Płyta głowna ASRock P4S55FX+, nowy BIOS mam tylko nie wiem jak zaktualizowac, ponizej jest sposob jaki podaja na stronie producenta, tam pisze zeby stworzyc bootowalny dysk systemowy, jak to zrobic w XP? Moze mi ktos opisac krok po kroku o aktualizacji BIOSU?
Cytat:BIOS Update Utility
ASRFLASH.EXE: The Flash Memory Writer utility is included in the WinZip format of BIOS file. It updates the BIOS by uploading a new BIOS file to the programmable flash ROM chip on the motherboard. To determine the BIOS version of your motherboard, press <F2> to enter the BIOS setup utility during bootup, and check the BIOS version from the Main menu. Larger numbers represent a newer BIOS file. This utility works only in DOS mode. (How do I check the BIOS version?)
1.The BIOS vision can be found during system boot up.
2.The BIOS vision can be found in BIOS setup utility.
The Flash Memory Writer utility can not be suitable for all ASRock motherboards. Please use the Flash utility which is included in each BIOS file to update its BIOS. Also ASRock motherboard MUST use ASRock's Flash utility to update BIOS, those uncertified BIOS flashing tools will cause motherboard damage.
Updating BIOS Procedures
1.
Create a bootable system floppy disk.
2.
Download an updated ASRock BIOS file (WinZip format with .zip file extension) from the web site, unzip the BIOS file and save both ASRFLASH.EXE utility and BIOS file to the disk you created in step 1.
3.
Boot from the disk you created in step 2.
4.
At the "A:\" prompt, type ASRFLASH, hit space bar once, and type BIOS file name then press <Enter>. For example: A:\ASRFLASH K7S41GX2.00 <Enter> then you will see a message "Please wait for BIOS loading ROM".
5.
After 30 seconds, you will see the message "Flash ROM Update Completed - Pass", then you have finished upgrading the BIOS.
6.
After finishing upgrading the BIOS, please remove the floppy disk. Restart your system and press <F2> to enter the BIOS setup utility during boot up.
7.
In Exit menu, please select "Load Default Settings" and press <Enter> to continue.
8.
Select "Exit Saving Changes" and press <Enter> to exit the BIOS setup utility.
9.
Now, system is booting up with new BIOS.
Notice
If you encounter problems while updating the new BIOS, DO NOT turn off your system since this corrupt BIOS might cause your system failed to boot up. Just repeat the process, and if the problem still persists, update the original BIOS file. If the Flash Memory Writer utility was not able to successfully update a complete BIOS file, your system may not be able to boot up. If this happens, your system will need service.
