PIC16F84A i programator JDM - błędy weryfikacji przy programowaniu
Maciek29 20 Mar 2008 12:33 1137 3
  • #1 4931219
    Maciek29
    Mam porblem z zaporgramowaniem Pic`a 16F84A, używam porgramatora JDM http://bruno.netstrefa.com.pl/radio/projekt/jdm/index.htm . Kiedyś zaporgramowałem nim mojego Pica ale teraz wyskakuje mi oto taka lista (nie znam sie na programowaniu procków :(
    Programming...
    Erasing ("bulk" or "chip") ...
    Programming CODE, 0x000000..0x0003FF
    Verify Error: 000000: read 000000, wanted 000183
    Verify Error: 000001: read 000000, wanted 00018B
    Verify Error: 000002: read 000000, wanted 00018A
    Verify Error: 000003: read 000000, wanted 000185
    Verify Error: 000004: read 000000, wanted 000186
    Verify Error: 000005: read 000000, wanted 00018C
    Verify Error: 000006: read 000000, wanted 00019D
    Verify Error: 000007: read 000000, wanted 00018F
    Verify Error: 000008: read 000000, wanted 000190
    Verify Error: 000009: read 000000, wanted 000191
    Verify Error: 00000A: read 000000, wanted 000192
    Verify Error: 00000B: read 000000, wanted 000193
    Verify Error: 00000C: read 000000, wanted 000194
    Verify Error: 00000D: read 000000, wanted 000195
    Verify Error: 00000E: read 000000, wanted 000198
    Verify Error: 00000F: read 000000, wanted 000199
    Verify Error: 000010: read 000000, wanted 00019A
    Programming aborted after 17 errors.
    Programming DATA, 0x002100..0x00213F
    Verify Error: 002100: read 000000, wanted 0000FF
    Verify Error: 002101: read 000000, wanted 0000FF
    Verify Error: 002102: read 000000, wanted 0000FF
    Verify Error: 002103: read 000000, wanted 0000FF
    Verify Error: 002104: read 000000, wanted 0000FF
    Verify Error: 002105: read 000000, wanted 0000FF
    Verify Error: 002106: read 000000, wanted 0000FF
    Verify Error: 002107: read 000000, wanted 0000FF
    Verify Error: 002108: read 000000, wanted 0000FF
    Verify Error: 002109: read 000000, wanted 0000FF
    Verify Error: 00210A: read 000000, wanted 0000FF
    Verify Error: 00210B: read 000000, wanted 0000FF
    Verify Error: 00210C: read 000000, wanted 0000FF
    Verify Error: 00210D: read 000000, wanted 0000FF
    Verify Error: 00210E: read 000000, wanted 0000FF
    Verify Error: 00210F: read 000000, wanted 0000FF
    Verify Error: 002110: read 000000, wanted 0000FF
    Programming CONFIG, 0x002000..0x002007
    Verify Error: 002000: read 000000, wanted 00000F
    Verify Error: 002001: read 000000, wanted 00000F
    Verify Error: 002002: read 000000, wanted 00000F
    Verify Error: 002003: read 000000, wanted 00000F
    Verify Error: 002007: read 000000, wanted 003FF1
    ERROR: Programming FAILED !
    Kod hex na bank jest poprawny.
    Wykasuj w temacie "!"
    12:45 20.3.2008
    [_P_]
  • #2 4931845
    edekk
    Ocena: 115
    Też miałem z tym programatorem kłopoty , ale po odłączeniu diod LED śmiga bez problemu.
  • #3 4933857
    Maciek29
    Dzięki za odpowiedz. Jutro wylutuje LEDy.
  • #4 5144351
    Pawcio89
    Ocena: 24
    Ja też mam problem z tym programatorem i czy możesz napisać czy wylutowanie diod pomogło?
