Carprog 7.52 - Odczyt KM w desce rozdzielczej 2005 Ford Mondeo nie działa
gl01bxg2003 13 Sty 2015 20:57 2349 7
  • #1 14326923
    gl01bxg2003
    If anyone can help me with such an information.
    I have recently bought a Carprog 7.52 interface with all adapter cables. I'm not sure if it's working correctly. I'm trying to get it to read KM in dashboard via OBD with A1 adapter cable on a 2005 Ford Mondeo.
    I've also tried with the Ford adapter cable. Same result: not working. (read error... or someting like that)
    Does anybody know is it should work on this car?
    thank you
  • #2 14327231
    bodzio012
    Poziom 33  
    Ocena: 779
    The long road ahead of you, you should sit on forums and read, there is no device that will do the dash by OBD, if you need some info you can write me PM
  • #3 14327995
    gabik001
    Poziom 37  
    Ocena: 418
    How you got it connected to computer? Via com port or you are using USB-serial interface?
    I don't think you can do this car via OBD. I did via OBD with Tacho Universal some VW and Chrysler/Dodge cars but it is tricky in VW cars .
    Anyway, look at this forum, there are some posts about how to modify carpro to make it work.
    Good luck!
  • #4 14328032
    gl01bxg2003
    Yes, I connected it via USB. Computer recognizes the device as Human Interface Device.
    I saw on ytb two clips showing the device working on two cars. Am I allowed to post here an ytb link?
  • #5 14331587
    bodzio012
    Poziom 33  
    Ocena: 779
    But your cars are other than you saw in youtub....
  • #6 14338482
    gabik001
    Poziom 37  
    Ocena: 418
    Thats the problem. Try to connect it via com port. I read on some british forum that connecting it via USB interface will not bring you results. In simple words it will not connect it with the car. Yes, it is visible as human interface device but this pointing to USB interface.
    Anyway I am not sure that your car can be done by OBD. In your car mileage is stored in 68HC912D60 chip inside cluster (Visteon) . AFAIK models 2007+ can be done via OBDII (2006-07 has 24C16 eprom and it can be done directly). As post over says those were diferrent cars in your clip.
  • #7 14344945
    gl01bxg2003
    Hi. Today I have managed to read the MCU by directly connecting 4 wires to the chip on pins 9, 10 15 and 34 and using the A10 cable.
    Attached you will find my .bin file.
    How many KM's should my dash display with this information on the chip?
    thank you
    • no1.BIN (1 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #8 14345588
    bodzio012
    Poziom 33  
    Ocena: 779
    Old +- 219km how much need?
Użytkownik ma problemy z odczytem kilometrów w desce rozdzielczej Forda Mondeo z 2005 roku za pomocą interfejsu Carprog 7.52. Pomimo użycia adapterów A1 i Ford, nie udało się uzyskać odczytu, co skutkuje błędami. Użytkownicy forum sugerują, że odczyt przez OBD może być niemożliwy, ponieważ w tym modelu licznik kilometrów jest przechowywany w chipie 68HC912D60. Zasugerowano również, aby spróbować połączenia przez port COM zamiast USB, ponieważ USB może nie działać poprawnie. Użytkownik ostatecznie zdołał odczytać MCU, łącząc się bezpośrednio z chipem, i pyta o wartość kilometrów na podstawie odczytanego pliku .bin.
