help me samsung LA40D503F7R - the upper half of the screen green
mahmoud_3zz 01 Lut 2017 09:16 714 3
  • #1 16244322
    mahmoud_3zz
    Hi all can help me the upper half of the screen green
    model LA40D503F7R
    PANEL LTF400HM05
    • tmp_14453-????????_??????-2031002807.jpg (1.8 MB) Musisz być zalogowany, aby pobrać ten załącznik.
    • tmp_14453-????????_??????-2018273939.jpg (5.19 MB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #3 16245605
    mahmoud_3zz
    Can i fix it or just replace it ?
  • #4 19898905
    khaledwwe
    first is it on both hdmi and av if one of them work fine then this is setting but in your case maby the scaller ic is bad cause of panel have some impact affect on the gate on glass in the vertical gate and horizntal data or gama lines volt that reason for red or green picture the black par see if there is missing 'volt of gama von v1.8 v2.5 v 3.3 on capacitior coupled to the cof
    inter to edid and make write protect off after that make read edid if it write success then you must change scaller ic aam lcd lqf60 41top
