[Atmega8] Atmega8 i Bascom: Problemy z uruchomieniem LCD na ST7565R
biglolo94 01 Cze 2011 16:29 4344 0
  • #1 9566428
    biglolo94
    Ocena: 15
    W folderze SAMPLES bascoma jest przykład programu, który obsługuje wyświetlacze z tym sterownikiem.
    A więc zakupiłem taki wyświetlacz:
    Link
    Mam wszystko podłączone jak w linku, ale nie moge go odpalić.
    Przykładowy program w tym folderze jest napisany dla atmegi168, która ma takie same wyjścia jak atmega8 więc zmieniłem i powinno ruszyć, no ale nie chce :/
    I jeszcze cały prog:
    '                     EADOGM128.BAS
    '               (c) 1995-2008 MCS Electronics
    ' micro : mega168
    ' demo  : SPI graphical display EADOGM128
    ' IMPORTANT : SPI only allows the WRITE mode. THis mean that setting pixels is not possible.
    '             for this reason commands as PSET, LINE and CIRCLE are not supported.
    '             best option would be to display pictures
    ' fonts and images are compatible to KS108
    $regfile = "m8def.dat"                                      ' ATmega8
    $crystal = 8000000
    $baud = 19200
    $lib "glcdEADOGM128x6.lbx"                                  ' specify the used lib
    'the display was connected with these pins
    Config Graphlcd = 128 * 64eadogm , Cs1 = Portd.4 , A0 = Portd.7 , Si = Portb.3 , Sclk = Portb.5 , Rst = Portd.5
    'the best option is to control the reset line of the LCD with the micro so you can reset it controlled at startup
    Config Adc = Single , Prescaler = Auto , Reference = Avcc
    Dim B As Byte , J As Byte
    Dim K As Byte , X As Word , Y As Word
    Print "cls"
    Cls
    'specify the font we want to use
    Setfont Font8x8tt
    'You can use locate but the columns have a range from 1-128
    'When you want to show somthing on the LCD, use the LDAT command
    'LCDAT Y , COL, value
    Lcdat 1 , 1 , "11111111"
    Lcdat 2 , 1 , "88888888"
    Lcdat 3 , 1 , "MCS Electronics" , 1
    Waitms 3000
    Dim I As Word
    For I = 110 To 333
      Lcdat 1 , 1 , I
      Waitms 500
      Cls 1 , 1 , 24 , 255                                      'clear inverse
      Waitms 500
    Next
    Waitms 3000
    Setfont My12_16
    Cls
    Lcdat 1 , 1 , "112345678"                                   'a bigger font
    Waitms 3000
    Setfont Font8x8tt
    'Showpic 0 , 0 , Plaatje
    Waitms 3000
    Do
      Gosub Touch                                               'optional touch screen
    Loop
    End
    'portc.0-portc.3 pin 1-4
    Touch:
       Start Adc
       Waitms 200
       Config Portc.0 = Output                                  'Bottom
       Config Portc.2 = Output                                  'Top
       Set Portc.0                                              'High
       Reset Portc.2                                            'Low
       Config Pinc.1 = Input                                    'left as input
       Config Pinc.3 = Input                                    'right as input
       Waitms 80
       Y = Getadc(3)
       Y = Y - 365
       If Y > 640 Then Y = 0
       Config Portc.1 = Output                                  'Left
       Config Portc.3 = Output                                  'Right
       Set Portc.3
       Reset Portc.1
       Config Pinc.0 = Input
       Config Pinc.2 = Input
       Waitms 80
       X = Getadc(0)
       X = X - 196
       If X > 800 Then X = 0
       Lcdat 1 , 1 , "X : " ; X
       Lcdat 1 , 74 , "Y : " ; Y
    Return
    Plaatje:
    'include the picture data
    '$bgf "ks108.bgf"
    'include used fonts
    $include "font8x8TT.font"
    $include "my12_16.font"
    Proszę o pomoc w odpaleniu tego LCD.
    Znalazłem problem :P
    Myślałem, że na schemacie są kondensatory ceramiczne, a chodziło o elektrolity ;P
