SeTool v0.91380049 – darmowy unlock db2010 RED CID49 przez USB, nowe funkcje
Gsm Libertus 08 Gru 2006 19:57 1680 3
  • #1 3309719
    Gsm Libertus
    Ocena: 28
    Nie wiem czy dobrze widzę, ale wydaje mi się że SeTool robi loka z db2010 za FREE
    http://mobile-files.com/forum/showthread.php?t=17423&page=12
    GUI v0.91380049
    some stable ( ) release and some NEW features.
    - fixup for some db2020 mobiles booting (err:36 and so on)
    - fixup for some sibley-based (w300/k310/k510/w300/z550/w810) flash break
    - new feature. red cid49 phones (db2000/db2010) can now be flashed via USB with ENORMOUS FAST speed using usual dcu60 cable (or miniusb for k600/z800). FROM NOW NO ONE CAN SAY "my XXX box flashing faster than yours setool2" supported ONLY RED CID 49 PHONES.
    there is several restrictions.
    first.
    UNLOCK is working. BUT if yours gdfs is damaged (rewrited from other phone) - you REQUIRED to use com/ufs connections to repair security values.
    second.
    IMEI change not working because of same reason.
    third.
    EROM must be intact in order for USB flashing work.
    fourth.
    no more restriction.
    some timings:
    fullflash of w810 phone - 360 seconds. (about 700 by uart)
    fullflash of w900 phone - 733 seconds. (about 1400 by uart)
    great thx for irritating testing goes to : vasilius, lider, sebagsm
    ps.
    of course - that feature will be immediately copied by other stealers.
    fuck them. do your own or insert my copyrights.
    well. now you CAN NOT do "you own" - i was first and you are stealers
    P.S Dzisiejszy Update
  • #2 3310169
    djn
    Ocena: 13
    chyba zle widzisz bo ja tu nie widze nic o lockach w db 2020...
    moze napisz, w ktorym miejscu o tym pisze:)
  • #4 3310309
    Gsm Libertus
    Ocena: 28
    Dzięki.Temat do zamknięcia
