Podcza programowanie przez openocd, za pomocą Jtag-lock-pick, wyskakuje mi cos takiego:
Czy ktoś może używał tego atmela mail podobny problem i wie jak go rozwiązać?
C:\>openocd -f interface/jtagkey.cfg -f target/at91sam7sx.cfg -c "jtag_khz 1000"
-c "init" -c "reset" -c "halt" -c "flash write_image erase C:\AT91SAM7S256_inc.
hex" -c "reset run" -c "shutdown"
Open On-Chip Debugger 0.4.0 (2010-02-22-19:05)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.berlios.de/doc/doxygen/bugs.html
srst_only srst_pulls_trst srst_gates_jtag srst_open_drain
Warn : use 'at91sam7s.cpu' as target identifier, not '0'
1000 kHz
Info : clock speed 1000 kHz
Info : JTAG tap: at91sam7s.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0
xf0f0, ver: 0x3)
Info : Embedded ICE version 1
Info : at91sam7s.cpu: hardware has 2 breakpoint/watchpoint units
xf0f0, ver: 0x3)
Warn : NOTE! DCC downloads have not been enabled, defaulting to slow memory writ
es. Type 'help dcc'.
Warn : NOTE! Severe performance degradation without fast memory access enabled.
Type 'help fast'.
target state: halted
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x60000013 pc: 0x000016ac
auto erase enabled
Error: No flash at address 0x00000000
wrote 0 bytes from file C:AT91SAM7S256_inc.hex in 0.108000s (0.000 kb/s)
xf0f0, ver: 0x3)
Type 'help fast'.
shutdown command invokedCzy ktoś może używał tego atmela mail podobny problem i wie jak go rozwiązać?
