Szukam artykułu z Elektora 6-8.2000 o przedwzmacniaczu na lampach ECL86
adigrzelczak 06 Kwi 2006 22:09 2451 5
  • #1 2501036
    adigrzelczak
    Ocena: 12
    Czy może mnie ktoś poratować artykułem z Elektora 6,7,8.2000?Chodzi o przedwzmacniacz na lampkach ecl86.
  • #2 2501088
    _PREDATOR_
    Ocena: 2312
    Powiedz mi jeszcze gdzie on jest :P ?
    Elektor UK
    | 2000 |
    DE || UK
    2000
    June
    Intelligent Door Lock
    Kinetic Auto Relay
    One-Wire Spy
    Make Your Own Mini DVDs
    Magnetic Card Reader
    Valve Preamplifier (1)
    Electronics OnLine: Tiny Webservers
    PC Interface for CAN Bus
    Wireless Application Protocol (WAP)
    DVD - The Megastore
    OCX Instruction Set (Lego)
    Lego Robotics Invention System (3)
    July/August
    Transmitter for Fibre-Optic IR Extender
    ESR Measurements
    Electronic Stethoscope
    Heatsink Calculations
    Precision Electroscope
    Adapter for SB Live! Player 1024
    3-volts Car Adapter
    Noise-Driven Sound Generator
    DIY Front Panels
    Receiver for Fibre-Optic IR Extender
    Noise Injector
    Bipolar Stepper Motor Control
    Compact Switching Step-Down Converter
    White LED Lamp
    Low-Noise Microphone Amplifier
    Power-On Sequencer
    5-V Voltage Converter
    JAL for the PIC84
    Simple Touch Pad Dimmer
    8 Channel D/I Card for RS232
    PC 12-V Adapter
    2 × Single = 1 × Dual
    AF Amplifier with Up/Down Volume Setting
    Simple RF Detector for 2m
    Max. Temp. Detector for Fan Controller
    Two-Position Dimmer
    10 to 100 MHz Oscillator
    0-44 dB RF Attenuator
    Video-Out Coupling
    Baud Rate Generator
    Simple MD Cartridge Preamplifier
    High-Side Current Measurements
    One Transistor Radio
    Stepper Motor Generator
    Video Correction for Pinnacle Studio MP10
    Series/Parallel Equivalent Circuits in Excel
    Optical S/PDIF Output
    Measuring Inductors
    Simple mV Source
    Simple Frequency Doubler
    Serial-to-Parallel Converter
    Battery Discharger
    8 Channel D/O Card for RS232
    Infra-Red Light Barrier
    2 × Dual = 1 × Quad
    Mains Powered!
    Voltage Reference for Battery Powered Circuits
    Diode Radio for Low Impedance Headphones
    Single-Opamp 10-MHz Bandpass Filter
    Analogue Optical Coupler
    Single-Chip Switch Debouncer
    Switch ICs with Adjustable Current Limiting
    Opto-Isolated RS232 Interface
    Universal Symmetric Power Supply
    Sensitive Overload Sensor
    20th-Order Measurement Filter
    E12 Series in Excel
    PC Battery Charger
    Coaxial S/PDIF Output
    Pressure Switch
    Light that Heats
    Valve Preamplifier (2)
    I/U Curve Tracer
    Signal Module for EEDTS Pro
    Surge Protection
    Make Your Own Front Panels
    Correction: 537 ‘Lite’ Computer
    Correction: BASIC-537
    Correction: Low-Impact Muscle Stimulator
    Correction: MP3 Basics & Chipsets
    Correction: Working with a Touch Screen
    Curve Plotting with HP-GL/2
    Implementing the I2C Bus
    8-Bit I/O Port
    MCP120/130
    Audio Attenuator
    Car Burglar Alarm
    September
    Letter: The Debate Continues...
    Letter: Valve Preamplifier
    Letter: Working with a Touch Screen
    PC Serial Peripheral Design (1)
    RJ45 Network Cable Tester
    Modern Surround-Sound Systems
    PIC 17C Processor Board
    ‘OSCAR’ MP3 Player (1)
    USB Interface
    The Universal Serial Bus (USB) (1)
    Märklin Digital Model Train Control (1)
    GSM Call Indicators
    COP8 Design Competition Results
    Electronics Online: Web Connected Organs
    Valve Preamplifier (2a)
    PIC17C75x Instruction Set (Microchip)
    Konto firmowe:
    ELMAX
    Małe Przedmieście 20/4, Olesno, 46-300 | Tel.: 535 XXX XXX (Pokaż) | Strona WWW: http://ftp.interka.pl/~elmax/about.php
  • #4 2501114
    _PREDATOR_
    Ocena: 2312
    I ja mam tego szukać (mamooo ratuj)?
    Olera, nie dziś, jutro, podaj na pw maila.
    Konto firmowe:
    ELMAX
  • #5 2501166
    adigrzelczak
    Ocena: 12
    wydaje mi sie ze to jest to:
    ale moge sie mylic:)
    _PREDATOR_
    Ocena: 2312
    To i ja zauważyłem, zgadza się, wysyłam wszystkie 3 części na maila, odpisz w nim, czy trafiony/ zatopiony :P
    Poszło, ok. 3 M
    A mogliśmy się uczyć :D :P :D
    Konto firmowe:
    ELMAX
