze odblokowal A4 sklanialo by mnie do podejzen ze blokada nie jest moze w samym gpu a na plytce karty umieszczona juz przez producenta karty na wniosek nvidi w kartach z A4.ale to tylko spekulacje;)
