HP Laser Jet 5 "Błąd 51" drukuje czarne strony.
marek694 14 Sie 2006 16:55 1571 2
  • #1 2915059
    marek694
    Ocena: 7
    HP Laser Jet 5 "Błąd 51" drukuje czarne strony.ktoś wie co to mogło by być?
    marioq4
    Ocena: 10
    Table 7-11 51 ERROR Beam Detect Checks
    ChecksAction
    1. Are all connectors on the DC Inspect connectors and wiring. Reseat or
    Controller properly seated? replace cables if necessary.
    2. Is the Laser/Scanner Assembly A defective Laser/Scanner Assembly can
    Defective? cause a 51 ERROR by spinning the
    scanning mirror at the wrong speed.
    Replace the Laser/Scanner Assembly.
    3. Is the DC Controller Defective?Replace the DC Controller.
    4. Has the printer been moved from a Allow the printer to stand 6 hours until
    cold to a warm room? any condensation has dissipated.To jest opis z serwisowki to oznacza że chyba padl laser
  • #3 2921330
    marek694
    Ocena: 7
    dzięki to było to własnie:) padniety laser.dzieki wielkie. zamykam temat
