Dim New As Bit
Dim Command As Byte , Subaddress As Byte , Volume As Byte
Reset P1.0
Reset P1.1
Reset P1.2
Reset P1.3
Reset P1.4
Reset P1.5
Reset P1.6
Reset P1.7
Reset Tcon.0
Volume = 50 'triggered by rising edge
On Int0 Receiverc5
Enable Int0
Enable Interrupts
Do
If New = 1 Then 'received new code
Disable Int0
If Command = 20 Then
Set P1.0
Waitms 200
Reset P1.0
End If
If Command = 3 Then
Set P1.1
Waitms 200
Reset P1.1
End If
If Command = 1 Then
Set P1.2
Waitms 200
Reset P1.2
End If
If Command = 2 Then
Set P1.3
Waitms 200
Reset P1.3
End If
If Command = 21 Then
Set P1.4
Waitms 200
Reset P1.4
End If
If Command = 19 Then
Set P1.5
Waitms 200
Reset P1.5
End If
If Command = 18 Then
Set P1.6
Waitms 200
Reset P1.6
End If
If Command = 13 Then
Set P1.7
Waitms 200
Reset P1.7
End If
Set P1.0
Waitms 200
Reset P1.0
End If
If Command = 3 Then
Set P1.1
Waitms 200
Reset P1.1
End If
If Command = 1 Then
Set P1.2
Waitms 200
Reset P1.2
End If
If Command = 2 Then
Set P1.3
Waitms 200
Reset P1.3
End If
Set P1.4
Waitms 200
Reset P1.4
End If
Set P1.5
Waitms 200
Reset P1.5
End If
Set P1.6
Waitms 200
Reset P1.6
End If
Set P1.7
Waitms 200
Reset P1.7
End If
Set P1.0
Waitms 200
Reset P1.0
End If
If Command = 3 Then
Set P1.1
Waitms 200
Reset P1.1
End If
If Command = 1 Then
Set P1.2
Waitms 200
Reset P1.2
End If
If Command = 2 Then
Set P1.3
Waitms 200
Reset P1.3
End If
Set P1.4
Waitms 200
Reset P1.4
End If
Set P1.5
Waitms 200
Reset P1.5
End If
Set P1.6
Waitms 200
Reset P1.6
End If
Set P1.7
Waitms 200
Reset P1.7
End If
If Command = 16 Then ' procedura zwiększania głosnosci
If Volume = 192 Then
Volume = 191
End If
Reset P3.5
Shiftout P3.3 , P3.4 , Volume , 3
Incr Volume
Set P3.5
Waitms 1
End If
If Command = 17 Then' procedura zmniejszaniai
If Volume = 0 Then
Volume = 1
End If
Reset P3.5
Decr Volume
Set P3.5
Waitms 1
End If
New = 0 'reset new bit
Enable Int0
End If
Loop
Receiverc5: 'interrupt routine
'the getrc5 routine uses 30 bytes ! of the stack for measuring
'the interval between the bits
Getrc5(subaddress , Command)
New = 1 'set flag
Return
Zrobiłem sobie w ten sposób sterowanie do odtwarzacza cd do którego nie maiłem pilota
tamte procedury na górze <if cośtam możesz wyrzucić> one są po to by generować impuls na kolejnych wyjściach procesora i w ten sposób właczyć kolejne funkcje w cd. zostaw tylko te procedury zwiekszania głośności. musisz mieć zwykły pilot do triluxa z kodem rc5 zrobisz głośniej i ciszej procesor odpowie i pga tez
. P3.5 dołaczasz do CS. p3.3 to wyjście danych a p3.4 to zegar wyjściowy. jak czegoś nie wiesz to pytaj. przepraszam że tak późno odpowiedziałem ale miałem egzaminy
. aaa i niech nikt nie mówi mi o jakims tda ze jest lepszy... Panowie Pga to zamiennik słynnego cs3310 i sadze że jeśli chodzi o potencjometry cyfrowe jest najlepszy. Dodam tylko że cs 3310 stosowano w przedwzmacniaczu hi end (nie pamiętam firmy)za .... 16000zł więc uważam że takowy do najgorszych nie należy
a co do zniekształceń THD.. hmm. czy to ważne czy ma 0.002 czy 0.009? pewnie że nie.. ważne sa szybkość i pasmo od nich zależa zniekształcenia TIM( na nie jesteśmy bardzo wrażliwi) a których większość producentów scalaków nie podaje
. z resztą pga2310 i tak mają najmniejsze o ile pmiętam to 0.0004:)
