#include <enc28j60.h>
#include <EtherCard.h>
#include <net.h>
- Web control relay with Arduino -
Ethernet module "ENC28J60" is connected to the Arduino :
VCC - 3.3V Arduino
GND - GND Arduino
SCK - Pin 13 Arduino
SO - Pin 12 Arduino
SI - Pin 11 Arduino
CS - Pin 10 Arduino
The relay is connected to the Arduino so:
VCC - 5V Arduino
In1 - Pin 2 Arduino
In2 - Pin 3 Arduino
In7 - Pin 8 Arduino
In8 - Pin 9 Arduino
GND - GND Arduino
byte mymac[6] = {0x74,0x69,0x69,0x2D,0x30,0x31};
// ethernet interface mac address, must be unique on the LAN
// remote website ip address and port
//static byte hisip[] = { 74,125,79,99 };
// remote website name
// Declare PinStatus and LedPins before BufferFiller declaration
uint8_t myip[4] = {192,168,1,3};
uint8_t netmask[4] = {255,255,255,0};
uint8_t gwip[4] = {192,168,1,1};
uint8_t dnsip[4] = {8,8,8,8};
boolean PinStatus[2];
int LedPins[2];
// buffer[500] for 4 relays
// increase size buffer for more relays
byte Ethernet::buffer[1200];
BufferFiller bfill;
const char http_OK[] PROGMEM =
"HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\n"
"Pragma: no-cache\r\n\r\n";
const char http_Found[] PROGMEM =
"HTTP/1.0 302 Found\r\n"
"Location: /\r\n\r\n";
const char http_Unauthorized[] PROGMEM =
"HTTP/1.0 401 Unauthorized\r\n"
"Content-Type: text/html\r\n\r\n"
"<h1>401 Unauthorized</h1>";
// Web page
void homePage()
bfill.emit_p(PSTR("$F"
"<HTML>"
"<title>ArduinoPIN Webserver</title>"
"<p align=center><font size=10>"
http_OK);
for(int i = 0; i <= 1; i++)
bfill.emit_p(PSTR(
"R$D: <a href='?P$D=$F' style=color:$F>$F</a><br />"
i+1,
i+1,
PinStatus[i]?PSTR("off"):PSTR("on"),
PinStatus[i]?PSTR("green"):PSTR("red"),
PinStatus[i]?PSTR("ON"):PSTR("OFF"));
bfill.emit_p(PSTR("<a href=\"50000/show_settings/\">Show settings</a></br>"));
bfill.emit_p(PSTR("<a href=\"50000/change_settings/\">Change settings</a></br>"));
bfill.emit_p(PSTR("<a href=\"50000/reset_to_deflaut/\">Reset to deflaut</a></br>"));
bfill.emit_p(PSTR(
"</font></p>"
"</HTML>"
void reset_to_default()
"<HTML>"
"<p align=center><font size=5>"
http_OK);
bfill.emit_p(PSTR(
"<button type="
"button"
">Save settings</button></br>"
bfill.emit_p(PSTR(
"</font></p>"
"</HTML>"
void change_settings()
"<HTML>"
"<p align=center><font size=4>"),http_OK);
bfill.emit_p(PSTR("<body>"));
bfill.emit_p(PSTR("<form>"));
bfill.emit_p(PSTR("<input type=\"radio\" name=\"ip\" value=\"DHCP\" checked> DHCP<br>"));
bfill.emit_p(PSTR("<input type=\"radio\" name=\"ip\" value=\"Static_IP\"> Static IP<br>"));
bfill.emit_p(PSTR("</form>"));
bfill.emit_p(PSTR("IP: "));
bfill.emit_p(PSTR("<input value=\"$D\">."),myip[0]);
bfill.emit_p(PSTR("<input value=\"$D\">."),myip[1]);
bfill.emit_p(PSTR("<input value=\"$D\">."),myip[2]);
bfill.emit_p(PSTR("<input value=\"$D\"></br>"),myip[3]);
bfill.emit_p(PSTR("MASK: "));
bfill.emit_p(PSTR("<input value=\"$D\">."),netmask[0]);
bfill.emit_p(PSTR("<input value=\"$D\">."),netmask[1]);
bfill.emit_p(PSTR("<input value=\"$D\">."),netmask[2]);
bfill.emit_p(PSTR("<input value=\"$D\"></br>"),netmask[3]);
bfill.emit_p(PSTR("GW: "));
bfill.emit_p(PSTR("<input value=\"$D\">."),gwip[0]);
bfill.emit_p(PSTR("<input value=\"$D\">."),gwip[1]);
bfill.emit_p(PSTR("<input value=\"$D\">."),gwip[2]);
bfill.emit_p(PSTR("<input value=\"$D\"></br>"),gwip[3]);
bfill.emit_p(PSTR("MAC: "));
bfill.emit_p(PSTR("<input value=\"$H\">:"),mymac[0]);
bfill.emit_p(PSTR("<input value=\"$H\">:"),mymac[1]);
bfill.emit_p(PSTR("<input value=\"$H\">:"),mymac[2]);
bfill.emit_p(PSTR("<input value=\"$H\">:"),mymac[3]);
bfill.emit_p(PSTR("<input value=\"$H\">:"),mymac[4]);
bfill.emit_p(PSTR("<input value=\"$H\"></br> "),mymac[5]);
bfill.emit_p(PSTR("DNS: "));
bfill.emit_p(PSTR("<input value=\"$D\">."),dnsip[0]);
bfill.emit_p(PSTR("<input value=\"$D\">."),dnsip[1]);
