Prosty schemat automatycznego włącznika do wzmacniacza
krzysiekdioda 01 Sty 2011 18:00 3333 2
  • #1 8944109
    krzysiekdioda
    Ocena: 2
    Poszukuję w miare prostego schematu automatycznego włącznika załączającego wzmacniacz po podaniu sygnału audio, chodzi mi o to żeby nie marnować niepotrzebnie prądu :)).
    Znalazłem w internecie schemat AUTOMATYCZNEGO WŁĄCZNIKA SUBWOFERA lecz on nie przypadł mi do gustu. Potrzebuję coś naprawdę prostego. Może jest jakis schemacik na bramce CD4017 ??
    Może coś na bazie klaskacza http://www.cyfronika.com.pl/dok/avt721pdf.pdf
    Z góry dziękuję za pomoc.
  • #2 8944603
    fascynat
    Ocena: 107
    Może ten schemat Cię zainteresuje.
    Automatic Switch For Audio Power Amplifier
    Circuit of an automatic switch for audio power amplifier stage is presented here. The circuit uses stereo preamplifier output to detect the presence of audio to switch the audio power amplifier on only when audio is present. The circuit thus helps curtail power wastage. IC1 is used as an inverting adder. The input signals from left and right channels are combined to form a common signal for IC2, which is used as an open loop comparator. IC3 (NE556) is a dual timer. Its second section, i.e., IC3(b), is configured as monostable multivibrator. Output of IC3(b) is used to switch the power amplifier on or off through a Darlington pair formed by transistors T1 and T2. IC3(a) is used to trigger the monostable multivibrator whenever an input signal is sensed. Under ‘no signal’ condition, pin 3 of IC2 is negative with respect to its pin 2. Hence the output of IC2 is low and as a result output of IC3(a) is high. Since there is no trigger at pin 8 of IC3(b), the output of IC3(b) will be low and the amplifier will be off. When an input singal is applied to IC1, IC2 converts the inverted sum of the input signals into a rectangular waveform by comparing it with a constant voltage which can be controlled by varying potentiometer VR1. When the output of IC2 is high, output pin 5 of IC3 goes low, thus triggering the monostable multivibrator. As soon as the audio input to IC1 stops, pin 5 of IC3 goes high and pin 1 of IC3 discharges through capacitor C3, thus resetting the monostable multivibrator. Hence, as long as input signals are applied, the amplifier remains ‘on.’ When the input signals are removed, i.e., when signal level is zero, the amplifier switches off after the mono flip-flop delay period determined by the values of resistor R8 and capacitor C3. If no input signals are sensed within this time, the amplifier turns off—else it remains on. Power supply for the circuit can be obtained from the power supply of the amplifier. Hence, the circuit can be permanently fitted in the amplifier box itself. The main switch of the amplifier should be always kept on. Resistors R1 and R2 are used to divide single voltage supply into two equal parts. Capacitors C1 and C2 are used as regulators and also as an AC bypass for input signals. Diode D1 is used so that loading fluctuations in power amplifier do not affect circuit regulation. Transisitor T2 acts as a high voltage switch which may be replaced by any other high voltage switching transistor satisfying amplifier current requirements. Value of resistor R10 should be modified for large current requirement. The LED glows when the amplifier is on. The circuit is very useful and relieves one from putting the amplifier on and off every time one plays a cassette or radio etc.
    Drugi układ masz tutaj.
  • #3 8946096
    krzysiekdioda
    Ocena: 2
    Dziękuję za schematy :D
    Zainteresował mnie ten drugi, czy zamiast LMC7215 mogę zastosować inny układ ??
    Powiedzmy TL071 ??
