Dell 620, XP SP3 - Instalacja poprawki KB 232414 (xml 3.0) nieudana, co zrobić?
MarudaP 28 Paź 2013 06:57 1119 4
  • #1 12889008
    MarudaP
    Ocena: 238
    System XP Prof. z Sp3, aktualizacje włączone.Nie można zainstalować poprawki KB 232414 (xml 3.0). Nie pomagają: msxml3.msi, xmlInst.exe, fixit. Czy odinstalowanie sp3 może pomóc ?
  • #2 12889017
    Matuzalem
    Ocena: 1099
    To "nie można" to czym się dokładnie objawia? - Byłoby dobrze, o ile jest, z sygnaturą błędu z logu WU.
    Konto firmowe:
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #3 12889064
    MarudaP
    Ocena: 238
    Wklejam cały log:
    [09:23:49]: Welcome to the Microsoft Data Access Components Hotfix Installer.
    [09:23:49]: Windows Version Information:
    Type: WinNT/2000/XP
    Version: 5.1 (Service Pack: 3 ("Dodatek Service Pack 3"))
    Terminal Services: No
    MUI Enabled: No
    [09:23:49]: Parsing Command Line options.
    [09:23:49]: Opening .ini file: C:\DOCUME~1\Domownik\USTAWI~1\Temp\IXP000.TMP\dahotfix.ini
    [09:23:49]: Loading System Setup Engine (SETUPAPI.DLL)
    [09:23:49]: Checking system dependencies.
    [09:23:49]: Processing .ini file data and building job list.
    [09:23:49]: Initializing Job Queues.
    Job queue root: SOFTWARE\Microsoft\DataAccess\dahotfix
    [09:23:49]: The registry value (SOFTWARE\Microsoft\Windows\CurrentVersion, "CommonFilesDir") was found. Setting the directory path to "C:\Program Files\Common Files".
    [09:23:49]: Job #1 added to job list.
    [09:23:49]: Standard user interface mode enabled. Creating user interface components.
    [09:23:49]: Creating Main Dialog.
    [09:23:49]: Setting Main Dialog visible.
    [09:23:49]: Beginning Windows Message Pump.
    [09:23:51]: Creating worker thread to handle installation of files.
    [09:23:51]: Executing PreInstallActions for package.
    [09:23:51]: Loading function CheckForMSXML30 from internal function list.
    [09:23:51]: Checking to see if MSXML 3.0 is currently installed on the machine.
    [09:23:51]: Dll existance verified, reading version.
    [09:23:51]: Target Dll version: 8.100.1053.0
    [09:23:51]: Comparing SP version at target: 100 to 40 at source
    [09:23:51]: ERROR: SP version Check failure.
    [09:23:51]: MSXML 3.0 is NOT installed on the machine.
    [09:23:51]: The action CheckForMSXML30(40) returned FALSE.
    [09:23:51]: This action was deemed critical, skiping other actions in this package
    Either all of the PreInstallActions for this package returned FALSE, or there was a fatal error while executing an action.
    The package will not be installed. This error will not halt the setup process.
    [09:23:51]: Destroying Job Queues.
    [09:30:53]: Ending Windows Message Pump.
    [09:30:53]: Destroying Main Dialog.
    [09:30:53]: Checking state of setup at end of installation.
    Setup was NOT successful.
    [09:30:53]: Shutting down Hotfix Installer.
  • #4 12889079
    Matuzalem
    Ocena: 1099
    się z komunikatu w oczy rzuca (to coś napisał o *.msi widziałem, ale niewiele z tego wynika).
    Nadto - czy w logach podglądu zdarzeń nic nie ma?
    Konto firmowe:
    Doradztwo podatkowe
  • #5 12889135
    MarudaP
    Ocena: 238
    W dzienniku zdarzeń nie ma nic szczególnego.
    Podczas próby instalacji pojawia się komunikat:
    "An version occured while setup was trying to veryfy the version of MS Data Access Components currently instaled on thy machine."
