Jak naprawić 3 bad sectory na dysku Seagate ST380023A?
Slawek1710 08 Paź 2006 15:53 1752 1
  • #1 3097207
    Slawek1710
    Witam mam problem z tym dyskiem poniżej jest raport z programu SeaTools są tam 3 bad sectory czy ktoś może wie jak je naprawić SeaTools Desktop v3.02.04
    Copyright (c) 2005 Kroll Ontrack Inc.
    10/8/2006 @ 3:26 PM
    The following information has been generated by SeaTools Desktop. Use
    this information to help you recognize and resolve potential data access
    problems.
    System Information:
    BIOS Date 05/02/06
    Conventional Memory size 627 K
    Extended Memory size 58532 K
    IO Channel type PCI
    Drive Information:
    SIZE MODEL
    80 GB ST380023A
    Serial Number = 3KB07Q9K
    Int13 Num = 80, PHYS CHS = 16383x16x63.
    ParmTable CHS, Rsvd = 9729x255x63
    PARTITION CYLINDER SIZE
    # Type Start End MB
    Diagnostic Results:
    ATA Full Test Result: Failed
    Results from Seagate's DiagATA/SCSI:
    DIAGATA.EXE Version 3.08.50629ML
    Copyright (c) 2002-2005 by Seagate Technology LLC. All rights reserved.
    Timer Resolution: 0.000122
    Long Test Begin: 08-Oct-2006 14:49:35
    Cable Test - 0 Errors
    Buffer Test - 0 Errors
    Identify Data
    Model Number: ST380023A
    Serial Number: 3KB07Q9K
    Firmware Revision: 3.31
    Default CHS: 16383-16-63
    Current CHS: 16383-16-63
    Current Capacity: 16514064 Sectors
    Total Capacity: 156301488 Sectors
    Conductor Cable Reported
    ID Method: Jumper
    SMART Enabled
    SMART Check: Passed
    Full Scan (0 to 156301488) - Errors
    |LBA |Error Register|
    |156301485 |10h |
    |156301486 |10h |
    |156301487 |10h |
    Long Test Failed: 08-Oct-2006 15:25:47
    SMART Disabled
    End results from Seagate's DiagATA/SCSI
    The Following Sectors MAY be damaged
    LBA: 156301485
    STATUS: Write-reallocation SKIPPED
    USAGE: Not in use
    LBA: 156301486
    USAGE: Not in use
    LBA: 156301487
    USAGE: Not in use
    File Structure Test Result:
    Recommendation:
    If you are not experiencing data loss and SeaTools reports File
    System Structure errors, they may be caused by a lock-up or
    failure to shutdown Windows correctly. Many times, these errors
    may be repaired through normal system maintenance which
    includes using the Windows provided "Defrag" and
    "Scandisk / Chkdsk / Error Checking" utilities.
    If you are experiencing a hardware error, you should isolate
    the cause and replace the failing component. If you are unsure how
    to proceed with repairs, contact a computer professional. After
    completing any maintenance tasks, run SeaTools again to
    verify that all errors have been repaired. If errors continue to
    occur, the system may not be stable. Again, contact a computer
    professional.
    If you have experienced a data loss, cease drive operation
    immediately. Professional data recovery service is the best
    option to recover your data.
    Moderowany przez TONI_2003:
    Zmieniłem temat postu!
    ... nie krzycz , nie używaj Caps Locka !
  • #2 3097580
    tronic1
    Spec od komputerów
    Ocena: 1109
    Przecież Sea Tools sugeruje ci co należy zrobić.
    Jak nie znasz angielskiego to znajdziesz w sieci darmowy translator.
    Jeśli na dysku masz dane na których ci zależy to zabezpiecz je przegrywając na inny dysk lub płytę CD,DVD.
    Poza tym na tym forum jest b.dużo na ten temat, wystarczy poszukać.
