W200i na kablu setoola widoczny na dcu60 nie - problem
fokus73 11 Gru 2007 11:44 4616 16
  • #1 4575633
    fokus73
    Ocena: 15
    W czasie wgrywania mapy Davincim wystapił problem i teraz juz nie widac telefonu na kablu dcu-60.
    (#) Service Client v22.33
    New device connected on USBF1
    Device Identification Started...
    The IMEI of the product is:
    354269011xxxxx
    Model info:
    W200i
    Software info:
    R4GB001 prgCXC1250719_GENERIC_ME R4GB001
    Customization info:
    CDA102738/6 R2A
    cxc1250728 R4GB001
    CENT_EUROPE
    SIM Lock Staus: LOCKED
    Identification Time - 00:00:13
    Done!
    Service Selection Started...
    Getting Unlock Script From Server For: W200i / CID51 / Red...
    Downloaded 3Kb In 0 sec
    SELECTED: Unlock SIMLOCKs W200i / CID51 / Red
    Script Execution Started...
    Checking Files...
    Starting up...
    Script initialization. Please wait...
    61205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738
    Loading CsLoader...
    061027 1446 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B004
    Authentification...
    Starting GDFS...
    Reading GDFS Data. It Can Take A While. Please Wait...
    Got Units 814 / 1161
    Got Units 1128 / 1161
    Got Units 1161 / 1161
    GDFS Data Read OK!
    Connecting Server. Please Wait...
    Unlock Step 2: Writing Security Map...
    Failed To Write: 0x01 0x0725 Size 0x0000040E ErrorCode 0x11
    GDFS Write OK!
    Jumping Normal Mode...
    Disconnect The Phone. Push Power Button And Wait 10 Seconds. Then Connect Powered On Again...
    Device Detected! Trying To Connect...
    Connected In Normal Mode OK! Activating...
    I telefon już nie daje oznak życia
    Pod Setoolem na jego kablu telefon sie odczytuje :
    v0.914014/UNI
    Card serial:0000xxxx
    Loaded 51 flash descriptors
    Open COM port OK
    ChipID:8040,EMP protocol:0301
    NEW SECURITY MODEL DETECTED
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:51
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:51 PAF:1 IMEI:3542690116xxxx CERT:RED
    FLASH CID:51 COLOR:RED
    Model:W200i
    MAPP CXC article: R4GB001 prgCXC1250719_GENERIC_ME
    MAPP CXC version: R4GB001
    Language Package:CENT_EUROPE
    CDA article: CDA102738/6
    CDA version: R2A
    Default article: cxc1250728
    Default version: R4GB001
    Operator: 000-00
    USERCODE:0000
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed:33 secs.
    Davincim juz nie idzie zrobic bo na dcu-60 z HOLD C nie widzi fona.
    Jakies sugestie ??
  • #2 4575637
    Artech
    Ocena: 48
    Witam sprawdż na innym kablu dcu-60 :)
  • #3 4575659
    Fyszo
    Poziom 37  
    Ocena: 115
    Zobacz bez c na właczonym fonie czy winda go poznaje (tzn. jakiś telefon).
  • #4 4575681
    fokus73
    Ocena: 15
    Telefon się nie włącza.
  • #5 4575698
    dyziek@
    Ocena: 14
    To pewnie pozostaje flash i telefon wstanie.
    pozdr
  • #6 4575716
    Fyszo
    Poziom 37  
    Ocena: 115
    Jak chcesz sprawdzić kabel to nie muszisz go trupem sprawdzać, co nie?
    Ale jeśli kabel jest ok to w sumie masz racje.
  • #7 4575746
    fokus73
    Ocena: 15
    Tak do końca nie jest trup bo na Setoolu mam odczyt i to mnie martwi ze Davinci nie odczytuje a powinien :(
    Po power miga diodka na górze ale telefon nie odpala.
  • #8 4576524
    mmaacckkii
    Ocena: 26
    jak miga diodka to albo masz słabą baterie albo uszkodzoną zawartość Erom telefonu , najszybciej mozna to zrobić WotanClient-em ale trzeba logi wykupić w sumie mozna pewnie też Setoolem ale jakoś nie próbowałem zawsze robie Wotanem po przez przytrzymanie zamiast C dwóch klawiszy 2 i 5 równocześnie , moze spróbuj na swoim sofcie skomunikować go włąsnie tak trzymając klawisze 2 i 5 zamiast C
  • #9 4578463
    fokus73
    Ocena: 15
    Przeflashowałem Setoolem maina + central- telefon nadal sie nie włącza. Pod Davincim nie komunikuje ani na hold "c" ani na 2+5 równocześnie, cały czas miga diodka. Jak naprawić eroma Setoolem ?