bfill.emit_p(PSTR("<input value=\"$D\">."),dnsip[2]);
bfill.emit_p(PSTR("<input value=\"$D\"></br>"),dnsip[3]);
bfill.emit_p(PSTR("<a href=\"http://$D.$D.$D.$D/\">Save settings</a></br>"));
bfill.emit_p(PSTR("<a href=\"http://$D.$D.$D.$D/\">Back to control page</a></br>"),myip[0],myip[1],myip[2],myip[3]);
bfill.emit_p(PSTR("<input type=\"number\" maxlength=\"3\" min=\"10\" max=\"255\" size=\"0\" value=\"$D\">."),myip[0]);
bfill.emit_p(PSTR("<input type=\"number\" maxlength=\"3\" min=\"10\" max=\"255\" size=\"0\" value=\"$D\">."),myip[1]);
bfill.emit_p(PSTR("<input type=\"number\" maxlength=\"3\" min=\"10\" max=\"255\" size=\"0\" value=\"$D\">."),myip[2]);
bfill.emit_p(PSTR("<input type=\"number\" maxlength=\"3\" min=\"10\" max=\"255\" size=\"0\" value=\"$D\"></br>"),myip[3]);
bfill.emit_p(PSTR(
"</body>"
"</font></p>"
"</HTML>"
void show_settings()
"<HTML>"
http_OK);
bfill.emit_p( PSTR("IP Address: $D.$D.$D.$D\n</br>"), myip[0],myip[1],myip[2],myip[3] );
bfill.emit_p( PSTR("Mask: $D.$D.$D.$D\n</br>"), netmask[0],netmask[1],netmask[2],netmask[3] );
bfill.emit_p( PSTR("GW Address: $D.$D.$D.$D\n</br>"), gwip[0],gwip[1],gwip[2],gwip[3] );
bfill.emit_p( PSTR("MAC: $H:$H:$H:$H:$H:$H\n</br>"), mymac[0],mymac[1],mymac[2],mymac[3],mymac[4],mymac[5] );
bfill.emit_p(PSTR("<a href=\"http://$D.$D.$D.$D/\">Back to control page</a>"),myip[0],myip[1],myip[2],myip[3]);
bfill.emit_p(PSTR(
"</font></p>"
"</HTML>"
void setup()
Serial.begin(9600);
Serial.print("Setup ");
// Pins on Arduino D2 and D3
LedPins[0] = 2;
LedPins[1] = 3;
// if (ether.begin(sizeof Ethernet::buffer, mymac) == 0).
// and change it (CS-pin) to pin 10.
Serial.println(F("\nConnecting..."));
if (ether.begin(sizeof Ethernet::buffer, mymac,10) == 0);
Serial.println(F("Failed to access Ethernet controller"));
if (!ether.dhcpSetup());
Serial.println(F("DHCP failed"));
Serial.print("Connected\n");
ether.printIp("My Router IP: ", ether.myip);
//ether.staticSetup(myip);
ether.printIp("My SET IP: ", ether.myip);
// Debug
Serial.print("\n");
Serial.print("|-------------------------------------------|\n");
Serial.print("| Actions | LedPin / PinStatus |\n");
Serial.print("| Init | ");
// Initialization of pin mode and pin status
pinMode(LedPins[i],OUTPUT);
digitalWrite (LedPins[i],HIGH);
PinStatus[i]=false;
// Debug
Serial.print(LedPins[i]);
Serial.print("/");
Serial.print(PinStatus[i]);
Serial.print(" ");
Serial.print("\n");
void loop()
delay(1);
// bool a=0; if(digitalRead(tenbutton){if(a==0){a=1; delay(500);} else {a=0; delay(500);)}}
word len = ether.packetReceive(); // check for ethernet packet
word pos = ether.packetLoop(len); // check for tcp packet
if (pos) {
bfill = ether.tcpOffset();
char *data = (char *) Ethernet::buffer + pos;
if (strncmp("GET /",data, 5) != 0) {
bfill.emit_p(http_Unauthorized);
else {
data += 5;
int relay=data[2] - 48; // ASCII code for the character '0' is decimal 48
if (data[0] == ' ') {
// If change on home page, execute function.
homePage();
//Debug
for (int i = 0; i <= 1; i++)digitalWrite(LedPins[i],!PinStatus[i]);
Serial.print("| F5 | ");
} else if( relay>0 && relay<=2 ) {
data += 4;
if (strncmp("on ", data, 3) == 0) {
PinStatus[relay-1] = true;
bfill.emit_p(http_Found);
// Debug
Serial.print("| R");
Serial.print(relay-1);
Serial.print(" ON | ");
} else if (strncmp("off ", data, 4) == 0) {
PinStatus[relay-1] = false;
// Debug
Serial.print(" OFF | ");
else if(strncmp("/50000/show_settings/",data, 21) != 0)
change_settings();
else if(strncmp("/50000/change_settings/",data, 23) != 0)
show_settings();
else if(strncmp("/50000/reset_to_deflaut/",data, 24) != 0)
reset_to_default();
else {
// Page not found
// Debug
Serial.print("/");
Serial.print(" ");
Serial.print("\n");
ether.httpServerReply(bfill.position()); // send http response
