No i stalo sie SETool odblokowuje CID52, poniżej wersja w języku polskim, oto cale info:
Q: How to PERMANENT unlock from network DB2020/DB2012/DB2001/PNX5230 phone ?
A:
first, download latest version, special server support started from v0.913902.
select USB as interface. that is REQUIRED.
select phone model
settings - check "use server for csca unlock/flash", "do full unlock instead of usercode reset", fill your login details.
back to semc tab, press unlock, attach phone with pressed "C" buttons.
if you have enough credits - you will receive next message
"SIGNATURE QUEUED FOR CALCULATION, CHECK BACK LATER"
(that means signature is added to calculation queue. calculation can take up to 3 days.
if after 3 days (72 hours) signature will NOT be calculated - credits will be automatically returned
when you press "info" or add another phone to queue.)
(if you receive next message "QUEUE FULL, CHECK BACK LATER",
that means all slots for calculations filled up and you need try again later)
now - leave that phone aside for some time and check back periodically
(NOT each 5 min , but each 60 min )
if signature is calculated - you will receive 'SUCCESS' response, otherwise you will receive
"%YOUR_IMEI% ALREADY IN QUEUE" - that means signature is in calculation queue.
if calculation is success, then signature will be saved in backup\%imei% folder in your setool2 directory.
next, backup will be created so you will be able to restore phone if something will go wrong
(hardly believe, but who knows...)
next, you will be prompted to detach phone and turn it on.
do so.
detach phone.
turn it on FULLY
phone will be on 5 locks, that is normal.
connect phone to usb.
if phone will ask you switch to phone mode - switch to phone mode.
it can ask you for drivers,if you not installed them previously.
install all needed phone drivers (phones.rar on support area)
be SURE that you install all drivers correctly.
press "testpoint ok"
note: in latest setool2 version phone will be searched constantly on all
available comports until it will be found. So, you not need to press "TESTPOINT OK"
procedure will continue,phone will be switched off and unlocked.
remember, if something will go wrong - you have a backup of security units.
cost of DB2020 unlock is 10 credits. it divided into 2 steps:
signature calculation 6 credits (charged once), phone unlock - 4 credits
(charged once, if by accident, server is recharging while you executing unlock, credits NOT charged)
as usual, credits will NOT be recovered in case of connection failures. (error 10054,10060).
that is NOT terms for discussion.
NOTE! there is STILL REMAIN USERCODE RESET FOR DB2020/DB2012/PNX5230.
it will work, if you UNCHECK option "do full unlock instead of usercode reset" and press UNLOCK.
note: i STRONGLY recommend you to instal PHONE drivers BEFORE starting unlock procedure.
POLSKA WERSJA:
Jak odblokować telefony serii DB2020/DB2012/DB2001/PNX5230 ?
Pierwsze sciągnij najnowszą wersje, specjalny serwer obslugiwany jest juz od wersji v0.913902.
Wybierz USB jako interfejs. KONIECZNIE !!!
Wybierz model telefonu
W zakladce SETTINGS - zaznacz "use server for csca unlock/flash", "do full unlock instead of usercode reset", wypełnij dane (login i pass)
Spowrotem przelacz na zakladke SEMC, wcisnij UNLOCK, podlacz telefon z wcisnietym przyciskiem "C".
Jeśli masz wystarczającą ilość kredytow - zobaczysz napis
(znaczy że sygnagtura zostala dodan do kolejki do kalkulacji. Kalkulacja może zająć do 3 dni.
Jesli po 3 dniach (72 godziny) sygnatura NIE ZOSTANIE przekalkulowana - kredyty zostaną automatycznie zwrocone kiedy tylko dasz "INFO" lub dodasz inny telefon do kolejki.)
(Jesli zobaczysz napis "QUEUE FULL, CHECK BACK LATER",
oznacza że wszystkie sloty do kalkulacji zostaly zajęte i musisz sprobować pozniej)
Teraz - zostaw teraz telefon na boku, sprawdz ponownie po pewnym czasie (NIE co 5min, tylko co 60min
Jeśli sygnatura zostanie przeliczona - zobaczysz napis 'SUCCESS', w przeciwnym wypadku zobaczysz "%YOUR_IMEI% ALREADY IN QUEUE" - co oznacza ze sygnatura jest w kolejce.
Jesli kalkulacja bedzie przeliczona if calculation is success, wtedy sygnatura zostanie zapisana do katalogu backup\%imei% w twoim katalogu SETool2.
Następnie, backup zostanie utworzony, wiec mozesz pozniej przywrocic telefon jesli poszlo by cos nie tak
Kolejno, będziesz poproszony o odlaczenie telefonu i wlaczenie go.
Zrob to !!.
- Odlacz telefon.
- Wlacz go CALKOWICIE !!.
- Telefon bedzie mial 5lockow, bez obaw to normalne.
- Podlacz telefon do USB.
- Jesli telefon poprosi o wlaczenie w PHONE MODE - wlacz go w PHONE MODE
- Może poprosić o zainstalowanie sterownikow, jesli nie zrobiles tego wczesniej.
- Zaintaluj wszystkie potrzebne sterowniki (phones.rar - z supportu)
- UPEWNIJ SIE ze wszystkie sterowniki sa zainstalowane poprawnie.
- Nacisnij "testpoint ok"
W ostatniej wersji SETTool2 telefon bedzie szukany na wszystkich portach com dopoki nie zostanie znaleziony. Więc nie ma potrzeby naciskania "TESTPOINT OK"
Procedura będzie kontynuowana, telefon zostanie wylaczony i odblokowany
PAMIĘTAJ, jeśli pojdzie cos nie tak mozesz przywrocic backup.
Koszt odblokowania DB2020 wynosi 10 kredytow. Jest podzielony na dwa kroki:
Kalkulacja sygnatury - 6 kredyty (pobierane raz)
Odblokowanie - 4 kredyty
(pobierane raz - jesli przez przypadek, serwer będzie przeciazony podczas unlocka, kredyty nie będa pobierane)
Jak zawsze, kredyty nie będa zwracane w przypadku bledow w polaczenie z internetem (bledy typu 10054,10060).
NIE PODLEGA TO DYSKUSJI !!
UWAGA: ZDECYDOWANIE ZALECANE JEST ZAINSTALOWANIE STEROWNIKOW DO TELEFONU PRZED PROCEDURA ODBLOKOWANIA.
Tresć i cala wersja polska zostala przekopiowana z forum gsmplanet.net
A:
select phone model
do so.
detach phone.
turn it on FULLY
POLSKA WERSJA:
Zrob to !!.
- Odlacz telefon.