  • #10 4578755
    MoDerato
    Przejdź do zakładki Empty i wciśnij aktywny przycisk Recovery.
  • #11 4579196
    fokus73
    Ocena: 15
    RECOVERY MODE STARTED
    Open COM port OK
    REC:070307 0947 NPA4_CXC1326739_DB2010_SEMC_RECOVERY_P2A
    fout_ssw superblock BAD:01
    Recovery failed. Phone dead.
    Elapsed:2 secs.
  • #12 4579220
    dickheadGSM
    Ocena: 37
    A to juz na pewno nie pojdzie to nie DB2020 tylko 2012 a to juz inna bajka.
    @fokus73 przywroc mu obszary plikiem z backupa
  • #13 4579233
    fokus73
    Ocena: 15
    Czy Davinci bedzie miał backup ?
  • #14 4579275
    dickheadGSM
    Ocena: 37
    Podzukaj ale nie wiem czy z automatu robi
    Eroma masz w katalogu erom w oprogramowaniu setoola - db2012_erom_redcid51.ssw. Jak chcesz wrzucic to do Firmware upgrade pack i flash.
  • #15 4579423
    fokus73
    Ocena: 15
    Przy próbie wgrania Eroma :
    v0.914014/UNI
    Open COM port OK
    Speed:921600
    OTP LOCKED:1 CID:51 PAF:1 IMEI:354269011xxxxx CERT:RED
    phone CID not supported in that mode
    Elapsed:4 secs.
    SERVER SUPPORT ENABLED.
    Open COM port OK
    Speed:921600
    LDR:061205 1354 HAN_DB2012_FLASHLOADER_R2B012_CXC1326738
    Flash ID check:897E
    Flash props sent ok
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    Flashing upgrade archive:E:\Kopia starego 10GB\Programy\GSM\Setool\v0.914014\eroms\db2012_erom_redcid51.ssw
    CURRENT FLASH FILE CID:36
    HDR block not accepted. (1/0),error:02FF
    Elapsed:43 secs.
    Przy próbie flasha na CID52 :
    Open COM port OK
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    writing E:\Kopia starego 10GB\Programy\GSM\Setool\W200i _PL\R4GB001_1250719_GENERIC_ME.ssw
    CURRENT FLASH FILE CID:52
    SSW uses complete hash, hash len is:6340
    HDR block not accepted,error:2
    Elapsed:24 secs.
  • #16 4906217
    zenek123
    Ocena: 36
    Co zaznaczasz w settings? Sproboj use serwer
  • #17 4906244
    fokus73
    Ocena: 15
    Wgranie backupu od Davinci Team postawiło fona na nogi. Dla informacji : W200 nie komunikuje po DCU 60 w przypadku uszkodzenia Eroma. Jedyne rozwiązanie to wgranie backupu w formacie przeliczonym pod Setoola. Temat zamykam.
✨ Podczas próby wgrania mapy za pomocą oprogramowania Davinci na telefonie Sony Ericsson W200i pojawił się problem z komunikacją przez kabel DCU-60 – telefon nie był wykrywany przez Davinci, mimo że Setool odczytywał urządzenie. Telefon nie włączał się, a dioda migała, co wskazywało na możliwe uszkodzenie pamięci EROM. Próby komunikacji z telefonem na różne sposoby (przytrzymanie klawiszy C lub 2+5) nie powiodły się. Flashowanie głównego oprogramowania i centralnego modułu Setoolem nie przywróciło funkcjonalności. Próba uruchomienia trybu recovery zakończyła się błędem „superblock BAD” i telefon pozostał martwy. Wskazano, że problem dotyczy modelu z nowym modelem zabezpieczeń (DB2012), co komplikuje naprawę. Zaleceniem było przywrócenie obszarów pamięci z backupu plikowego, jednak Davinci nie zawsze automatycznie tworzy backup. Wgranie pliku EROM dedykowanego dla CID51 zakończyło się błędem „HDR block not accepted”. Ostatecznie wgranie backupu przygotowanego przez zespół Davinci w formacie kompatybilnym z Setool przywróciło telefon do życia. Wniosek: uszkodzenie EROM w W200i skutkuje brakiem komunikacji po DCU-60 w Davinci, a jedynym rozwiązaniem jest wgranie odpowiedniego backupu EROM przez Setool.
