Opinie i dane techniczne wzmacniacza Profile Clarus Cl1200
kiceq 23 Lip 2009 12:54 963 0
  • #1 6812951
    kiceq
    Ocena: 2
    Co to jest ? Miał ktoś z tym doczynienia ? Poszukuje wszelkich opinni na temat tego wzmacniacza? Kilka danych technicznych :
    # 300 watts RMS x 2 at 4 ohms
    # 450 watts RMS x 2 at 2 ohms
    # 900 watts RMS x 1 at 4 ohms in bridged mode
    # requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
    # stereo or bridged mono output
    # Tri-way capable (Tri-Way crossover required)
    # MOSFET power supplies
    # 40-500 Hz continuously variable low- and high-pass crossovers, 12 dB/octave
    # anti-thump circuit for quiet turn on/off
    # accepts up to 6-gauge speaker wire
    # 0-18 dB variable bass boost at 45 Hz
    # defeatable subsonic filter eliminates frequencies below 20 Hz for improved amp and speaker efficiency
    # gold-plated preamp inputs and block terminals
    # speaker- and preamp-level inputs
    # preamp outputs
    # power light strip
    Link do dokladnej instrukcji:
    http://akamaipix.crutchfield.com/Manuals/489/489CL1200.PDF
    Z góry dziękuje za wszystkie przydatne opinnie.
