Znalazłem cos w sieci może sie przyda....
Erasing the child safety (only for 37AM-24S).
Switch on appliance and press key "" on appliance and key "Lock/Keyl" on the RC at the same time. Press "Mode" on the RC to adjust the menu and press channel select keys "" and "" to switch on the "key" function. Press "Mode" to switch on "PIN". Input new PIN no. and then press "Exit" and press "Mode" again.
.Adjusting the vertical position: geometry.
Receive a Philips test picture. Press "" key to move picture up and press "" key to move picture down. Adjust horizontal position so that the picture is in the middle.
10.Adjusting the vertical amplitude: geometry.
Receive a Philips test picture. Press "" button to increase the vertical size and press "" button to reduce the vertical size. Adjust vertical picture size so that the scanning is optimal.
