Jak wgrać soft do Sony Ericsson W810i CID 49 za pomocą Setool?
kowal00071 17 Gru 2007 19:29 2612 15
  • #1 4598080
    kowal00071
    Ocena: 30
    witam mam problem z wgraniem softu do w810i cid 49 setolem
    v0.914016/UNI
    Card serial:00052989
    Loaded 51 flash descriptors
    Open COM port OK
    ChipID:8040,EMP protocol:0301
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:49
    Speed:921600
    OTP LOCKED:1 CID:49 PAF:1 IMEI:35657401887775 CERT:RED
    PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
    LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Open COM port OK
    Trying to launch embedded bootloader...
    Embedded flashloader:
    COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
    Flash ID check:2019
    Flash props sent ok
    FOUND: R4GC010_CXC1250316_GENERIC_HN
    Restore from:R4GC010_CXC1250316_GENERIC_HN
    can't open file "C:\Documents and Settings\Mobile world\Pulpit\instalki\boxy\setool\program\rest\R4GC010_CXC1250316_GENERIC_HN"
    writing C:\Documents and Settings\Mobile world\Pulpit\k810\cccccccccccccc\R4EA031_1250316_GENERIC_HN.ssw.cry
    CURRENT FLASH FILE CID:49
    SSW uses dynamic hash, dynamic hash len is:344
    Will flash 344 blocks...
    Send subblock NAK
    Elapsed:141 secs.
    a jak daje unlock to wyskakuje
    v0.914016/UNI
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    Send subblock NAK
    Elapsed:141 secs.
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    Setting up GDFS...
    Error while reading critical data
    Unlock FAILED
    Elapsed:103 secs.
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    Setting up GDFS...
    Unlock FAILED
    Elapsed:110 secs.
    DZiękuje pozdrawiam.
  • #2 4598206
    dickheadGSM
    Ocena: 37
    Masz to w kazdym logu
    Sciagnij resty
  • #3 4598244
    kowal00071
    Ocena: 30
    to znaczy ??? ja mam setoola od tygodnia
  • #4 4598299
    dickheadGSM
    Ocena: 37
    Na supporcie sa spakowane pliki rest, wypakuj do katalogu rest w programie. Pobierz wszystkie jest ich 13 sztuk. (orginal setool rest files czy jakos tak)
    ps. jakas instrukce sobie poszukaj co bys nie uwalil (choc trudno) przy 1 flashowaniu :)
  • #5 4598455
    tele_sim
    Poziom 33  
    Ocena: 217
    Jak wypakujesz to od nowa flashowanie, tak samo jak robisz simlocka to sciagaj resty pod dany tel.
  • #6 4598477
    kowal00071
    Ocena: 30
    nie kapuje ściągam 12 plików daje do tego katalogu icoś dodatkowego zaznaczam czy nie???
  • #7 4598494
    gomezf1
    Spec od GSM
    Ocena: 19
    Musisz mieć dokładnie ten sam plik restore co SW telefonu. Upewnij sie czy wypakowałeś właściwe resty i o ile je "wypakowałeś" z RAR-a do właściwego katalogu. ;)
  • #8 4598551
    kowal00071
    Ocena: 30
    i ładuje ten plik razem z flashem ??
  • #9 4598564
    dickheadGSM
    Ocena: 37
    nie setool sobie sam znajdzie
    wypakuj zawartosc 12 plikow do katalogu rest w programie a tak dokladnie to tu C:\Documents and Settings\Mobile world\Pulpit\instalki\boxy\setool\program\rest\
  • #10 4598617
    kowal00071
    Ocena: 30
    Nic z tego :cry:
    v0.914016/UNI
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    writing C:\Documents and Settings\Mobile world\Pulpit\R4EA031_1250316_GENERIC_HN.ssw.cry
    Send subblock NAK
    Elapsed:110 secs.
  • #11 4598633
    dickheadGSM
    Ocena: 37
    A zrob go po usb
    Aj! Bateria na full
  • #12 4598640
    kowal00071
    Ocena: 30
    nie wiem jak
    dickheadGSM
    Ocena: 37
    kabel dcu-60
    wyjmij baterie
    wloz baterie
    nacisnij 'c' i trzymaj
    podlacz telefon
    poprosi o sterownik pusc 'c'
    sterownik zainstaluj z drivers w setoolu
    odlacz telefon
    uruchom setoola
    dodaj pliki + complete
    wybierz port usb
    kliknij flash
    nacisnij 'c' i podlacz telefon
    Kolejny patent na trupa
    moze byc po porcie com
    do plikow dodaj gdfs z katalogu setoola /gdfs in sww
    UWAZAJ tylko dla platformy db2000
    dodaj main i fs
    zakladka settings - complete phone after flash, unlock after flash
    i flash :)
    Powodzenia!
  • #14 4598766
    kowal00071
    Ocena: 30
    kabla nie moge zainstalować a normalnie dochodzi prawie do połowy i staje
    v0.914016/UNI
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    Send subblock NAK
    Elapsed:110 secs.
    Open COM port OK
    Speed:921600
    phone pre-boot failed,possible RECOVERY needed.
    Elapsed:8 secs.
    Open COM port OK
    Speed:921600
    verify block error
    last blk:44150000,00010000
    prepare failed,that is FATAL
    Elapsed:34 secs.
    Open COM port OK
    Speed:921600
    HDR block not accepted,error:BA
    Elapsed:35 secs.
    Open COM port OK
    Speed:921600
    THEN PRESS "READY"
    Open COM port OK
    Flash ID check:2019
    Flash props sent ok
    writing C:\Documents and Settings\Mobile world\Pulpit\instalki\boxy\setool\W810\flash\brown\prepared\w810\r4gc010\R4GC010_1250316_GENERIC_HN.ssw
    CURRENT FLASH FILE CID:254
    SSW uses dynamic hash, dynamic hash len is:345
    Will flash 345 blocks...
    Send subblock NAK
    Elapsed:696 secs.
    dickheadGSM
    Ocena: 37
    Bateria na full
  • #16 4598859
    kowal00071
    Ocena: 30
    @dickheadGSM wstyd mi :cry: miałeś racje
    DZIĘKUJE
Problem dotyczy wgrywania oprogramowania (softu) do telefonu Sony Ericsson W810i z CID 49 za pomocą programu Setool v0.914016/UNI. Podczas próby flashowania pojawia się błąd „can’t open file” dotyczący pliku restore (rest), który jest niezbędny do poprawnego procesu. Rozwiązaniem jest pobranie i wypakowanie kompletu 12-13 oryginalnych plików rest do katalogu „rest” w folderze programu Setool, dokładnie pod ścieżką wskazaną w logu. Setool automatycznie wykrywa pliki rest, nie trzeba ich ręcznie dodawać do procesu flashowania. Zalecane jest również wykonanie flashowania przez port USB z użyciem kabla DCU-60, przy czym telefon należy podłączyć w trybie bootloadera (wyjmując baterię, wkładając ją ponownie i przytrzymując klawisz „c” podczas podłączania). Należy mieć na uwadze, że bateria powinna być naładowana w pełni, a sterowniki USB z folderu Setool muszą być poprawnie zainstalowane. Po poprawnym przygotowaniu plików i sprzętu proces flashowania powinien przebiegać bez błędów. Dodatkowo wskazano, że do flashowania można dodać pliki GDFS odpowiednie dla platformy DB2000 oraz ustawić opcje „complete phone after flash” i „unlock after flash” w programie.
